Hermit-At v1.1.7 (Armadillo-300/eth) compiled at 18:08:48, Dec 28 2006
Uncompressing kernel...........................................................
...............................................done.
Uncompressing ramdisk...........................................................
......................................................done.
Doing console=ttyAM0,115200
Linux version 2.6.12.5-at1 (build@debian) (gcc version 3.4.4 20050314 (prereleas
e) (Debian 3.4.3-13)) #1 Fri Dec 29 00:31:52 JST 2006
CPU: ARM926EJ-Sid(wb) [41069264] revision 4 (ARMv5TEJ)
CPU0: D VIVT write-back cache
CPU0: I cache: 8192 bytes, associativity 4, 32 byte lines, 64 sets
CPU0: D cache: 4096 bytes, associativity 4, 32 byte lines, 32 sets
Machine: ARMADILLO300
ATAG_INITRD is deprecated; please update your bootloader.
NS9750 Rev. 1, running at 199 MHz
Built 1 zonelists
Kernel command line: console=ttyAM0,115200
PID hash table entries: 512 (order: 9, 8192 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 64MB = 64MB total
Memory: 55168KB available (2904K code, 484K data, 100K init)
checking if image is initramfs...it isn't (bad gzip magic numbers); looks like a
n initrd
Freeing initrd memory: 6144K
PCI: bus0: Fast back to back transfers enabled
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
i2c_ns: I2C ns9750 driver $Revision: 1.5 $ initializing
i2c-at24cxx: i2c at24cxx eeprom driver, (C) 2003-2005 Atmark Techno, Inc.
NetWinder Floating Point Emulator V0.97 (double precision)
Initializing Cryptographic API
gpio: Armadillo-3x0 GPIO driver, (C) 2005 Atmark Techno, Inc.
led: Armadillo-3x0 LED driver, (C) 2006 Atmark Techno, Inc.
NS9xx0 Watchdog initialized
Serial: NS9xx0 driver $Revision: 1.6 $
ttyAM0 at MMIO 0xf9200040 (irq = 36) is a NS9xx0
ttyAM1 at MMIO 0xf9200000 (irq = 34) is a NS9xx0
io scheduler noop registered
io scheduler anticipatory registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
loop: loaded (max 8 devices)
NS9750 ethernet driver.
ns9750_eth: PHY (0x13, 0x78e2) = LXT971A/972A detected at 0x0
ath_pci: 0.9.4.5 (svn r1865)
PCI: enabling device 0000:00:01.0 (0340 -> 0342)
CountryCode: 0x188
wifi0: 11a rates: 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbps
wifi0: 11b rates: 1Mbps 2Mbps 5.5Mbps 11Mbps
wifi0: 11g rates: 1Mbps 2Mbps 5.5Mbps 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36
Mbps 48Mbps 54Mbps
wifi0: turboA rates: 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbps
wifi0: turboG rates: 6Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbps
wifi0: H/W encryption support: WEP AES AES_CCM TKIP
wifi0: mac 10.5 phy 6.1 radio 6.3
wifi0: Use hw queue 1 for WME_AC_BE traffic
wifi0: Use hw queue 0 for WME_AC_BK traffic
wifi0: Use hw queue 2 for WME_AC_VI traffic
wifi0: Use hw queue 3 for WME_AC_VO traffic
wifi0: Use hw queue 8 for CAB traffic
wifi0: Use hw queue 9 for beacons
unable to load wlan_scan_sta
wifi0: Atheros 5212: mem=0x80000000, irq=10
ath_hal: 0.9.18.0 (AR5210, AR5211, AR5212, RF5111, RF5112, RF2413, RF5413, REGOP
S_FUNC)
wlan: 0.8.4.2 (svn r1865)
wlan: mac acl policy registered
ath_rate_sample: 1.2 (svn r1865)
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
armadillo3x0-nor: Found 1 x16 devices at 0x0 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
armadillo3x0-nor: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
armadillo3x0-nor: use default partitions(5)
Creating 5 MTD partitions on "armadillo3x0-nor":
0x00000000-0x00002000 : "ipl"
0x00002000-0x00010000 : "bootloader"
0x00010000-0x00210000 : "kernel"
0x00210000-0x007f0000 : "userland"
0x007f0000-0x00800000 : "config"
ns9750-ohci ns9750-ohci.0: NS9750 OHCI
ns9750-ohci ns9750-ohci.0: new USB bus registered, assigned bus number 1
ns9750-ohci ns9750-ohci.0: irq 75, io base 0xf9100000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
usbcore: registered new driver usb-storage
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.01:USB HID core driver
pegasus: v0.6.12 (2005/01/13), Pegasus/Pegasus II USB Ethernet driver
usbcore: registered new driver pegasus
mice: PS/2 mouse device common for all mice
i2c-s3531a: Device Type [S-353x0A]
i2c-s3531a: i2c S-3531A/S-353X0A driver, (C) 2001-2005 Atmark Techno, Inc.
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
IPv4 over IPv4 tunneling driver
ip_tables: (C) 2000-2002 Netfilter core team
NET: Registered protocol family 10
Disabled Privacy Extensions on device c0328874(lo)
IPv6 over IPv4 tunneling driver
ip6_tables: (C) 2000-2002 Netfilter core team
Bridge firewalling registered
SCTP: Hash tables configured (established 2048 bind 4096)
RAMDISK: Loading 6144KiB [1 disk] into ram disk... done.
VFS: Mounted root (ext2 filesystem).
Freeing init memory: 100K
init started: BusyBox v1.00 (2006.12.28-15:33+0000) multi-call binary
Starting fsck for root filesystem.
fsck 1.25 (20-Sep-2001)
ext2fs_check_if_mount: No such file or directory while determining whether /dev/
ram0 is mounted.
/dev/ram0: clean, 679/1024 files, 5508/6144 blocks
Checking root filesystem: done
Remounting root rw: done
Mounting proc: done
Mounting usbfs: done
Mounting sysfs: done
Cleaning up system: done
Running local start scripts.
Changing file permissions: done
Starting syslogd: done
Starting klogd: done
Loading /etc/config: done
Starting basic firewall: done
Setting hostname: done
Configuring network interfaces: info, udhcpc (v0.9.9-pre) started
debug, Sending discover...
debug, Sending select for 192.168.10.206...
info, Lease of 192.168.10.206 obtained, lease time 600
done
Starting inetd: done
generate rsa1 key ... done
generate dsa key ... done
generate rsa key ... done
Stating sshd: done
Starting thttpd: done
atmark-dist v1.8.0 (AtmarkTechno/Armadillo-300)
Linux 2.6.12.5-at1 [armv5tejl arch]
armadillo300 login:
