Hermit-At v4.1.0 (Armadillo-EVA 1500) compiled at 13:55:20, Oct 21 2014
mmcsd: SD card at address 0x00000001
mmcsd: M8G1GC 1048576KiB
gendisk: /dev/mmcblk0p1: start=0x00000010, size=0x00b2d070
gendisk: Image.bin is found. (6694660 Bytes)
Copying kernel...done.
Uncompressing fdt.done.
Doing console=ttySC3,115200
Doing mem=768M
Doing noinitrd
Doing rootwait
Doing root=/dev/mmcblk0p1
Initializing cgroup subsys cpuset
Linux version 3.4.81-ae1500-at2 (atmark@atde5) (gcc version 4.6.3 (Debian 4.6.3-
14atmark1) ) #1 SMP PREEMPT Mon Oct 27 18:11:13 JST 2014
CPU: ARMv7 Processor [413fc0f2] revision 2 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
Machine: armadilloeva1500, model: Armadillo-EVA 1500
cma: CMA: reserved 128 MiB at 66000000
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 7 pages/cpu @c0cc9000 s6144 r8192 d14336 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 195072
Kernel command line: console=ttySC3,115200 mem=768M noinitrd rootwait root=/dev/
mmcblk0p1
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
allocated 1572864 bytes of page_cgroup
please try 'cgroup_disable=memory' option if you don't want memory cgroups
Memory: 768MB = 768MB total
Memory: 639612k/639612k available, 146820k reserved, 8192K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc05f3000 (6060 kB)
.init : 0xc05f3000 - 0xc0624800 ( 198 kB)
.data : 0xc0626000 - 0xc066a6e0 ( 274 kB)
.bss : 0xc066a704 - 0xc06c1444 ( 348 kB)
NR_IRQS:16 nr_irqs:16 16
Architected local timer running at 10.00MHz (virt).
Switching to timer-based delay loop
sched_clock: ARM arch timer >56 bits at 10000kHz, resolution 100ns
sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
Calibrating delay loop (skipped), value calculated using timer frequency.. 20.00
BogoMIPS (lpj=100000)
Initializing cgroup subsys cpuacct
Initializing cgroup subsys memory
Initializing cgroup subsys devices
Initializing cgroup subsys freezer
Initializing cgroup subsys blkio
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
Setting up static identity map for 0x40463dd0 - 0x40463e28
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (40.00 BogoMIPS).
devtmpfs: initialized
dummy:
sh-pfc pfc-r8a7791: r8a77910_pfc support registered
renesas_irqc renesas_irqc.0: driving 10 irqs
hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 8 bytes.
bio: create slab <bio-0> at 0
gpio_rcar gpio_rcar.0: driving 32 GPIOs
gpio_rcar gpio_rcar.1: driving 32 GPIOs
gpio_rcar gpio_rcar.2: driving 32 GPIOs
gpio_rcar gpio_rcar.3: driving 32 GPIOs
gpio_rcar gpio_rcar.4: driving 32 GPIOs
gpio_rcar gpio_rcar.5: driving 32 GPIOs
gpio_rcar gpio_rcar.6: driving 32 GPIOs
gpio_rcar gpio_rcar.7: driving 32 GPIOs
pwm-rcar pwm-rcar.0: registering PWM0
pwm-rcar pwm-rcar.1: registering PWM1
pwm-rcar pwm-rcar.2: registering PWM2
pwm-rcar pwm-rcar.3: registering PWM3
pwm-rcar pwm-rcar.4: registering PWM4
pwm-rcar pwm-rcar.5: registering PWM5
pwm-rcar pwm-rcar.6: registering PWM6
SCSI subsystem initialized
i2c-gpio i2c-gpio.7: using pins 238 (SDA) and 237 (SCL)
i2c-gpio i2c-gpio.8: using pins 240 (SDA) and 239 (SCL)
i2c-gpio i2c-gpio.9: using pins 71 (SDA) and 70 (SCL)
i2c-sh_mobile i2c-sh_mobile.6: I2C adapter 6 with bus speed 100000 Hz (L/H=32/2b
Linux media interface: v0.10
vgaarb: loaded
sh_cmt sh_cmt.0: used for clock events
Advanced Linux Sound Architecture Driver Version 1.0.25.
Switching to clocksource arch_sys_counter
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
audit: initializing netlink socket (disabled)
type=2000 audit(0.170:1): initialized
highmem bounce pool size: 64 pages
VFS: Disk quotas dquot_6.5.2
nfs4filelayout_init: NFSv4 File Layout Driver Registering...
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 1489
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
io scheduler noop registered
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
SuperH (H)SCI(F) driver initialized
sh-sci.0: ttySC0 at MMIO 0xe6c40000 (irq = 176) is a scifa
sh-sci.1: ttySC1 at MMIO 0xe6c50000 (irq = 177) is a scifa
sh-sci.2: ttySC2 at MMIO 0xe6c20000 (irq = 180) is a scifb
sh-sci.3: ttySC3 at MMIO 0xe6c30000 (irq = 181) is a scifb
console [ttySC3] enabled
sh-sci.4: ttySC4 at MMIO 0xe6ce0000 (irq = 182) is a scifb
sh-sci.5: ttySC5 at MMIO 0xe6c60000 (irq = 183) is a scifa
sh-sci.6: ttySC6 at MMIO 0xe6e60000 (irq = 184) is a scif
sh-sci.7: ttySC7 at MMIO 0xe6e68000 (irq = 185) is a scif
sh-sci.8: ttySC8 at MMIO 0xe62c0000 (irq = 186) is a hscif
sh-sci.9: ttySC9 at MMIO 0xe62c8000 (irq = 187) is a hscif
sh-sci.10: ttySC10 at MMIO 0xe6e58000 (irq = 54) is a scif
sh-sci.11: ttySC11 at MMIO 0xe6ea8000 (irq = 55) is a scif
sh-sci.12: ttySC12 at MMIO 0xe6ee0000 (irq = 56) is a scif
sh-sci.13: ttySC13 at MMIO 0xe6ee8000 (irq = 57) is a scif
sh-sci.14: ttySC14 at MMIO 0xe6c70000 (irq = 61) is a scifa
sh-sci.15: ttySC15 at MMIO 0xe6c78000 (irq = 62) is a scifa
sh-sci.16: ttySC16 at MMIO 0xe6c80000 (irq = 63) is a scifa
sh-sci.17: ttySC17 at MMIO 0xe62d0000 (irq = 53) is a hscif
scsi0 : sata_rcar
ata1: SATA max UDMA/133 irq 137
scsi1 : sata_rcar
ata2: SATA max UDMA/133 irq 138
m25p80 spi0.0: n25q064 (8192 Kbytes)
Creating 4 MTD partitions on "m25p80":
0x000000000000-0x000000010000 : "ipl"
0x000000010000-0x000000090000 : "bootloader"
0x000000090000-0x0000000d0000 : "fdt"
0x0000000d0000-0x000000800000 : "firmware"
qspi qspi.0: probed
spi_sh_msiof spi_sh_msiof.1: master is unqueued, this is deprecated
spi_sh_msiof spi_sh_msiof.2: master is unqueued, this is deprecated
spi_sh_msiof spi_sh_msiof.3: master is unqueued, this is deprecated
sh_mii: probed
Base address at 0xee700000, 00:11:0c:1a:00:00, IRQ 194.
ehci-platform ehci-platform.0: Generic Platform EHCI Controller
ehci-platform ehci-platform.0: new USB bus registered, assigned bus number 1
ehci-platform ehci-platform.0: irq 140, io mem 0xee081000
ehci-platform ehci-platform.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ehci-platform ehci-platform.1: Generic Platform EHCI Controller
ehci-platform ehci-platform.1: new USB bus registered, assigned bus number 2
ehci-platform ehci-platform.1: irq 145, io mem 0xee0c1000
ehci-platform ehci-platform.1: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-platform ohci-platform.0: Generic Platform OHCI Controller
ohci-platform ohci-platform.0: new USB bus registered, assigned bus number 3
ohci-platform ohci-platform.0: irq 140, io mem 0xee080000
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
ohci-platform ohci-platform.1: Generic Platform OHCI Controller
ohci-platform ohci-platform.1: new USB bus registered, assigned bus number 4
ohci-platform ohci-platform.1: irq 145, io mem 0xee0c0000
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
xhci-hcd xhci-hcd.0: xHCI Host Controller
xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 5
xhci-hcd xhci-hcd.0: irq 133, io mem 0xee000000
ata1: link resume succeeded after 1 retries
hub 5-0:1.0: USB hub found
ata2: link resume succeeded after 1 retries
hub 5-0:1.0: 1 port detected
xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 6
hub 6-0:1.0: USB hub found
hub 6-0:1.0: 1 port detected
input: st1232-touchscreen as /devices/platform/i2c-gpio.9/i2c-9/9-0055/input/inp
ut0
rtc-s35390a 7-0030: rtc core: registered rtc-s35390a as rtc0
i2c /dev entries driver
i2c-rcar i2c-rcar_h2.0: probed
i2c-rcar i2c-rcar_h2.1: probed
i2c-rcar i2c-rcar_h2.2: probed
i2c-rcar i2c-rcar_h2.3: probed
i2c-rcar i2c-rcar_h2.4: probed
i2c-rcar i2c-rcar_h2.5: probed
lirc_dev: IR Remote Control driver registered, major 250
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
ata1: SATA link down (SStatus 0 SControl 300)
IR RC5 (streamzap) protocol handler initialized
IR SANYO protocol handler initialized
ata2: SATA link down (SStatus 0 SControl 300)
IR MCE Keyboard/mouse protocol handler initialized
IR LIRC bridge handler initialized
i2c-core: driver [adv7180] using legacy suspend method
i2c-core: driver [adv7180] using legacy resume method
soc-camera-pdrv soc-camera-pdrv.2: Probing soc-camera-pdrv.2
vin vin.2: VIN Unit driver attached to camera 0
adv7180 8-0020: chip found @ 0x40 (i2c-gpio8)
vin vin.2: VIN Unit driver detached from camera 0
uvcvideo: Unable to create debugfs directory
MMNGR: CO from 0x78000000 to 0x7fffffff
MMNGR: MXSAAR0(0x00780080)
vspm (Oct 27 2014 18:09:47) driver installed
fdpm (Oct 27 2014 18:09:45) driver for M2 installed
[drm] Initialized drm 1.1.0 20060810
Console: switching to colour frame buffer device 240x67
rcar-du rcar-du-r8a7791: fb0: frame buffer device
rcar-du rcar-du-r8a7791: registered panic notifier
[drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[drm] No driver support for vblank timestamp query.
