Hermit-At v1.1.9 (Armadillo-500) compiled at 12:00:00, Jul 27 2007
Uncompressing kernel......................................................
...............................................................done.
Uncompressing ramdisk......................................................
Linux version 2.6.18-12-at0 (atmark@atde) (gcc version 4.1.2 20061115
(prerelease) (Debian 4.1.1-21)) #1 PREEMPT Thu Jul 26 00:01:12 JST 2007
CPU: Some Random V6 Processor [4107b364] revision 4 (ARMv6TEJ), cr=00c5387f
Machine: Armadillo-500
ATAG_INITRD is deprecated; please update your bootloader.
CPU0: D VIPT write-back cache
CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
CPU0: D cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
Built 1 zonelists. Total pages: 16384
Kernel command line: console=ttymxc0
MXC IRQ initialized
PID hash table entries: 512 (order: 9, 2048 bytes)
Actual CLOCK_TICK_RATE is 60000000 Hz
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 52748KB available (3078K code, 718K data, 120K init)
checking if image is initramfs...it isn't (bad gzip magic numbers); looks like
an initrd
Freeing initrd memory: 8192K
MXC GPIO hardware
system_rev is: 0x11
Clock input source is 26000000
L2 cache: WB
Using SDMA I.API
MXC DMA API initialized
usb: Host 2 registered
usb: OTG HS Host registered
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
MXC MMC/SD driver
mxcmci-0 found
IP route cache hash table entries: 512 (order: -1, 2048 bytes)
TCP established hash table entries: 2048 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 2048 bind 1024)
TCP reno registered
Low-Level PM Driver module loaded
NetWinder Floating Point Emulator V0.97 (double precision)
JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
Console: switching to colour frame buffer device 80x30
fb0: MXC frame buffer at 640x480x16 (CRT-VGA)
gpio: Armadillo-5x0 GPIO Sample driver [Rev.1.00]
MXC WatchDog Driver 2.0
MXC Watchdog Timer: initial timeout 60 sec
Serial: MXC Internal UART driver
mxcintuart.0: ttymxc0 at MMIO 0x43f90000 (irq = 45) is a Freescale MXC
mxcintuart.1: ttymxc1 at MMIO 0x43f94000 (irq = 32) is a Freescale MXC
RAMDISK driver initialized: 16 RAM disks of 16384K size 1024 blocksize
loop: loaded (max 8 devices)
eth0: LAN9118 (rev 1) at 0xc4850000 IRQ 64
eth0: Ethernet addr: 00:11:0c:0a:00:01
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
NFTL driver: nftlcore.c $Revision: 1.98 $, nftlmount.c $Revision: 1.41 $
armadillo5x0-nor: Found 1 x16 devices at 0x0 in 16-bit bank
Using buffer write method
armadillo5x0-nor: use default partitions(4)
Creating 4 MTD partitions on "armadillo5x0-nor":
0x00000000-0x00020000 : "nor.bootloader"
0x00020000-0x00220000 : "nor.kernel"
0x00220000-0x00fe0000 : "nor.userland"
0x00fe0000-0x01000000 : "nor.config"
MXC MTD nand Driver 2.0
NAND device: Manufacturer ID: 0x20, Chip ID: 0xf1 (ST Micro NAND 128MiB 3,3V
8-bit)
Scanning device for bad blocks
Creating 4 MTD partitions on "NAND 128MiB 3,3V 8-bit":
0x00000000-0x00020000 : "nand.ipl"
0x00020000-0x00420000 : "nand.kernel"
0x00420000-0x01a20000 : "nand.userland"
0x01a20000-0x10000000 : "nand.free"
armadillo5x0_pcmcia: PCMCIA driver [Rev.1 (2007/--/--)], (C) 2007 Atmark Techno,
Inc.
usbmon: debugfs is not available
fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
fsl-ehci fsl-ehci.0: irq 36, io base 0x43f88400
fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detectedt
fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
fsl-ehci fsl-ehci.1: irq 37, io base 0x43f88000
fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usbcore: registered new driver usb-storage
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
pegasus: v0.6.13 (2005/11/13), Pegasus/Pegasus II USB Ethernet driver
usbcore: registered new driver pegasus
mice: PS/2 mouse device common for all mice
tactsw: Armadillo-5x0 Tact-SW driver [Rev.1.00]
input: Tact-SW Port1 as /class/input/input0
input: Tact-SW Port2 as /class/input/input1
rtc-s353xxa: S-353XXA Real Time Clock class driver [Rev.1 (2007/--/--)], (C)
2007 Atmark Techno, Inc.
i2c /dev entries driver
i2c_armadillo5x0: Armadillo-5x0 I2C driver [Rev.1 (2007/--/--)], (C) 2007 Atmark
Techno, Inc.
rtc-s353xxa 0-0030: rtc intf: sysfs
rtc-s353xxa 0-0030: rtc intf: proc
rtc-s353xxa 0-0030: rtc intf: dev (253:0)
rtc-s353xxa 0-0030: rtc core: registered S-353XXA as rtc0
tlv320aic: TI TLV320AIC Audio codec driver [Rev.1 (2007/--/--)], (C) 2007 Atmark
Techno, Inc.
IPU Post-filter loading
SSI module loaded successfully
led: Armadillo-5x0 LED driver, (C) 2007 Atmark Techno, Inc.
Registered led device: led1
Registered led device: led2
Registered led device: led3
Registered led device: led4
Registered led device: led5
Advanced Linux Sound Architecture Driver Version 1.0.12rc1 (Thu Jun 22 13:55:50
2006 UTC).
mxc_alsa_i2s: MXC ALSA iis audio driver [Rev.1 (2007/--/--)], (C) 2007 Atmark
Techno, Inc.
usbcore: registered new driver snd-usb-audio
ALSA device list:
#0: mxc i2s audio
IPv4 over IPv4 tunneling driver
TCP bic registered
ieee80211: 802.11 data/management/control stack, git-1.1.13
ieee80211: Copyright (C) 2004-2005 Intel Corporation <jketreno@linux.intel.com>
Power Management for Freescale MX31
VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 2
rtc-s353xxa 0-0030: setting the system clock to 2007-07-26 14:01:52 (1185458512)
RAMDISK: Loading 8192KiB [1 disk] into ram disk... done.
VFS: Mounted root (ext2 filesystem).
Freeing init memory: 120K
init started: BusyBox v1.00 (2007.07.25-15:02+0000) multi-call binary
Starting fsck for root filesystem.
fsck 1.25 (20-Sep-2001)
ext2fs_check_if_mount: No such file or directory while determining whether
/dev/ram0 is mounted.
/dev/ram0: clean, 719/1024 files, 6572/8192 blocks
Checking root filesystem: done
Remounting root rw: done
Mounting proc: done
Mounting usbfs: done
Mounting sysfs: done
Cleaning up system: done
Running local start scripts.
Starting udevd: done
Changing file permissions: done
Configure /home/ftp: done
Starting syslogd: done
Starting klogd: done
Loading /etc/config: done
Starting basic firewall: done
Setting hostname: done
Configuring network interfaces: info, udhcpc (v0.9.9-pre) started
eth0: link down
eth0: link up, 100Mbps, full-duplex, lpa 0x05E1
debug, Sending select for 172.16.1.93...
info, Lease of 172.16.1.100 obtained, lease time 86400
done
Starting inetd: done
Stating sshd: done
Starting thttpd: done
Mounting ramfs /home/ftp/pub: done
atmark-dist v1.10.0 (AtmarkTechno/Armadillo-500)
Linux 2.6.18-12-at0 [armv6l arch]
armadillo500 login:
