第10章 Boot Modes and Bootloader Functions
This chapter explains about the boot modes on the Armadillo and also about the boot configuration functions of Hermit-At, the default bootloader.
JP1 can be used to select between the on-board flash memory boot mode and the UART boot mode on Armadillo-440. In the on-board flash memory boot mode, the bootloader stored in the bootloader region of flash memory is booted. The UART boot mode is used for system restore when, for example, the bootloader stored in flash memory has been damaged. For more information, refer to "Restoring Bootloader to Factory State" in the "Armadillo-400 Series Software Manual."
10.1. Boot Mode Selection
Boot mode selection is determined by the configuration of JP2. Each boot mode is detailed in 表10.1「Boot Mode」.
表10.1 Boot Mode
Mode | JP2 | Description |
Auto-boot | Open | The Linux kernel is automatically booted after power on. |
Maintenance | Short | The Hermit-At command prompt that can be used for changing configuration is started. |
10.2. Linux Kernel Boot Option Configuration
Various settings including console and root filesystem settings can be changed by specifying the appropriate Linux kernel boot options. The following details some options typically used with Armadillo.
The setenv function of Hermit-At is used for this configuration. Parameters set with setenv are saved to flash memory and remain in effect even after rebooting.
The clearenv command is used to clear any set parameters.
10.2.1. Console Configuration
To change the output console of the boot log, set the console parameter as shown below.
For the effects on logging for each setting, refer to 表10.2「Console Configuration Effect On Output Destination」.
表10.2 Console Configuration Effect On Output Destination
Console Option | Boot Log Output Destination | Maintenance Mode Prompt Destination[] |
ttymxc1 | CON3 (Serial Interface 1) | CON3 (Serial Interface 1) |
ttymxc2 | CON9 (Serial Interface 2) | CON9 (Serial Interface 2) |
ttymxc4 | CON9 (Serial Interface 3) | CON9 (Serial Interface 3) |
null | None | CON3 (Serial Interface 1) |
Other (tty1 etc) | The specified console[] | CON3 (Serial Interface 1) |
If the kernel console is set with setenv, this configuration is also carried over to the Hermit-At console. For example, if the kernel console is set to ttymxc2, the Hermit-At console will also change to ttymxc2 from the next boot. |
10.2.2. Specifying Image File To Boot
On the Armadillo-440, in addition to on-board flash memory it is also possible to boot an image file from storage or a tftp server. For more information, refer to "Kernel and Userland Placement" in the "Armadillo-400 Series Software Manual."
10.2.3. Other Boot Options
There are a large number of options available aside from those introduced here. For more information refer to a book on the Linux kernel or the documentation included in the Linux kernel source code (kernel-source/Documentation/kernel-parameters.txt
10.2.4. Boot Option Configuration Examples
10.3. Note On Bootloader Versions
When a bootloader image based on hermit-at v2.0.0 source (loader-armadillo4x0-v2.0.0.bin etc) and a kernel image based on linux-2.6.26-at7 source (linux-a400-1.00.bin.gz etc) are used on Armadillo-440 Rev.C1 or later boards (S/N 100201-2195 or greater), a problem exists where the kernel may not boot. This problem only occurs with the above combination.
On Armadillo-440 Rev.C1 or later boards (S/N 100201-2195 and greater), please use a bootloader image based on hermit-at v2.0.1 or later source (loader-armadillo4x0-v2.0.1.bin or later).[]