[drm] Initialized rcar-du 1.0.0 20130110 on minor 0
PVR_K: SGX use system memory.
pvrsrvkm pvrsrvkm: start latency exceeded, new value 5700 ns
dc_linuxfb - Found usable fbdev device ():
range (physical) = 0x66100000-0x678bb000
size (bytes) = 0x17bb000
xres x yres = 1920x1080
xres x yres (v) = 1920x3240
img pix fmt = 20
num buffers = 3
rcar_thermal rcar_thermal: 1 sensor proved
device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
sh_mmcif sh_mmcif.0: driver version 2010-04-28
mmc0: new high speed MMC card at address 0001
mmcblk0: mmc0:0001 M8G1GC 7.28 GiB
mmcblk0boot0: mmc0:0001 M8G1GC partition 1 4.00 MiB
mmcblk0boot1: mmc0:0001 M8G1GC partition 2 4.00 MiB
mmcblk0: p1 p2
mmcblk0boot1: unknown partition table
mmcblk0boot0: unknown partition table
sh_mobile_sdhi sh_mobile_sdhi.0: mmc1 base at 0xee100000 clock rate 0 MHz
sh_mobile_sdhi sh_mobile_sdhi.1: mmc2 base at 0xee140000 clock rate 0 MHz
usbhid: USB HID core driver
cs42l52 8-004a: Cirrus Logic CS42L52, Revision: 03
input: CS42L52 Beep Generator as /devices/platform/i2c-gpio.8/i2c-8/8-004a/input
/input1
asoc: cs42l52 <-> scu-ssi-dai mapping ok
TCP: cubic registered
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
input: gpio-keys as /devices/platform/gpio-keys/input/input2
rtc-s35390a 7-0030: setting system clock to 2000-01-01 01:18:20 UTC (946689500)
ALSA device list:
#0: armadilloeva1500-cs42l52
kjournald starting. Commit interval 5 seconds
EXT3-fs (mmcblk0p1): mounted filesystem with ordered data mode
VFS: Mounted root (ext3 filesystem) readonly on device 179:1.
devtmpfs: mounted
Freeing init memory: 196K
INIT: version 2.88 booting
[info] Using makefile-style concurrent boot in runlevel S.
[....] Starting the hotplug events dispatcher: udevdudevd[996]: starting version
175
. ok
[....] Synthesizing the initial hotplug events...done.
[....] Waiting for /dev to be fully populated...vin vin.2: VIN Unit driver attac
hed to camera 0
adv7180 8-0020: Not detect any video input signal
[....] Activating swap...done.
[....] Checking root file system...fsck from util-linux 2.20.1
/dev/mmcblk0p1: clean, 30086/732960 files, 201350/1464846 blocks
EXT3-fs (mmcblk0p1): using internal journal
[....] Cleaning up temporary files... /tmp. ok
[info] Loading kernel module loop.
libkmod: ERROR ../libkmod/libkmod.c:554 kmod_search_moddep: could not open modde
p file '/lib/modules/3.4.81-ae1500-at2/modules.dep.bin'
[....] Activating lvm and md swap...done.
[....] Checking file systems...fsck from util-linux 2.20.1
[....] Mounting local filesystems...done.
[....] Activating swapfile swap...done.
[....] Cleaning up temporary files.... ok
[....] Setting kernel variables ...done.
[....] Configuring network interfaces...done.
[....] Starting rpcbind daemon...rpcbind: cannot create socket for udp6
rpcbind: cannot create socket for tcp6
. ok
[....] Starting NFS common utilities: statd idmapd. ok
[....] Setting up ALSA...done.
[....] Setting up X socket directories... /tmp/.X11-unix /tmp/.ICE-unix. ok
INIT: Entering runlevel: 2
[info] Using makefile-style concurrent boot in runlevel 2.
[....] Starting rpcbind daemon...[....] Already running.. ok
[....] Starting enhanced syslogd: rsyslogd. ok
[....] Starting deferred execution scheduler: atd. ok
[....] Starting periodic command scheduler: cron. ok
[....] Starting system message bus: dbus. ok
[....] Starting MTA: exim4. ok
ALERT: exim paniclog /var/log/exim4/paniclog has non-zero size, mail system poss
ibly broken
Debian GNU/Linux 7 debian ttySC3
debian login:
