Thank you for purchasing the Armadillo-440 LCD Model Development Set.
The Armadillo-440 LCD Model Development Set is comprised of the Armadillo-440 which as a CPU board provides the core functionality, and the Armadillo-440 LCD Expansion Board which incorporates LCD, touch screen and audio functionality.
The Armadillo-440 is a small form factor general purpose CPU board which along with the Freescale ARM9 processor "i.MX257", LPDDR SDRAM and flash memory, also incorporates interfaces which are often required for embedded devices, such as serial, LAN, USB 2.0, microSD and GPIO. Armadillo-440 keeps pin compatibility with the existing Armadillo-220 model while at the same time also offering improved performance and even lower power consumption.
The Armadillo-440 LCD Expansion Board is designed to be connected to the Armadillo-440 and incorporates the functionality required to create a touch screen computer, including LCD and touch screen interfaces, audio in and out and button input. As the circuit diagrams for the Armadillo-440 LCD Expansion board have been made available, it is possible to quickly meet various hardware requirements when developing a panel computer by using Armadillo-440 as is and just customizing the expansion board.
Linux is employed as the standard operating system on Armadillo-440, providing access to a rich array of software resources. It is also possible to create and run original programs with C and other programming languages. For information on how to customize software, please refer to the "Armadillo-400 Series Software Manual."
This document contains precautions for use and explanations on how to use the software functionality available in the default state as at time of purchase. On obtaining the Armadillo-440 LCD Model Development Set, please check the operation of all hardware and the use of the default software.
The product name "Armadillo" will be used in descriptions that apply to the whole Armadillo Series for the remainder of this document.
1.1. Who Should Read This Document
We hope that this document will prove to be useful to others as well.
This document describes the basic usage of Armadillo.
The main areas covered are listed below.
1.3. Typographical Conventions
Fonts are used in the following ways in this document.
表1.1 Fonts
Font Example | Description |
Plain text font | Used for standard text |
[PC ~]$ ls | Shell prompt and user input text |
text | Text that is either displayed, is to be edited, or is a comment |
1.3.2. Command Entry Examples
The command entry examples in this document all have an assumed execution environment which is reflected in the displayed prompt. The directory part “/
” will differ depending on the current directory. The home directory of each user is represented by “~
表1.2 Relationship Between Prompt and Execution Environment
Prompt | Command Execution Environment |
[PC /]# | To be executed by a privileged user on the work PC |
[PC /]$ | To be executed by a general user on the work PC |
[armadillo /]# | To be executed by a privileged user on Armadillo |
[armadillo /]$ | To be executed by a general user on Armadillo |
hermit> | To be executed on Armadillo in maintenance mode |
Commands that may change or vary depending on the relevant environment are written as shown below. Please adjust the commands as necessary.
表1.3 Abbreviations Used In Command Entry Examples
Notation | Description |
[version] | File version number |
Icons are used in the following way in this document.
This is used for precautions. |
This is used for helpful information. |
The software used on Armadillo is composed from Free Software / Open Source Software. This Free Software / Open Source Software is the result of efforts from developers from all over the world. We would like to take this opportunity to express our gratitude.
In order to use this product safely, please take special note of the following precaution.
This product uses semiconductor components designed for generic electronics equipment such as office automation equipment, communications equipment, measurement equipment and machine tools. Do not incorporate the product into devices such as medical equipment, traffic control systems, combustion control systems, safety equipment and so on which can directly threaten human life or pose a hazard to the body or property due to malfunction or failure. Moreover, products incorporating semiconductor components can be caused to malfunction or fail due to foreign noise or surge. To ensure there will be no risk to life, the body or property even in the event of malfunction or failure, be sure to take all possible measures in safety system design, such as using protection circuits like limit switches or fuse breakers, or system redundancy. |
1.6. Handling Precautions
Please pay attention to the following points when handling the product in order to avoid causing any irreversible damage.
- Areas Easily Damaged
The microSD connector and its cover and the connectors of the flat cable connecting Armadillo-440 and the LCD Expansion Board can be easily damaged. Please be careful not to damage them by handling them with too much force.
- Modifications To This Product
Please take note that any modifications[] made to this product are not covered under warranty. Also, please ensure to undertake a full operational check of this product before carrying out any modifications or mounting connectors[].
- Mounting and Dismounting of Connectors While Powered On
Apart from hot-pluggable interfaces (LAN, USB, Mic, Headphone), do not under any circumstances add or remove connectors while power is supplied to this product or peripheral circuits.
- Static Electricity
As CMOS devices are used in this product, please store it in antistatic packaging (such as that it was shipped in) until time of use.
- Latchup
Excessive noise or a surge from the power supply or input/output, or sharp voltage fluctuations can lead to the CMOS devices incorporated in the board causing a latch-up. Once the latch-up occurs, this situation continues until the power supply is disconnected, and therefore can damage the devices. Measures such as adding a protection circuit to noise-susceptible input/output lines or not sharing the power supply with devices that can be the cause of noise are highly recommended.
- Physical Stress
Please avoid strong physical stress such as drops or other impacts.
1.7. Software Usage Precautions
- About Software Contained In This Product
The software and documentation contained in this product is provided “AS IS” without warranty of any kind including warranty of merchantability or fitness for a particular purpose, reliability, correctness or accuracy. Furthermore, no guarantee is made in regard to any outcomes resulting from the use of this product.
Armadillo is a registered trademark of Atmark Techno, Inc. All other company names, product names and related trademarks are the property of their respective owners.
