起動と終了
5.1. 起動
電源入力インターフェースに電源を接続すると Armadillo-IoT ゲートウェイ G4 が起動します。起動すると CON6 (USB コンソールインターフェース) から起動ログが表示されます。
Armadillo-IoT ゲートウェイ G4 の電源投入時点でのジャンパ JP1 の状態によって起動モードが変化します。 詳しくは 「JP1(起動デバイス設定ジャンパ)」 を参照してください。
U-Boot SPL 2020.04-at1 (Dec 02 2021 - 01:42:08 +0000)
NOTICE:  BL31: v2.4(release):lf-5.10.y-1.0.0-0-gba76d337e
NOTICE:  BL31: Built : 08:25:30, Jun  9 2021
U-Boot 2020.04-at1 (Dec 02 2021 - 01:42:08 +0000)
CPU:   Industrial temperature grade (-40C to 105C) at 26C
  - ATF ba76d33
  - U-Boot 2020.04-at1
Unknown image format!
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.10.52-1-at (builder@98b643f88a21) (gcc (Alpine1
[    0.000000] Machine model: Atmark-Techno Armadillo-IoT Gateway G4 Board
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000062000000B
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shl
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000094300000B
[    0.000000] OF: reserved mem: initialized node vdev0buffer@94300000, compal
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000040000000-0x00000000bfffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000040000000-0x0000000055ffffff]
[    0.000000]   node   0: [mem 0x0000000058000000-0x00000000923fffff]
[    0.000000]   node   0: [mem 0x0000000092400000-0x00000000a43fffff]
[    0.000000]   node   0: [mem 0x00000000a4400000-0x00000000bfffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 22 pages/cpu s51728 r8192 d30192 u90112
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 507904
[    0.000000] Kernel command line: console=ttymxc1,115200 root=/dev/mmcblk2po
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 byt)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 byte)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 912664K/2064384K available (19326K kernel code, 1588K )
[    0.000000] random: get_random_u64 called from __kmem_cache_create+0x28/0x0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 .
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 160 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[    0.000000] ITS: No ITS available, not enabling LPIs
[    0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycls
[    0.000003] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 21s
[    0.000351] Console: colour dummy device 80x25
[    0.000382] Calibrating delay loop (skipped), value calculated using timer)
[    0.000397] pid_max: default: 32768 minimum: 301
[    0.000506] LSM: Security Framework initializing
[    0.000571] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, l)
[    0.000583] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 byt)
[    0.001724] rcu: Hierarchical SRCU implementation.
[    0.002984] smp: Bringing up secondary CPUs ...
[    0.003331] Detected VIPT I-cache on CPU1
[    0.003356] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[    0.003389] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.003778] Detected VIPT I-cache on CPU2
[    0.003797] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[    0.003817] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.004235] Detected VIPT I-cache on CPU3
[    0.004253] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[    0.004272] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.004328] smp: Brought up 1 node, 4 CPUs
[    0.004342] SMP: Total of 4 processors activated.
[    0.004349] CPU features: detected: 32-bit EL0 Support
[    0.004356] CPU features: detected: CRC32 instructions
[    0.004601] CPU: All CPU(s) started at EL2
[    0.004620] alternatives: patching kernel code
[    0.005296] devtmpfs: initialized
[    0.013072] KASLR disabled due to lack of seed
[    0.013221] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff,s
[    0.013234] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.031459] pinctrl core: initialized pinctrl subsystem
[    0.032122] NET: Registered protocol family 16
[    0.038565] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocatios
[    0.039388] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic as
[    0.040199] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomics
[    0.040256] audit: initializing netlink subsys (disabled)
[    0.040448] audit: type=2000 audit(0.040:1): state=initialized audit_enabl1
[    0.040844] thermal_sys: Registered thermal governor 'step_wise'
[    0.041137] cpuidle: using governor ladder
[    0.041157] cpuidle: using governor menu
[    0.041399] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.041471] ASID allocator initialised with 65536 entries
[    0.042530] Serial: AMBA PL011 UART driver
[    0.042588] imx mu driver is registered.
[    0.042611] imx rpmsg driver is registered.
[    0.077103] imx8mp-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
[    0.094048] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.094063] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.094069] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.094077] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.095599] cryptd: max_cpu_qlen set to 1000
[    0.164236] raid6: neonx8   gen()  2150 MB/s
[    0.232284] raid6: neonx8   xor()  1604 MB/s
[    0.300362] raid6: neonx4   gen()  2200 MB/s
[    0.368398] raid6: neonx4   xor()  1567 MB/s
[    0.436455] raid6: neonx2   gen()  2098 MB/s
[    0.504512] raid6: neonx2   xor()  1443 MB/s
[    0.572561] raid6: neonx1   gen()  1798 MB/s
[    0.640615] raid6: neonx1   xor()  1222 MB/s
[    0.708677] raid6: int64x8  gen()  1438 MB/s
[    0.776717] raid6: int64x8  xor()   771 MB/s
[    0.844764] raid6: int64x4  gen()  1601 MB/s
[    0.912817] raid6: int64x4  xor()   822 MB/s
[    0.980863] raid6: int64x2  gen()  1399 MB/s
[    1.048914] raid6: int64x2  xor()   748 MB/s
[    1.116954] raid6: int64x1  gen()  1033 MB/s
[    1.185017] raid6: int64x1  xor()   517 MB/s
[    1.185024] raid6: using algorithm neonx4 gen() 2200 MB/s
[    1.185031] raid6: .... xor() 1567 MB/s, rmw enabled
[    1.185038] raid6: using neon recovery algorithm
[    1.187393] iommu: Default domain type: Translated
[    1.187536] vgaarb: loaded
[    1.187760] SCSI subsystem initialized
[    1.188012] usbcore: registered new interface driver usbfs
[    1.188047] usbcore: registered new interface driver hub
[    1.188073] usbcore: registered new device driver usb
[    1.189560] mc: Linux media interface: v0.10
[    1.189586] videodev: Linux video capture interface: v2.00
[    1.189653] pps_core: LinuxPPS API ver. 1 registered
[    1.189660] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Gi>
[    1.189674] PTP clock support registered
[    1.189706] EDAC MC: Ver: 3.0.0
[    1.190705] Advanced Linux Sound Architecture Driver Initialized.
[    1.191058] Bluetooth: Core ver 2.22
[    1.191079] NET: Registered protocol family 31
[    1.191086] Bluetooth: HCI device and connection manager initialized
[    1.191096] Bluetooth: HCI socket layer initialized
[    1.191105] Bluetooth: L2CAP socket layer initialized
[    1.191113] Bluetooth: SCO socket layer initialized
[    1.191319] nfc: nfc_init: NFC Core ver 0.1
[    1.191363] NET: Registered protocol family 39
[    1.192109] clocksource: Switched to clocksource arch_sys_counter
[    1.192260] VFS: Disk quotas dquot_6.6.0
[    1.192309] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.198319] NET: Registered protocol family 2
[    1.198427] IP idents hash table entries: 32768 (order: 6, 262144 bytes, l)
[    1.199407] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 1)
[    1.199436] TCP established hash table entries: 16384 (order: 5, 131072 by)
[    1.199546] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, li)
[    1.199762] TCP: Hash tables configured (established 16384 bind 16384)
[    1.199836] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    1.199879] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, line)
[    1.200027] NET: Registered protocol family 1
[    1.200330] RPC: Registered named UNIX socket transport module.
[    1.200336] RPC: Registered udp transport module.
[    1.200343] RPC: Registered tcp transport module.
[    1.200350] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.201003] PCI: CLS 0 bytes, default 64
[    1.201724] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counterse
[    1.206710] Initialise system trusted keyrings
[    1.206795] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    1.211625] DLM installed
[    1.212333] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.212845] NFS: Registering the id_resolver key type
[    1.212865] Key type id_resolver registered
[    1.212872] Key type id_legacy registered
[    1.212944] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.212955] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Register.
[    1.212978] ntfs: driver 2.1.32 [Flags: R/W].
[    1.213113] jffs2: version 2.2. (NAND) (SUMMARY)  �© 2001-2006 Red Hat, In.
[    1.213448] fuse: init (API version 7.32)
[    1.213771] SGI XFS with ACLs, security attributes, realtime, quota, no ded
[    1.252232] xor: measuring software checksum speed
[    1.256418]    8regs           :  2365 MB/sec
[    1.259935]    32regs          :  2802 MB/sec
[    1.264084]    arm64_neon      :  2380 MB/sec
[    1.264090] xor: using function: 32regs (2802 MB/sec)
[    1.264111] Key type asymmetric registered
[    1.264117] Asymmetric key parser 'x509' registered
[    1.264150] Block layer SCSI generic (bsg) driver version 0.4 loaded (majo)
[    1.264159] io scheduler mq-deadline registered
[    1.266122] samsung-hdmi-phy 32fdff00.hdmiphy: failed to get phy apb clk: 7
[    1.266262] imx8-pcie-phy 32f00000.pcie-phy: failed to get imx pcie phy clk
[    1.272711] i.MX clk 324: register failed with -2
[    1.272720] i.MX clk 325: register failed with -2
[    1.272727] i.MX clk 326: register failed with -2
[    1.272734] i.MX clk 328: register failed with -2
[    1.272742] i.MX clk 329: register failed with -2
[    1.272749] i.MX clk 330: register failed with -2
[    1.278254] imx-sdma 30bd0000.dma-controller: firmware found.
[    1.278409] imx-sdma 30bd0000.dma-controller: loaded firmware 4.5
[    1.280171] Bus freq driver module loaded
[    1.284867] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.287139] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 30, base_baX
[    1.287798] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 31, base_baX
[    2.385364] printk: console [ttymxc1] enabled
[    2.392506] imx-lcdifv3 32e90000.lcd-controller: No pix clock get: -517
[    2.399421] imx-lcdifv3 32fc6000.lcd-controller: No irq get, ret=-517
[    2.409510] imx-hdmi-pavi 32fc4000.hdmi-pai-pvi: No pvi clock get
[    2.424356] loop: module loaded
[    2.427787] zram: Added device: zram0
[    2.431933] usbcore: registered new interface driver pn533_usb
[    2.438015] nfcsim 0.2 initialized
[    2.441452] usbcore: registered new interface driver port100
[    2.447934] imx ahci driver is registered.
[    2.454193] libphy: Fixed MDIO Bus: probed
[    2.458794] tun: Universal TUN/TAP device driver, 1.6
[    2.463983] CAN device driver interface
[    2.470522] imx-dwmac 30bf0000.ethernet: IRQ eth_lpi not found
[    2.476456] imx-dwmac 30bf0000.ethernet: no reset control found
[    2.482520] imx-dwmac 30bf0000.ethernet: User ID: 0x10, Synopsys ID: 0x51
[    2.489322] imx-dwmac 30bf0000.ethernet:     DWMAC4/5
[    2.494143] imx-dwmac 30bf0000.ethernet: DMA HW capability register suppord
[    2.501292] imx-dwmac 30bf0000.ethernet: RX Checksum Offload Engine suppord
[    2.508439] imx-dwmac 30bf0000.ethernet: TX Checksum insertion supported
[    2.515147] imx-dwmac 30bf0000.ethernet: Wake-Up On Lan supported
[    2.521298] imx-dwmac 30bf0000.ethernet: Enable RX Mitigation via HW Watchr
[    2.528965] imx-dwmac 30bf0000.ethernet: Enabled Flow TC (entries=8)
[    2.535329] imx-dwmac 30bf0000.ethernet: Enabling HW TC (entries=256, max_)
[    2.542907] imx-dwmac 30bf0000.ethernet: Using 34 bits DMA width
[    2.549637] imx-dwmac 30bf0000.ethernet: Cannot register the MDIO bus
[    2.556098] imx-dwmac 30bf0000.ethernet: stmmac_dvr_probe: MDIO bus (id: 1d
[    2.565202] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet r
[    2.572658] usbcore: registered new interface driver pegasus
[    2.578352] usbcore: registered new interface driver rtl8150
[    2.584044] usbcore: registered new interface driver r8152
[    2.589573] usbcore: registered new interface driver lan78xx
[    2.595275] usbcore: registered new interface driver asix
[    2.600712] usbcore: registered new interface driver ax88179_178a
[    2.606840] usbcore: registered new interface driver cdc_ether
[    2.612702] usbcore: registered new interface driver dm9601
[    2.618309] usbcore: registered new interface driver CoreChips
[    2.624182] usbcore: registered new interface driver smsc75xx
[    2.629966] usbcore: registered new interface driver smsc95xx
[    2.635752] usbcore: registered new interface driver net1080
[    2.641444] usbcore: registered new interface driver plusb
[    2.646965] usbcore: registered new interface driver cdc_subset
[    2.652917] usbcore: registered new interface driver zaurus
[    2.658521] usbcore: registered new interface driver MOSCHIP usb-ethernet r
[    2.665953] usbcore: registered new interface driver cdc_ncm
[    2.671826] VFIO - User Level meta-driver version: 0.3
[    2.682647] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.689194] ehci-pci: EHCI PCI platform driver
[    2.693685] ehci-platform: EHCI generic platform driver
[    2.699118] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.705309] ohci-pci: OHCI PCI platform driver
[    2.709785] ohci-platform: OHCI generic platform driver
[    2.715698] usbcore: registered new interface driver cdc_acm
[    2.721366] cdc_acm: USB Abstract Control Model driver for USB modems and s
[    2.729527] usbcore: registered new interface driver uas
[    2.734891] usbcore: registered new interface driver usb-storage
[    2.740961] usbcore: registered new interface driver usbserial_generic
[    2.747513] usbserial: USB Serial support registered for generic
[    2.753554] usbcore: registered new interface driver ftdi_sio
[    2.759325] usbserial: USB Serial support registered for FTDI USB Serial De
[    2.766666] usbcore: registered new interface driver usb_serial_simple
[    2.773216] usbserial: USB Serial support registered for carelink
[    2.779328] usbserial: USB Serial support registered for zio
[    2.785007] usbserial: USB Serial support registered for funsoft
[    2.791031] usbserial: USB Serial support registered for flashloader
[    2.797403] usbserial: USB Serial support registered for google
[    2.803343] usbserial: USB Serial support registered for libtransistor
[    2.809890] usbserial: USB Serial support registered for vivopay
[    2.815919] usbserial: USB Serial support registered for moto_modem
[    2.822206] usbserial: USB Serial support registered for motorola_tetra
[    2.828840] usbserial: USB Serial support registered for novatel_gps
[    2.835214] usbserial: USB Serial support registered for hp4x
[    2.840980] usbserial: USB Serial support registered for suunto
[    2.846917] usbserial: USB Serial support registered for siemens_mpi
[    2.853305] usbcore: registered new interface driver usb_ehset_test
[    2.861517] udc-core: couldn't find an available UDC - added [g_multi] to s
[    2.871861] snvs_rtc 30370000.snvs:snvs-rtc-lp: registered as rtc1
[    2.878267] i2c /dev entries driver
[    2.882133] IR NEC protocol handler initialized
[    2.886676] IR RC5(x/sz) protocol handler initialized
[    2.891733] IR RC6 protocol handler initialized
[    2.896268] IR JVC protocol handler initialized
[    2.900804] IR Sony protocol handler initialized
[    2.905429] IR SANYO protocol handler initialized
[    2.910138] IR Sharp protocol handler initialized
[    2.914846] IR MCE Keyboard/mouse protocol handler initialized
[    2.920684] IR XMP protocol handler initialized
[    2.925218] ir_imon_decoder: IR iMON protocol handler initialized
[    2.931316] IR RCMM protocol handler initialized
[    2.936718] usbcore: registered new interface driver uvcvideo
[    2.942472] USB Video Class driver (1.1.1)
[    2.949120] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm
[    2.957646] Bluetooth: HCI UART driver ver 2.3
[    2.962104] Bluetooth: HCI UART protocol H4 registered
[    2.967250] Bluetooth: HCI UART protocol BCSP registered
[    2.972588] Bluetooth: HCI UART protocol LL registered
[    2.977733] Bluetooth: HCI UART protocol ATH3K registered
[    2.983151] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    2.989499] Bluetooth: HCI UART protocol Intel registered
[    2.994984] Bluetooth: HCI UART protocol Broadcom registered
[    3.000665] Bluetooth: HCI UART protocol QCA registered
[    3.005906] Bluetooth: HCI UART protocol AG6XX registered
[    3.011326] Bluetooth: HCI UART protocol Marvell registered
[    3.016946] usbcore: registered new interface driver bcm203x
[    3.022649] usbcore: registered new interface driver bpa10x
[    3.028264] usbcore: registered new interface driver bfusb
[    3.033786] usbcore: registered new interface driver btusb
[    3.039319] usbcore: registered new interface driver ath3k
[    3.045073] EDAC MC: ECC not enabled
[    3.049735] sdhci: Secure Digital Host Controller Interface driver
[    3.055926] sdhci: Copyright(c) Pierre Ossman
[    3.060418] Synopsys Designware Multimedia Card Interface Driver
[    3.067077] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.074834] ledtrig-cpu: registered to indicate activity on CPUs
[    3.081336] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    3.088544] caam-snvs 30370000.caam-snvs: violation handlers armed - init e
[    3.096958] usbcore: registered new interface driver usbhid
[    3.102542] usbhid: USB HID core driver
[    3.106306] mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADA
[    3.106838] mxc-mipi-csi2-sam 32e40000.csi: supply mipi-phy not found, usir
[    3.122897] mxc-md 32c00000.bus:camera: deferring cap_device registration
[    3.133168] optee: probing for conduit method.
[    3.137644] optee: revision 3.13 (2c1092df)
[    3.138454] optee: dynamic shared memory is enabled
[    3.147834] optee: initialized driver
[    3.154457] Galcore version 6.4.3.p2.336687
[    3.232442] mmc2: new HS400 MMC card at address 0001
[    3.238935] mmcblk2: mmc2:0001 S0J56X 7.30 GiB
[    3.243670] mmcblk2boot0: mmc2:0001 S0J56X partition 1 31.5 MiB
[    3.249753] mmcblk2boot1: mmc2:0001 S0J56X partition 2 31.5 MiB
[    3.255823] mmcblk2gp0: mmc2:0001 S0J56X partition 4 8.00 MiB
[    3.261721] mmcblk2gp1: mmc2:0001 S0J56X partition 5 8.00 MiB
[    3.267631] mmcblk2gp2: mmc2:0001 S0J56X partition 6 8.00 MiB
[    3.269745] [drm] Initialized vivante 1.0.0 20170808 for 40000000.mix_gpu_0
[    3.273559] mmcblk2gp3: mmc2:0001 S0J56X partition 7 8.00 MiB
[    3.282741] hantrodec 0 : module inserted. Major = 237
[    3.287841] mmcblk2rpmb: mmc2:0001 S0J56X partition 3 4.00 MiB, chardev (2)
[    3.292956] hantrodec 1 : module inserted. Major = 237
[    3.306236] hantroenc: HW at base < 0000000038320000 > with ID <0x80006200>
[    3.313214] hx280enc: module inserted. Major < 236 >
[    3.320369] usbcore: registered new interface driver snd-usb-audio
[    3.327391]  mmcblk2: p1 p2 p3 p4 p5
[    3.330540] fsl-aud2htx 30cb0000.aud2htx: failed to get mem clock
[    3.338973] imx-cdnhdmi sound-hdmi: snd_soc_register_card failed (-517)
[    3.345703] Mirror/redirect action on
[    3.349490] u32 classifier
[    3.352256]     Performance counters on
[    3.356111]     input device check on
[    3.359780]     Actions configured
[    3.363230]  mmcblk2gp1:
[    3.365602] xt_time: kernel timezone is -0000
[    3.370462] Initializing XFRM netlink socket
[    3.375232] NET: Registered protocol family 10
[    3.381554] Segment Routing with IPv6
[    3.385303] mip6: Mobile IPv6
[    3.388440] NET: Registered protocol family 17
[    3.392945] Bridge firewalling registered
[    3.396981] can: controller area network core
[    3.401387] NET: Registered protocol family 29
[    3.405838] can: raw protocol
[    3.408815] can: broadcast manager protocol
[    3.413011] can: netlink gateway - max_hops=1
[    3.417537] Bluetooth: RFCOMM TTY layer initialized
[    3.422433] Bluetooth: RFCOMM socket layer initialized
[    3.427614] Bluetooth: RFCOMM ver 1.11
[    3.431372] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.436690] Bluetooth: BNEP filters: protocol multicast
[    3.441939] Bluetooth: BNEP socket layer initialized
[    3.446912] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.452847] Bluetooth: HIDP socket layer initialized
[    3.459682] NET: Registered protocol family 33
[    3.464146] Key type rxrpc registered
[    3.467808] Key type rxrpc_s registered
[    3.471672] 8021q: 802.1Q VLAN Support v1.8
[    3.480632] DCCP: Activated CCID 2 (TCP-like)
[    3.485026] DCCP: Activated CCID 3 (TCP-Friendly Rate Control)
[    3.491248] sctp: Hash tables configured (bind 256/256)
[    3.497420] NET: Registered protocol family 21
[    3.501991] Registered RDS/tcp transport
[    3.505938] lib80211: common routines for IEEE802.11 drivers
[    3.511698] 9pnet: Installing 9P2000 support
[    3.516004] tsn generic netlink module v1 init...
[    3.520906] NET: Registered protocol family 36
[    3.525386] Key type dns_resolver registered
[    3.529669] Key type ceph registered
[    3.534057] libceph: loaded (mon/osd proto 15/24)
[    3.538794] mpls_gso: MPLS GSO support
[    3.542860] registered taskstats version 1
[    3.546967] Loading compiled-in X.509 certificates
[    3.557254] Loaded X.509 cert 'Build time autogenerated kernel key: f706f5'
[    3.567223] Key type ._fscrypt registered
[    3.571241] Key type .fscrypt registered
[    3.575172] Key type fscrypt-provisioning registered
[    3.581092] Btrfs loaded, crc32c=crc32c-generic
[    3.594254] M2_3P3V: supplied by VEXT_3P3V
[    3.608568] nxp-pca9450 0-0025: pca9450bc probed.
[    3.613440] i2c i2c-0: IMX I2C adapter registered
[    3.621476] rtc-rv8803 1-0032: Voltage low, temperature compensation stopp.
[    3.628635] rtc-rv8803 1-0032: Voltage low, data loss detected.
[    3.637310] rtc-rv8803 1-0032: Voltage low, data is invalid.
[    3.643687] rtc-rv8803 1-0032: registered as rtc0
[    3.649321] rtc-rv8803 1-0032: Voltage low, data is invalid.
[    3.655012] rtc-rv8803 1-0032: hctosys: unable to read the hardware clock
[    3.662507] usb251xb 1-002c: supply vdd not found, using dummy regulator
[    3.675466] random: fast init done
[    3.710279] usb251xb 1-002c: Hub configuration was successful.
[    3.716125] usb251xb 1-002c: Hub probed successfully
[    3.731942] i2c i2c-1: IMX I2C adapter registered
[    3.740570] i2c i2c-2: IMX I2C adapter registered
[    3.746184] i2c i2c-3: IMX I2C adapter registered
[    3.752265] imx8mq-usb-phy 381f0040.usb-phy: supply vbus not found, using r
[    3.760759] imx8mq-usb-phy 382f0040.usb-phy: supply vbus not found, using r
[    3.769162] samsung-hdmi-phy 32fdff00.hdmiphy: failed to get phy apb clk: 7
[    3.780992] imx6q-pcie 33800000.pcie: supply epdev_on not found, using dumr
[    3.791994] imx6q-pcie 33800000.pcie: PLL REF_CLK is used!.
[    3.792181] SoC: i.MX8MP revision 1.1
[    3.798166] imx6q-pcie 33800000.pcie: PCIe PHY PLL clock is locked.
[    3.801518] imx-cpufreq-dt imx-cpufreq-dt: cpu speed grade 7 mkt segment 24
[    3.818776] imx-lcdifv3 32fc6000.lcd-controller: No irq get, ret=-517
[    3.826599] imx-sdma 30e10000.dma-controller: firmware found.
[    3.846798] imx6q-pcie 33800000.pcie: PCIe PLL locked after 0 us.
[    3.852965] imx6q-pcie 33800000.pcie: host bridge /soc@0/pcie@33800000 ran:
[    3.860235] imx6q-pcie 33800000.pcie:   No bus range found for /soc@0/pcie]
[    3.869588] imx6q-pcie 33800000.pcie:       IO 0x001ff80000..0x001ff8ffff 0
[    3.877795] imx6q-pcie 33800000.pcie:      MEM 0x0018000000..0x001fefffff 0
[    3.886057] imx6q-pcie 33800000.pcie: invalid resource
[    4.109250] pps pps0: new PPS source ptp0
[    4.118961] libphy: fec_enet_mii_bus: probed
[    4.125458] fec 30be0000.ethernet eth0: registered PHC device 0
[    4.132187] imx-dwmac 30bf0000.ethernet: IRQ eth_lpi not found
[    4.138100] imx-dwmac 30bf0000.ethernet: no reset control found
[    4.144415] imx-dwmac 30bf0000.ethernet: User ID: 0x10, Synopsys ID: 0x51
[    4.151216] imx-dwmac 30bf0000.ethernet:     DWMAC4/5
[    4.156015] imx-dwmac 30bf0000.ethernet: DMA HW capability register suppord
[    4.163158] imx-dwmac 30bf0000.ethernet: RX Checksum Offload Engine suppord
[    4.170296] imx-dwmac 30bf0000.ethernet: TX Checksum insertion supported
[    4.177002] imx-dwmac 30bf0000.ethernet: Wake-Up On Lan supported
[    4.183098] imx-dwmac 30bf0000.ethernet: Enable RX Mitigation via HW Watchr
[    4.190759] imx-dwmac 30bf0000.ethernet: Enabled Flow TC (entries=8)
[    4.197135] imx-dwmac 30bf0000.ethernet: Enabling HW TC (entries=256, max_)
[    4.204713] imx-dwmac 30bf0000.ethernet: Using 34 bits DMA width
[    4.392439] libphy: stmmac: probed
[    4.399725] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    4.405256] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus1
[    4.413275] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe6c hci version 0x0
[    4.422703] xhci-hcd xhci-hcd.1.auto: irq 69, io mem 0x38100000
[    4.429295] hub 1-0:1.0: USB hub found
[    4.433064] hub 1-0:1.0: 1 port detected
[    4.437166] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    4.442663] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus2
[    4.450332] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    4.456895] usb usb2: We don't know the algorithms for LPM for this host, .
[    4.465909] hub 2-0:1.0: USB hub found
[    4.469685] hub 2-0:1.0: 1 port detected
[    4.474619] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    4.480127] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus3
[    4.488119] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe6c hci version 0x0
[    4.497550] xhci-hcd xhci-hcd.2.auto: irq 70, io mem 0x38200000
[    4.504474] hub 3-0:1.0: USB hub found
[    4.508245] hub 3-0:1.0: 1 port detected
[    4.512351] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    4.517853] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus4
[    4.525520] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[    4.532089] usb usb4: We don't know the algorithms for LPM for this host, .
[    4.541033] hub 4-0:1.0: USB hub found
[    4.544821] hub 4-0:1.0: 1 port detected
[    4.551355] sdhci-esdhc-imx 30b50000.mmc: Got CD GPIO
[    4.551484] caam 30900000.crypto: device ID = 0x0a16040100000100 (Era 9)
[    4.563168] caam 30900000.crypto: job rings = 2, qi = 0
[    4.587229] caam algorithms registered in /proc/crypto
[    4.588548] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADA
[    4.593246] caam 30900000.crypto: caam pkc algorithms registered in /proc/o
[    4.606926] caam 30900000.crypto: registering rng-caam
[    4.613314] Device caam-keygen registered
[    4.618810] mxc-mipi-csi2-sam 32e40000.csi: supply mipi-phy not found, usir
[    4.627543] mxc-mipi-csi2-sam 32e40000.csi: lanes: 2, hs_settle: 13, clk_s0
[    4.638726] isi-capture 32e00000.isi:cap_device: deferring 32e00000.isi:can
[    4.648753] mxc-isi 32e00000.isi: mxc_isi.0 registered successfully
[    4.655368] random: crng init done
[    4.655708] mxc-md 32c00000.bus:camera: deferring cap_device registration
[    4.666802] imx-cdnhdmi sound-hdmi: snd_soc_register_card failed (-517)
[    4.675665] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops 0xfff)
[    4.683811] imx-drm display-subsystem: bound imx-lcdifv3-crtc.1 (ops 0xfff)
[    4.692062] imx-drm display-subsystem: bound 32c00000.bus:ldb@32ec005c (op)
[    4.701030] dwhdmi-imx 32fd8000.hdmi: Detected HDMI TX controller v2.13a w)
[    4.711333] dwhdmi-imx 32fd8000.hdmi: registered DesignWare HDMI I2C bus dr
[    4.720196] imx-drm display-subsystem: bound 32fd8000.hdmi (ops 0xffff8000)
[    4.728772] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem1
[    4.780434] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[    4.781256] Console: switching to colour frame buffer device 128x48
[    4.792591] mmc1: host does not support reading read-only switch, assuminge
[    4.814004] imx-drm display-subsystem: [drm] fb0: imx-drmdrmfb frame buffee
[    4.823157] mx8-img-md: Registered mxc_isi.0.capture as /dev/video2
[    4.829509] mx8-img-md: Registered sensor subdevice: imx219 1-0010 (1)
[    4.836081] mx8-img-md: created link [mxc_isi.0] => [mxc_isi.0.capture]
[    4.842700] mx8-img-md: created link [mxc-mipi-csi2.0] => [mxc_isi.0]
[    4.849146] mx8-img-md: created link [imx219 1-0010] => [mxc-mipi-csi2.0]
[    4.855937] mxc-md 32c00000.bus:camera: mxc_md_create_links
[    4.865370] input: audio-hdmi HDMI Jack as /devices/platform/sound-hdmi/so0
[    4.875042] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[    4.878953] imx6q-pcie 33800000.pcie: Phy link never came up
[    4.882773] isi-m2m 32e00000.isi:m2m_device: Register m2m success for ISI.0
[    4.890186] imx6q-pcie 33800000.pcie: failed to initialize host
[    4.894476] cfg80211: Loading compiled-in X.509 certificates for regulatore
[    4.900315] imx6q-pcie 33800000.pcie: unable to add pcie port.
[    4.910491] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    4.921546] ALSA device list:
[    4.924579]   #0: audio-hdmi
[    4.934273] EXT4-fs (mmcblk2p2): mounted filesystem with ordered data mode)
[    4.942461] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    4.950212] devtmpfs: mounted
[    4.953782] Freeing unused kernel memory: 2432K
[    4.972764] Run /sbin/init as init process
[    4.980292] hub 3-1:1.0: USB hub found
[    4.984090] mmc1: new ultra high speed SDR104 SDHC card at address 0007
[    4.984115] hub 3-1:1.0: 2 ports detected
[    4.995176] mmcblk1: mmc1:0007 SD16G 14.9 GiB
   OpenRC 0.43.3.bf57debcde is [    5.008424]  mmcblk1: p1 p2 p3 p4 p5
starting up Linux 5.10.52-1-at (aarch64)
 * Clock skew detected with `(null)'
 * Adjusting mtime of `/run/openrc/deptree' to Thu Nov 25 19:26:50 2021
 * Mounting cgroup filesystem ... [ ok ]
udev             | * Starting udev ...overlayfs        | * Preparing overlay c
overlayfs        | * Preparing overlay for /var
overlayfs        | * Preparing overlay for /root
[    5.707199] udevd[706]: starting version 3.2.10
overlayfs        | * Preparing overlay for /home
fsck_atlog       |fsck.fat 4.2 (2021-01-31)
fsck_atlog       |/dev/mmcblk2gp1: 2 files, 1/4081 clusters
fsck             | * Checking local filesystems  ... [ ok ]
[    5.765935] udevd[706]: starting eudev-3.2.10
root             | * Remounting filesystems ... [ ok ]
localmount       | * Mounting local filesystems ...[    5.923330] EXT4-fs (mme
[    5.928821] EXT4-fs (mmcblk2p3): mounted filesystem with ordered data mode)
[    5.937874] BTRFS: device label app devid 1 transid 4752 /dev/mmcblk2p5 sc)
[    5.947458] BTRFS info (device mmcblk2p5): use zstd compression, level 3
[    5.954305] BTRFS info (device mmcblk2p5): turning on async discard
[    5.960585] BTRFS info (device mmcblk2p5): using free space tree
[    5.966595] BTRFS info (device mmcblk2p5): has skinny extents
[    5.981704] BTRFS info (device mmcblk2p5): enabling ssd optimizations
rngd             | * Starting rngd ... [ ok ]
hostname         | * Setting hostname ...udev-trigger     | * Generating a ru]
udev-trigger     | * Populating /dev with existing devices through uevents ..]
bootmisc         | * Migrating /var/lock to /run/lock ... [ ok ]
bootmisc         | * / is not writable; unable to clean up underlying /run
bootmisc         | * Creating user login records ... [ ok ]
bootmisc         | * Wiping /var/tmp directory ... [ ok ]
syslog           | * Starting busybox syslog ... [ ok ]
dbus             | * Starting System Message Bus ... [ ok ]
[    7.098505] BTRFS: device label app devid 1 transid 62 /dev/mmcblk1p5 scan)
networkmanager   | * Starting networkmanager ... [ ok ]
reset_bootcount  |Environment OK, copy 1
podman-atmark    | * Starting Start podman containers ...chronyd          | *]
[    7.758482] Microchip KSZ9131 Gigabit PHY 30be0000.ethernet-1:03: attached)
[    7.824606] imx-dwmac 30bf0000.ethernet eth1: PHY [stmmac-1:03] driver [Mi)
[    7.852130] imx-dwmac 30bf0000.ethernet eth1: No Safety Features support fd
[    7.859381] imx-dwmac 30bf0000.ethernet eth1: IEEE 1588-2008 Advanced Timed
[    7.872271] imx-dwmac 30bf0000.ethernet eth1: registered PTP clock
[    7.878773] imx-dwmac 30bf0000.ethernet eth1: configuring for phy/rgmii-ide
[    7.894988] 8021q: adding VLAN 0 to HW filter on device eth1
Welcome to Alpine Linux 3.14
Kernel 5.10.52-1-at on an aarch64 (/dev/ttymxc1)
  - ATF ba76d33
5.2. ログイン
起動が完了するとログインプロンプトが表示されます。表5.1「シリアルコンソールログイン時のユーザ名とパスワード」に示すユーザでログインすることができます。
表5.1 シリアルコンソールログイン時のユーザ名とパスワード
ユーザ名パスワード権限
root ユーザ
一般ユーザ
初めてログインしたときは、パスワードの変更を促されます。事前に新しいパスワードを用意してください。
    初期パスワードを変更します。root でログインと同様にパスワードを入力します。
persist_file コマンドに関する詳細は「overlayfs と persist_file について」を参照してください。
5.3. 終了方法
安全に終了させる場合は、次のようにコマンドを実行し、「reboot: Power down」と表示されたのを確認してから電源を切断します。
urandom          | * Saving random seed ...chronyd          | * Stopping chronyd ...syslog           | * Stopping busybox syslog ... [ ok ]
overlayfs        | * Unmounting /etc ...rngd             | * Stopping rngd ...podman-atmark    | * Stopping Start podman containers ... [ ok ] [ ok ]
podman-atmark    | [ ok ]
udev             | * Stopping udev ...hwclock          | * Setting hardware clock using the system clock [UTC] ... [ ok ]
overlayfs        | [ !! ]
overlayfs        | * Unmounting /dev/shm/overlay_etc_lower ... [ ok ]
networkmanager   | * Stopping networkmanager ...overlayfs        | * Unmounting /var ...nm-dispatcher: req:1 'connectivity-change': find-scripts: Cannot execute '/etc/Netw.
dbus             | * Stopping System Message Bus ...nm-dispatcher: System bus stopped. Exiting
overlayfs        | [ !! ]
overlayfs        | * Unmounting /dev/shm/overlay_var_lower ... [ ok ]
overlayfs        | * Unmounting /root ... [ ok ]
overlayfs        | * Unmounting /dev/shm/overlay_root_lower ... [ ok ]
localmount       | * Unmounting loop devices
overlayfs        | * Unmounting /home ...localmount       | * Unmounting filesystems
localmount       | *   Unmounting /var/tmp ... [ ok ]
localmount       | *   Unmounting /var/app/volumes ... [ ok ]
localmount       | *   Unmounting /var/app/rollback/volumes ... [ ok ]
localmount       | *   Unmounting /var/lib/containers/storage_readonly ... [ ok ]
localmount       | *   Unmounting /var/log ... [ ok ]
localmount       | *   Unmounting /tmp ... [ ok ]
localmount       | *   Unmounting /home ...
 *   in use but fuser finds nothing
localmount       | [ !! ]
localmount       | *   Unmounting /var ... [ ok ]
localmount       | *   Unmounting /etc ... *   in use but fuser finds nothing
localmount       | [ !! ]
overlayfs        | * Unmounting /dev/shm/overlay_home_lower ... [ ok ]
killprocs        | * Terminating remaining processes ...mount-ro         | * Remounting remaining filesystems read-only ... *   Remounting /etc read only ... [ ok ]
mount-ro         | *   Remounting / read only ... [ ok ]
mount-ro         | [ ok ]
[   62.855146] imx2-wdt 30280000.watchdog: Device shutdown: Expect reboot!
[   62.862470] reboot: Power down
