The following provides details on the Armadillo-400 Series RTC Option Module hardware.
The RTC Option Module is a board that connects to Expansion Interface 2 (CON14)[] on the Armadillo-400 Series. The board incorporates a Seiko Instruments Inc. real-time clock. An electric double-layer capacitor provides backup power to the real-time clock allowing it to function for a period of time even after power to the board has been cut. It is possible to connect a separate external battery in order to maintain time data during extended periods of no power supply.
The RTC Option Module is included in the Armadillo-420 Basic Model Development Set and is also available for sale separately.
The main specifications of the RTC Option Module are as follows.
表9.1 RTC Option Module Specifications
Calendar Clock | S-35390A (Seiko Instruments Inc.) [] |
Backup |
EECEN0F204RK (Panasonic) mounted[],
additional battery can be connected to External Backup Connector (CON2)
Board Size | 10.0 x 22.0 mm |
Power Supply Voltage | DC3.3V |
Operating Temperature | -10 - 60℃ (with no condensation) |
表9.2 RTC Option Module Interface Details
Part Number | Interface | Shape | Notes |
CON1 | Armadillo-400 Series Connector | 4 pin (2.54 mm pitch) | |
CON2 | External Backup Connector[] | DF13-2P-1.25DSA (Hirose Electric Co.) | Supported battery: CR2032WK11 (Hitachi Maxell or similar) |
9.3. Board Outline Diagrams
| Round head screw (M2, L=6mm, spring washer + small washer) |
| RTC Option Module |
| Flat washer |
| Metal spacer (M2, L=11mm, D=4mm) |
| Armadillo-420, Armadillo-440 |
