Hermit-At v4.0.0 (Armadillo-EVA 1500) compiled at 17:49:42, Jul 20 2014
mmcsd: SD card at address 0x00000001
mmcsd: M8G1GC 1048576KiB
gendisk: /dev/mmcblk0p1: start=0x00400800, size=0x00a8f800
gendisk: Image.bin is found. (6314692 Bytes)
Copying kernel...done.
Uncompressing fdt.done.
Doing console=ttySC3,115200
Doing mem=1024M
Doing noinitrd
Doing rootwait
Doing root=/dev/mmcblk0p1
Initializing cgroup subsys cpuset
Linux version 3.4.81-ae1500-at1 (atmark@atde5) (gcc version 4.6.3 (Debian 4.6.3-1
4atmark1) ) #1 SMP PREEMPT Fri Jul 18 17:18:24 JST 2014
CPU: ARMv7 Processor [413fc0f2] revision 2 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
Machine: armadilloeva1500, model: Armadillo-EVA 1500
cma: CMA: reserved 128 MiB at 66000000
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 7 pages/cpu @c160d000 s6144 r8192 d14336 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096
Kernel command line: console=ttySC3,115200 mem=1024M noinitrd rootwait root=/dev/
mmcblk0p1
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
allocated 2097152 bytes of page_cgroup
please try 'cgroup_disable=memory' option if you don't want memory cgroups
Memory: 1024MB = 1024MB total
Memory: 899692k/899692k available, 148884k reserved, 270336K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0599000 (5700 kB)
.init : 0xc0599000 - 0xc05c9800 ( 194 kB)
.data : 0xc05ca000 - 0xc060daa0 ( 271 kB)
.bss : 0xc060dac4 - 0xc0643384 ( 215 kB)
NR_IRQS:16 nr_irqs:16 16
Architected local timer running at 10.00MHz (virt).
Switching to timer-based delay loop
sched_clock: ARM arch timer >56 bits at 10000kHz, resolution 100ns
sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
Calibrating delay loop (skipped), value calculated using timer frequency.. 20.00
BogoMIPS (lpj=100000)
Initializing cgroup subsys cpuacct
Initializing cgroup subsys memory
Initializing cgroup subsys devices
Initializing cgroup subsys freezer
Initializing cgroup subsys blkio
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
Setting up static identity map for 0x40424dd0 - 0x40424e28
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (40.00 BogoMIPS).
devtmpfs: initialized
dummy:
sh-pfc pfc-r8a7791: r8a77910_pfc support registered
renesas_irqc renesas_irqc.0: driving 10 irqs
hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 8 bytes.
bio: create slab <bio-0> at 0
gpio_rcar gpio_rcar.0: driving 32 GPIOs
gpio_rcar gpio_rcar.1: driving 32 GPIOs
gpio_rcar gpio_rcar.2: driving 32 GPIOs
gpio_rcar gpio_rcar.3: driving 32 GPIOs
gpio_rcar gpio_rcar.4: driving 32 GPIOs
gpio_rcar gpio_rcar.5: driving 32 GPIOs
gpio_rcar gpio_rcar.6: driving 32 GPIOs
gpio_rcar gpio_rcar.7: driving 32 GPIOs
pwm-rcar pwm-rcar.0: registering PWM0
pwm-rcar pwm-rcar.1: registering PWM1
pwm-rcar pwm-rcar.2: registering PWM2
pwm-rcar pwm-rcar.3: registering PWM3
pwm-rcar pwm-rcar.4: registering PWM4
pwm-rcar pwm-rcar.5: registering PWM5
pwm-rcar pwm-rcar.6: registering PWM6
SCSI subsystem initialized
i2c-gpio i2c-gpio.7: using pins 238 (SDA) and 237 (SCL)
i2c-gpio i2c-gpio.8: using pins 240 (SDA) and 239 (SCL)
i2c-gpio i2c-gpio.9: using pins 71 (SDA) and 70 (SCL)
i2c-sh_mobile i2c-sh_mobile.6: I2C adapter 6 with bus speed 100000 Hz (L/H=32/2b)
Linux media interface: v0.10
vgaarb: loaded
sh_cmt sh_cmt.0: used for clock events
Advanced Linux Sound Architecture Driver Version 1.0.25.
Switching to clocksource arch_sys_counter
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
audit: initializing netlink socket (disabled)
type=2000 audit(0.170:1): initialized
highmem bounce pool size: 64 pages
VFS: Disk quotas dquot_6.5.2
nfs4filelayout_init: NFSv4 File Layout Driver Registering...
jffs2: version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
msgmni has been set to 1485
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
io scheduler noop registered
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
SuperH (H)SCI(F) driver initialized
sh-sci.0: ttySC0 at MMIO 0xe6c40000 (irq = 176) is a scifa
sh-sci.1: ttySC1 at MMIO 0xe6c50000 (irq = 177) is a scifa
sh-sci.2: ttySC2 at MMIO 0xe6c20000 (irq = 180) is a scifb
sh-sci.3: ttySC3 at MMIO 0xe6c30000 (irq = 181) is a scifb
console [ttySC3] enabled
sh-sci.4: ttySC4 at MMIO 0xe6ce0000 (irq = 182) is a scifb
sh-sci.5: ttySC5 at MMIO 0xe6c60000 (irq = 183) is a scifa
sh-sci.6: ttySC6 at MMIO 0xe6e60000 (irq = 184) is a scif
sh-sci.7: ttySC7 at MMIO 0xe6e68000 (irq = 185) is a scif
sh-sci.8: ttySC8 at MMIO 0xe62c0000 (irq = 186) is a hscif
sh-sci.9: ttySC9 at MMIO 0xe62c8000 (irq = 187) is a hscif
sh-sci.10: ttySC10 at MMIO 0xe6e58000 (irq = 54) is a scif
sh-sci.11: ttySC11 at MMIO 0xe6ea8000 (irq = 55) is a scif
sh-sci.12: ttySC12 at MMIO 0xe6ee0000 (irq = 56) is a scif
sh-sci.13: ttySC13 at MMIO 0xe6ee8000 (irq = 57) is a scif
sh-sci.14: ttySC14 at MMIO 0xe6c70000 (irq = 61) is a scifa
sh-sci.15: ttySC15 at MMIO 0xe6c78000 (irq = 62) is a scifa
sh-sci.16: ttySC16 at MMIO 0xe6c80000 (irq = 63) is a scifa
sh-sci.17: ttySC17 at MMIO 0xe62d0000 (irq = 53) is a hscif
scsi0 : sata_rcar
ata1: SATA max UDMA/133 irq 137
scsi1 : sata_rcar
ata2: SATA max UDMA/133 irq 138
m25p80 spi0.0: n25q064 (8192 Kbytes)
Creating 4 MTD partitions on "m25p80":
0x000000000000-0x000000010000 : "ipl"
0x000000010000-0x000000090000 : "bootloader"
0x000000090000-0x0000000d0000 : "fdt"
0x0000000d0000-0x000000800000 : "firmware"
qspi qspi.0: probed
spi_sh_msiof spi_sh_msiof.1: master is unqueued, this is deprecated
spi_sh_msiof spi_sh_msiof.2: master is unqueued, this is deprecated
spi_sh_msiof spi_sh_msiof.3: master is unqueued, this is deprecated
sh_mii: probed
Base address at 0xee700000, 00:11:0c:1a:00:00, IRQ 194.
ehci-platform ehci-platform.0: Generic Platform EHCI Controller
ehci-platform ehci-platform.0: new USB bus registered, assigned bus number 1
ehci-platform ehci-platform.0: irq 140, io mem 0xee081000
ehci-platform ehci-platform.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ehci-platform ehci-platform.1: Generic Platform EHCI Controller
ehci-platform ehci-platform.1: new USB bus registered, assigned bus number 2
ehci-platform ehci-platform.1: irq 145, io mem 0xee0c1000
ehci-platform ehci-platform.1: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-platform ohci-platform.0: Generic Platform OHCI Controller
ohci-platform ohci-platform.0: new USB bus registered, assigned bus number 3
ohci-platform ohci-platform.0: irq 140, io mem 0xee080000
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
ohci-platform ohci-platform.1: Generic Platform OHCI Controller
ohci-platform ohci-platform.1: new USB bus registered, assigned bus number 4
ohci-platform ohci-platform.1: irq 145, io mem 0xee0c0000
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
xhci-hcd xhci-hcd.0: xHCI Host Controller
ata1: link resume succeeded after 1 retries
xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 5
ata2: link resume succeeded after 1 retries
xhci-hcd xhci-hcd.0: irq 133, io mem 0xee000000
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 1 port detected
xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 6
hub 6-0:1.0: USB hub found
hub 6-0:1.0: 1 port detected
input: st1232-touchscreen as /devices/platform/i2c-gpio.9/i2c-9/9-0055/input/inpu
t0
rtc-s35390a 7-0030: rtc core: registered rtc-s35390a as rtc0
i2c /dev entries driver
i2c-rcar i2c-rcar_h2.0: probed
i2c-rcar i2c-rcar_h2.1: probed
i2c-rcar i2c-rcar_h2.2: probed
i2c-rcar i2c-rcar_h2.3: probed
i2c-rcar i2c-rcar_h2.4: probed
i2c-rcar i2c-rcar_h2.5: probed
lirc_dev: IR Remote Control driver registered, major 250
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
ata1: SATA link down (SStatus 0 SControl 300)
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
ata2: SATA link down (SStatus 0 SControl 300)
IR Sony protocol handler initialized
IR RC5 (streamzap) protocol handler initialized
IR SANYO protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR LIRC bridge handler initialized
i2c-core: driver [adv7180] using legacy suspend method
i2c-core: driver [adv7180] using legacy resume method
soc-camera-pdrv soc-camera-pdrv.2: Probing soc-camera-pdrv.2
vin vin.2: VIN Unit driver attached to camera 0
adv7180 8-0020: chip found @ 0x40 (i2c-gpio8)
vin vin.2: VIN Unit driver detached from camera 0
uvcvideo: Unable to create debugfs directory
[drm] Initialized drm 1.1.0 20060810
Console: switching to colour frame buffer device 240x67
rcar-du rcar-du-r8a7791: fb0: frame buffer device
rcar-du rcar-du-r8a7791: registered panic notifier
[drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[drm] No driver support for vblank timestamp query.
[drm] Initialized rcar-du 1.0.0 20130110 on minor 0
rcar_thermal rcar_thermal: 1 sensor proved
device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
sh_mmcif sh_mmcif.0: driver version 2010-04-28
mmc0: new high speed MMC card at address 0001
mmcblk0: mmc0:0001 M8G1GC 7.28 GiB
mmcblk0boot0: mmc0:0001 M8G1GC partition 1 4.00 MiB
mmcblk0boot1: mmc0:0001 M8G1GC partition 2 4.00 MiB
mmcblk0: p1 p2
mmcblk0boot1: unknown partition table
mmcblk0boot0: unknown partition table
sh_mobile_sdhi sh_mobile_sdhi.0: mmc1 base at 0xee100000 clock rate 0 MHz
sh_mobile_sdhi sh_mobile_sdhi.1: mmc2 base at 0xee140000 clock rate 0 MHz
usbhid: USB HID core driver
cs42l52 8-004a: Cirrus Logic CS42L52, Revision: 03
input: CS42L52 Beep Generator as /devices/platform/i2c-gpio.8/i2c-8/8-004a/input/
input1
asoc: cs42l52 <-> scu-ssi-dai mapping ok
TCP: cubic registered
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
input: gpio-keys as /devices/platform/gpio-keys/input/input2
rtc-s35390a 7-0030: setting system clock to 2014-07-20 19:50:30 UTC (1405885830)
platform pvrsrvkm: start latency exceeded, new value 5900 ns
platform pvrsrvkm: state save latency exceeded, new value 500 ns
ALSA device list:
#0: armadilloeva1500-cs42l52
platform pvrsrvkm: stop latency exceeded, new value 5000 ns
kjournald starting. Commit interval 5 seconds
EXT3-fs (mmcblk0p1): mounted filesystem with ordered data mode
VFS: Mounted root (ext3 filesystem) readonly on device 179:1.
devtmpfs: mounted
Freeing init memory: 192K
INIT: version 2.88 booting
[info] Using makefile-style concurrent boot in runlevel S.
[....] Starting the hotplug events dispatcher: udevdudevd[965]: starting version
175
. ok
[....] Synthesizing the initial hotplug events...done.
[....] Waiting for /dev to be fully populated...vin vin.2: VIN Unit driver attach
ed to camera 0
adv7180 8-0020: Detected the NTSC video input signal
[....] Activating swap...done.
[....] Checking root file system...fsck from util-linux 2.20.1
/dev/mmcblk0p1: clean, 24601/346064 files, 164793/1384192 blocks
EXT3-fs (mmcblk0p1): using internal journal
[....] Cleaning up temporary files... /tmp. ok
[info] Loading kernel module loop.
libkmod: ERROR ../libkmod/libkmod.c:554 kmod_search_moddep: could not open moddep
file '/lib/modules/3.4.81-ae1500-at1/modules.dep.bin'
[....] Activating lvm and md swap...done.
[....] Checking file systems...fsck from util-linux 2.20.1
[....] Mounting local filesystems...done.
[....] Activating swapfile swap...done.
[....] Cleaning up temporary files.... ok
[....] Setting kernel variables ...done.
[....] Configuring network interfaces...done.
[....] Starting rpcbind daemon...rpcbind: cannot create socket for udp6
rpcbind: cannot create socket for tcp6
. ok
[....] Starting NFS common utilities: statd idmapd. ok
[....] Setting up ALSA...done.
INIT: Entering runlevel: 2
[info] Using makefile-style concurrent boot in runlevel 2.
[....] Starting rpcbind daemon...[....] Already running.. ok
[....] Starting enhanced syslogd: rsyslogd. ok
[....] Starting deferred execution scheduler: atd. ok
[....] Starting periodic command scheduler: cron. ok
[....] Starting MTA: exim4. ok
ALERT: exim paniclog /var/log/exim4/paniclog has non-zero size, mail system possi
bly broken
Debian GNU/Linux 7 debian ttySC3
debian login:
