Hermit-At v3.10.0 (armadillo4x0) compiled at 10:17:05, Nov 06 2017
Uncompressing kernel...........................................................
...............................................................done.
Uncompressing ramdisk...........................................................
Initializing cgroup subsys cpuset
Initializing cgroup subsys cpuacct
Linux version 3.14.36-at10 (atmark@atde5) (gcc version 4.6.3 (Debian 4.6.3-14atm
ark1) ) #1 PREEMPT Mon Nov 6 22:41:58 JST 2017
CPU: VIVT data cache, VIVT instruction cache
Machine: Armadillo-440
Memory policy: Data cache writeback
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Kernel command line: console=ttymxc1,115200 root=/dev/ram0
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
allocated 262144 bytes of page_cgroup
please try 'cgroup_disable=memory' option if you don't want memory cgroups
Memory: 103232K/131072K available (4614K kernel code, 227K rwdata, 1416K rodata,
175K init, 150K bss, 27840K reserved)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xc8800000 - 0xff000000 ( 872 MB)
lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc05ebebc (6032 kB)
.init : 0xc05ec000 - 0xc0617dfc ( 176 kB)
.data : 0xc0618000 - 0xc0650f00 ( 228 kB)
.bss : 0xc0650f0c - 0xc06769e8 ( 151 kB)
Dump stacks of tasks blocking RCU-preempt GP.
NR_IRQS:16 nr_irqs:16 16
MXC IRQ initialized
Switching to timer-based delay loop
sched_clock: 32 bits at 66MHz, resolution 15ns, wraps every 64585974768ns
Calibrating delay loop (skipped), value calculated using timer frequency.. 133.0
0 BogoMIPS (lpj=665000)
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Initializing cgroup subsys memory
Initializing cgroup subsys devices
Initializing cgroup subsys freezer
Initializing cgroup subsys blkio
Setting up static identity map for 0x80488528 - 0x80488580
devtmpfs: initialized
regulator-dummy: no parameters
imx25-pinctrl imx25-pinctrl.0: initialized IMX pinctrl driver
bio: create slab <bio-0> at 0
eSDHC1 Vcc: at 3300 mV
USB VBUS: at 5000 mV
eSDHC2 Vcc: at 3300 mV
fixed-5.0V: at 5000 mV
SCSI subsystem initialized
i2c i2c-0: IMX I2C adapter registered
i2c i2c-1: IMX I2C adapter registered
i2c i2c-2: IMX I2C adapter registered
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@l
inux.it>
PTP clock support registered
Advanced Linux Sound Architecture Driver Initialized.
Switched to clocksource mxc_timer1
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP: reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Trying to unpack rootfs image as initramfs...
rootfs image is not initramfs (junk in compressed archive); looks like an initrd
Freeing initrd memory: 19800K (c1000000 - c2356000)
futex hash table entries: 256 (order: -1, 3072 bytes)
audit: initializing netlink subsys (disabled)
audit: type=2000 audit(0.759:1): initialized
VFS: Disk quotas dquot_6.5.2
msgmni has been set to 240
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
io scheduler noop registered
imx-fb imx21-fb.0: i.MX Framebuffer driver
Console: switching to colour frame buffer device 60x34
imx-sdma imx25-sdma: loaded firmware 1.0
imx-sdma imx25-sdma: initialized
imx21-uart.1: ttymxc1 at MMIO 0x43f94000 (irq = 48, base_baud = 7500000) is a IM
X
console [ttymxc1] enabled
imx21-uart.4: ttymxc4 at MMIO 0x5002c000 (irq = 56, base_baud = 7500000) is a IM
X
brd: module loaded
loop: module loaded
physmap platform flash device: 02000000 at a0000000
physmap-flash: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x0000
89 Chip ID 0x00227e
Amd/Fujitsu Extended Query Table at 0x0040
Amd/Fujitsu Extended Query version 1.3.
number of CFI chips: 1
Creating 4 MTD partitions on "physmap-flash":
0x000000000000-0x000000040000 : "nor.bootloader"
0x000000040000-0x000000440000 : "nor.kernel"
0x000000440000-0x000001f00000 : "nor.userland"
0x000001f00000-0x000002000000 : "nor.config"
libphy: fec_enet_mii_bus: probed
fec imx25-fec.0 eth0: Freescale FEC PHY driver [SMSC LAN8710/LAN8720] (mii_bus:p
hy_addr=imx25-fec-1:00, irq=-1)
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
rtc-s35390a 1-0030: rtc core: registered rtc-s35390a as rtc0
rtc-s35390a 2-0030: error resetting chip
rtc-s35390a: probe of 2-0030 failed with error -5
i2c /dev entries driver
uvcvideo: Unable to create debugfs directory
imx2-wdt imx2-wdt.0: timeout 10 sec (nowayout=0)
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: no vqmmc regulator found
mmc0: SDHCI controller on sdhci-esdhc-imx25.0 [sdhci-esdhc-imx25.0] using DMA
mmc1: no vqmmc regulator found
mmc1: SDHCI controller on sdhci-esdhc-imx25.1 [sdhci-esdhc-imx25.1] using DMA
usbhid: USB HID core driver
i.MX ADC at 0x50030000 irq 62
usbcore: registered new interface driver snd-usb-caiaq
wm8978 2-001a: Failed to issue reset: -5
wm8978: probe of 2-001a failed with error -5
armadillo4x0_wm8978 armadillo4x0_wm8978.0: ASoC: CODEC wm8978.2-001a not registe
red
armadillo4x0_wm8978 armadillo4x0_wm8978.0: snd_soc_register_card failed (-517)
platform armadillo4x0_wm8978.0: Driver armadillo4x0_wm8978 requests probe deferr
al
oprofile: no performance counters
oprofile: using timer interrupt.
nf_conntrack version 0.5.0 (1922 buckets, 7688 max)
TCP: cubic registered
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
sit: IPv6 over IPv4 tunneling driver
registered taskstats version 1
eSDHC1 Vcc: incomplete constraints, leaving on
regulator-dummy: incomplete constraints, leaving on
red
al
input: gpio-keys as /devices/platform/gpio-keys/input/input0
red
input: imx_adc_ts as /devices/virtual/input/input1
i.MX ADC input touchscreen loaded.
mmc1: queuing unknown CIS tuple 0x10 (5 bytes)
al
red
al
rtc-s35390a 1-0030: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
ALSA device list:
No soundcards found.
RAMDISK: Loading 19803KiB [1 disk] into ram disk... |
mmc1: new high speed SDIO card at address 3988
VFS: Mounted root (ext2 filesystem) on device 1:0.
devtmpfs: mounted
Freeing unused kernel memory: 172K (c05ec000 - c0617000)
Mounting proc: done
Starting fsck for root filesystem.
fsck 1.25 (20-Sep-2001)
/dev/ram0: clean, 1212/1464 files, 17968/19803 blocks
Checking root filesystem: done
Remounting root rw: done
Mounting sysfs: done
Mounting tmpfs on /run: done
Cleaning up system: done
Running local start scripts.
Checking config region: done
Loading /etc/config: done
Starting udevd:udevd[1207]: starting version 175
done
Synthesizing the initial hotplug events:done
awl13: RX Transmission mode SDINT HT
mmc1: registerd "awl13" device as awlan0
red
awl13: Version 3.0.2 Load.
al
Changing file permissions: done
Configure /home/ftp: done
Mounting devpts: done
Starting syslogd: done
Starting klogd: done
Loading kernel module: awl13_sdio
Starting basic firewall: awl13: WID=0x5, STATUS CODE=0x0
awl13: disconnected!
awl13: device ready!
awl13: MAC is 00:1d:12:cf:22:01
awl13: WID=0x5, STATUS CODE=0x1
done
Setting hostname: done
Configuring network interfaces: IPv6: ADDRCONF(NETDEV_UP): eth0: link is not rea
dy
udhcpc (v1.20.2) started
Sending discover...
libphy: imx25-fec-1:00 - Link is Up - 100/Full
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Sending discover...
Sending select for 172.16.1.131...
Lease of 192.0.2.100 obtained, lease time 85875
done
Starting inetd: done
Setting at-cgi: done
Starting lighttpd: done
Creating avahi.services: done
Starting avahi.daemon: random: avahi-daemon urandom read with 64 bits of entropy
available
done
Mounting ramfs /home/ftp/pub: done
Running local start script (/etc/config/rc.local).
Starting functester: done
atmark-dist v1.54.0 (AtmarkTechno/Armadillo-420.WLAN-AWL13)
Linux 3.14.36-at10 [armv5tejl arch]
armadillo420-0 login:
