VSCode の左ペインの [G4/X2] から [Atmark Container New Project] を実行し、
任意のプロジェクト名を入力してエンターキーを押してください。ここでは、
ホームディレクトリ直下に my_project として保存しています。
その場合、意図しない解像度で描画されることがあります。
set_restart always
起床要因として利用可能なデバイスは次の通りです。 -
python から ONNX Runtime を使う
TensorFlow Lite をインストールする
python から TensorFlow Lite を使う
6.8.6.6. Rest API : コンテナ操作
6.8.6.7. Rest API : ネットワーク設定
{"name":"Wired connection 1","state":"activated","uuid":"18d241f1-946c-3325-974f-65cda3e6eea5","ctype":"802-3-ethernet","device":"eth0","props":{"802-3-ethernet.accept-all-mac-addresses":"-1","802-3-ethernet.auto-negotiate":"no","802-3-ethernet.cloned-mac-address":"","802-3-ethernet.duplex":"","802-3-ethernet.generate-mac-address-mask":"","802-3-ethernet.mac-address":"","802-3-ethernet.mac-address-blacklist":"","802-3-ethernet.mtu":"auto","802-3-ethernet.port":"","802-3-ethernet.s390-nettype":"","802-3-ethernet.s390-options":"","802-3-ethernet.s390-subchannels":"","802-3-ethernet.speed":"0","802-3-ethernet.wake-on-lan":"default","802-3-ethernet.wake-on-lan-password":"","GENERAL.CON-PATH":"/org/freedesktop/NetworkManager/Settings/1","GENERAL.DBUS-PATH":"/org/freedesktop/NetworkManager/ActiveConnection/6","GENERAL.DEFAULT":"yes","GENERAL.DEFAULT6":"no","GENERAL.DEVICES":"eth0","GENERAL.IP-IFACE":"eth0","GENERAL.MASTER-PATH":"","GENERAL.NAME":"Wired connection 1","GENERAL.SPEC-OBJECT":"","GENERAL.STATE":"activated","GENERAL.UUID":"18d241f1-946c-3325-974f-65cda3e6eea5","GENERAL.VPN":"no","GENERAL.ZONE":"","IP4.ADDRESS[1]":"198.51.100.123/16","IP4.DNS[1]":"192.0.2.1","IP4.DNS[2]":"192.0.2.2","IP4.GATEWAY":"198.51.100.1","IP4.ROUTE[1]":"dst = 198.51.100.0/16, nh = 0.0.0.0, mt = 100","IP4.ROUTE[2]":"dst = 0.0.0.0/0, nh = 198.51.100.1, mt = 100","IP6.ADDRESS[1]":"fe80::211:cff:fe00:b13/64","IP6.GATEWAY":"","IP6.ROUTE[1]":"dst = fe80::/64, nh = ::, mt = 1024","connection.auth-retries":"-1","connection.autoconnect":"yes","connection.autoconnect-priority":"-999","connection.autoconnect-retries":"-1","connection.autoconnect-slaves":"-1","connection.dns-over-tls":"-1","connection.gateway-ping-timeout":"0","connection.id":"Wired connection 1","connection.interface-name":"eth0","connection.lldp":"default","connection.llmnr":"-1","connection.master":"","connection.mdns":"-1","connection.metered":"unknown","connection.mptcp-flags":"0x0","connection.multi-connect":"0","connection.permissions":"","connection.read-only":"no","connection.secondaries":"","connection.slave-type":"","connection.stable-id":"","connection.timestamp":"1703208824","connection.type":"802-3-ethernet","connection.uuid":"18d241f1-946c-3325-974f-65cda3e6eea5","connection.wait-activation-delay":"-1","connection.wait-device-timeout":"-1","connection.zone":"","ipv4.addresses":"198.51.100.123/16","ipv4.auto-route-ext-gw":"-1","ipv4.dad-timeout":"-1","ipv4.dhcp-client-id":"","ipv4.dhcp-fqdn":"","ipv4.dhcp-hostname":"","ipv4.dhcp-hostname-flags":"0x0","ipv4.dhcp-iaid":"","ipv4.dhcp-reject-servers":"","ipv4.dhcp-send-hostname":"yes","ipv4.dhcp-timeout":"0","ipv4.dhcp-vendor-class-identifier":"","ipv4.dns":"192.0.2.1,192.0.2.2","ipv4.dns-options":"","ipv4.dns-priority":"0","ipv4.dns-search":"","ipv4.gateway":"198.51.100.1","ipv4.ignore-auto-dns":"no","ipv4.ignore-auto-routes":"no","ipv4.link-local":"0","ipv4.may-fail":"yes","ipv4.method":"manual","ipv4.never-default":"no","ipv4.replace-local-rule":"-1","ipv4.required-timeout":"-1","ipv4.route-metric":"-1","ipv4.route-table":"0","ipv4.routes":"","ipv4.routing-rules":"","ipv6.addr-gen-mode":"eui64","ipv6.addresses":"","ipv6.auto-route-ext-gw":"-1","ipv6.dhcp-duid":"","ipv6.dhcp-hostname":"","ipv6.dhcp-hostname-flags":"0x0","ipv6.dhcp-iaid":"","ipv6.dhcp-send-hostname":"yes","ipv6.dhcp-timeout":"0","ipv6.dns":"","ipv6.dns-options":"","ipv6.dns-priority":"0","ipv6.dns-search":"","ipv6.gateway":"","ipv6.ignore-auto-dns":"no","ipv6.ignore-auto-routes":"no","ipv6.ip6-privacy":"-1","ipv6.may-fail":"yes","ipv6.method":"auto","ipv6.mtu":"auto","ipv6.never-default":"no","ipv6.ra-timeout":"0","ipv6.replace-local-rule":"-1","ipv6.required-timeout":"-1","ipv6.route-metric":"-1","ipv6.route-table":"0","ipv6.routes":"","ipv6.routing-rules":"","ipv6.token":"","proxy.browser-only":"no","proxy.method":"none","proxy.pac-script":"","proxy.pac-url":""}}
必要制限: NetworkView
必要制限: NetworkAdmin
必要制限: NetworkAdmin
クライアントの接続の削除は DELETE "/api/connections/\{connection}" で行えます。 |
必要制限: NetworkAdmin
6.8.6.9. Rest API : WWAN の設定
必要制限: NetworkAdmin
必要制限: NetworkAdmin
6.8.6.10. Rest API : DHCP の設定
必要制限: NetworkView
必要制限: NetworkAdmin
必要制限: NetworkAdmin
6.8.6.11. Rest API : NAT の設定
必要制限: NetworkView
必要制限: NetworkAdmin
必要制限: NetworkAdmin
必要制限: NetworkView
必要制限: NetworkAdmin
必要制限: NetworkAdmin
6.8.6.12. Rest API : 時刻の設定-
必要制限: Custom
図6.108「ABOSDE で ローカルネットワーク上の Armadillo をスキャンする」 の赤枠で囲まれているボタンをクリックすることで、ローカルネットワーク上で ABOS Web が動作している Armadillo をスキャンすることができます。
そのため、ABOSDE では 図6.109「ABOSDE の ABOS Web パスワード入力画面」 のように ABOS Web のパスワードを求められますので、設定したパスワードを入力してください。 6.9.2. Armadillo のコンテナの情報を取得するローカルネットワーク上の Armadillo をスキャンした後に、
図6.111「ABOSDE で Armadillo のコンテナ情報を取得」 の赤枠で囲まれているボタンをクリックすることで、選択した Armadillo のコンテナの情報を取得できます。
図6.115「ABOSDE で Armadillo に SWU をインストール」 の赤枠で囲まれているボタンをクリックすることで、選択した Armadillo に SWU をインストールすることができます。
図6.120「ライブラリバージョンの確認」によるバージョン確認方法は、ライブラリイメージのバージョンが2.2.0以降の場合のみ可能です。
/opt/firmware を渡すコンテナコンフィグの例
動画コーデック: H.264/AVC, VP8, VP9
画像フォーマット: JPEG, PNG, BMP
ストリーミング: http, rtp
デコード可能なコーデック
エンコード可能なコーデック
デコーダーが対応しているフォーマット
エンコーダが対応しているフォーマット
Config1: +/-13 (planned)
Config2: +/-21
Config3: +/-29 (planned)
Config4: +/-45 (planned)
Config5: +/-61 (planned)
Intra PU: 16x16 / 8x8 / 4x4
Inter PU: 16x16 / 8x16 / 16x8
TU: 4x4 and 8x8 transforms
コンテナイメージを想定しています。
動画ファイルを選択することができます。
右側には認識した物体のラベルとスコアが表示されます。
2回目以降の起動では 5 秒程度で映像が表示されます。
図6.156「nmcli のコマンド書式」に nmcli の書式を示します。このことから、 nmcli は「オブジェクト (OBJECT) というものが存在し、
コネクションの作成と同様に persist_file コマンドで永続化する必要があります。 DHCP に設定する例を、図6.166「DHCP の設定」に示します。 ![[注記]](images/note.png) | |
一つのパーティションで構成されている microSD カードのパーティションを、2つに分割する例を図6.175「fdiskコマンドによるパーティション変更」に示します。
これにより Armadillo 動作中の温度の変化が可視化され、得られる情報が見やすくなります。 図6.186「Armadillo-IoT ゲートウェイ G4で取得した温度のグラフ」は Armadillo-IoT ゲートウェイ G4上で一定期間 atmark-thermal-profiler を実行して取得した thermal_profile.csv を Google スプレッドシートでグラフ化したものです。
以下の例では、Armadillo Base OS を更新した後に起動できないカーネルをインストールして、起動できなかったためにロールバックされました。 6.20. Armadillo 起動時にコンテナの外でスクリプトを実行する起動時に何かスクリプトを走らせるためにはコンテナとして実行することを推奨します。 「コンテナ起動設定ファイルを作成する」 を参照してください。 コンテナで実行不可能な場合に、「local」サービスを使うことができます: /etc/local.d ディレクトリに
2: eMMC
ブートディスクイメージをビルドします
baseos-x2-[VERSION].img -
ブートディスク上のLinuxカーネルを起動します。
ブートローダーのビルドに必要なパッケージのインストール
Armadillo-X2 ブートローダー から
sld_header_off 0x58000
sld_csf_off 0x59020
への同意を求められます。
Armadillo-X2では、
Linuxカーネルのビルドに必要なパッケージのインストール
Armadillo-X2 Linuxカーネル から
│ │ [*] Support DMA zone │ │
ルートファイルシステムを構築することができるツールです。
Armadillo-X2 開発用ツール から
ax2ディレクトリ以下のファイルを変更することで、
キャッシュアーカイブもダウンロードして、
6.23.4. ビルドしたルートファイルシステムの SBOM を作成するここでは例として、「Alpine Linux ルートファイルシステムをビルドする」 で作成した OS_update.swu の SBOM を作成します。
の各ソフトウェアダウンロードページからダウンロードすることができます。 eMMC は主に NAND Flash メモリから構成されるデバイスです。NAND Flash メモリには書き込みしてから1年から3年程度の長期間データが読み出されないと電荷が抜けてしまう可能性があります。その際、電荷が抜けて正しくデータが読めない場合は、eMMC 内部で ECC (Error Correcting Code) を利用してデータを訂正します。しかし、訂正ができないほどにデータが化けてしまう場合もあります。そのため、一度書いてから長期間利用しない、高温の環境で利用するなどのケースでは、データ保持期間内に電荷の補充が必要になります。電荷の補充にはデータの読み出し処理を実行し、このデータの読み出し処理をデータリテンションと呼びます。 Armadillo-X2 に搭載のeMMCには長期間データが読み出されない状態であっても、データリテンションを自動的に行う機能を搭載しています。 データリテンションは /etc/conf.d/micron-emmc-reten というファイルに書かれた設定、use_system_time によって以下の 2 通りの挙動を示します。 表6.26 データリテンションの挙動 /etc/conf.d/micron-emmc-reten | initiating condition |
これで設定は完了しました。 以下は挙動ごとのシステム概略図です。 use_system_time を有効にした場合のデータリテンションの動作例を以下に示します。 6.24.2. より詳しくデータリテンションの統計情報を確認するにはMicron Technology が提供する emmcparm というツールを使うことで、データリテンションの統計情報を確認することができます。統計情報として eMMC 内部に保存されているのは実行回数、最終実行完了時のカウンター値、現在のデータリテンション処理の進捗があります。
emmcparm をダウンロードする
マニュアル作成時点では 5.0.0 を利用しました |
パッケージを展開する
SSR を取得する
| Secure Smart Report |
リセット後に毎回実行する
eMMC コントローラは、バスの稼動状態を監視する
Armadillo でのセルフリフレッシュ機能搭載 eMMC への設定は以下のとおりです。 表6.27 Armadillo のデータリテンションの設定 setting | value | description |
6.25. Linuxカーネルがクラッシュしたときにメモリの状態を保存するArmadilloはLinuxカーネルがクラッシュすると、ウォッチドッグタイマーによってシステムリセットが発生し、再起動します。 このとき、再起動によってメモリの内容が失われてしまうため、デバッグが困難になる場合があります。 ここでは Kdump を利用してLinuxカーネルがクラッシュしたときにメモリの状態(vmcore)を保存し、vmcoreを解析する方法を紹介します。 ここでは、Kdumpの実行環境を構築する手順を紹介します。
Linuxカーネルの準備
ビルド済みのapkパッケージを利用する場合
Linuxカーネルをビルドする場合
パッケージのインストール
サービスの設定以外は同じ手順で実行できます。 |
設定ファイルの編集
kexec_args=/boot/Image
変更した場合、ファイルを永続化します。
kdumpサービスの有効化
kdumpサービスの自動起動を有効にします。
Linuxカーネル起動時パラメータの指定
[ 19.390426] Bye!
kdump |
kdump |
kdump |
kdump |
dmesg dump
vmlinuxの準備
ビルドしたLinuxカーネルが動作している場合
crashコマンドの準備
vmcoreの確認
このパーティションの障害チェックはシステム起動時に自動的に実行されます。 6.26.5. /var/log/ 配下のログに関して表6.28「/var/log/ 配下のログ」 に Armadillo-X2 で /var/log/ 配下に出力するログを示します。 最大ファイルサイズを超えると 表6.28「/var/log/ 配下のログ」 の「ファイル名」の 2 行目に記載されたファイル名にコピーします。 その状態から更に最大ファイルサイズを超えた場合、 表6.28「/var/log/ 配下のログ」 の「ファイル名」の 2 行目に記載されたファイル名に上書きします。 表6.28 /var/log/ 配下のログ ファイル名 | 説明 | 最大ファイルサイズ | 最大ファイル数 |
文字を入力するにはコマンドモードから入力モードへ移行する必要があります。コマンドモードから入力モードに移行するには、表6.29「入力モードに移行するコマンド」に示すコマンドを入力します。入力モードへ移行後は、キーを入力すればそのまま文字が入力されます。 表6.29 入力モードに移行するコマンド コマンド | 動作 |
「i」、「a」それぞれのコマンドを入力した場合の文字入力の開始位置を図6.198「入力モードに移行するコマンドの説明」に示します。 入力モードからコマンドモードに戻りたい場合は、ESCキーを入力することで戻ることができます。現在のモードが分からなくなった場合は、ESCキーを入力し、一旦コマンドモードへ戻ることにより混乱を防げます。 ![[警告]](images/warning.png) | |
方向キーでカーソルの移動ができますが、コマンドモードで表6.30「カーソルの移動コマンド」に示すコマンドを入力することでもカーソルを移動することができます。 表6.30 カーソルの移動コマンド コマンド | 動作 |
ファイルの保存、終了を行うコマンドを表6.32「保存・終了コマンド」に示します。 表6.32 保存・終了コマンド コマンド | 動作 |
保存と終了を行うコマンドは「 : 」(コロン)からはじまるコマンドを使用します。" : "キーを入力すると画面下部にカーソルが移り入力したコマンドが表示されます。コマンドを入力した後Enterキーを押すことで、コマンドが実行されます。 本章では、Armadillo-X2のオプション品について説明します。 表6.33 Armadillo-X2関連のオプション品 6.28.1. Armadillo-X2 オプションケース(金属製)Armadillo-X2用のアルミ製ケースです。
基板を収めた状態で、DCジャック、LAN、USBx2、HDMI、USBコンソール、スイッチ、LEDにアクセスすることが可能となっています。 表6.34 Armadillo-X2 オプションケースセット(金属製)について 製品名 | Armadillo-X2 オプションケースセット(金属製) | 型番 | OP-CASEX2-MET-00 | セット内容 | アルミケース、ケースネジ×2、Armadillo-X2固定用ネジ×4 |
表6.35 Armadillo-X2 オプションケース(金属製)の仕様 ![[警告]](images/warning.png) | |
他コネクタの面位置より少し後ろに配置しているため、
ケース固定用のM3のねじ穴を2つ用意しています。
6.28.2. Armadillo-X2、G4 ケースモデル VESA規格固定用プレートArmadillo-X2、G4 ケースモデル VESA規格固定用プレートはVESA規格(100 × 100mm)に対応したテレビやモニターなどに
Armadillo-X2およびArmadillo-IoT ゲートウェイ G4のケースモデルを取り付けるための製品です。 表6.36 Armadillo-X2、G4 ケースモデル VESA規格固定用プレートについて 製品名 | Armadillo-X2、G4 ケースモデル VESA規格固定用プレート | 型番 | OP-CASEX2-VESA-00 | セット内容 | VESA規格固定用プレート、ケース固定用ねじ×2、プレート固定用ねじ×4 |
表6.37 Armadillo-X2、G4 ケースモデル VESA規格固定用プレートの仕様 色 | 黒 | 材質 | 鉄 | 寸法 | 120 × 123 mm | 板厚 | 2 mm |
バインド小ねじ(M4、L=10mm) × 4
