第11章 Interface Specifications
The following explains the interface specifications of Armadillo-IoT.
11.1. Interface Layout
Armadillo-IoT Interface Layout (Side A)Whether they are mounted or not depends on the product model.
図11.1 Armadillo-IoT Interface Layout (Side A)[17]
表11.1 Armadillo-IoT Interface List (Side A)[18]
Part NumberInterface NameProduct NumberMaker
CON1Add-on Interface 1DF17(4.0)-60DS-0.5V(57)HIROSE ELECTRIC
CON2Add-on Interface 2DF17(4.0)-60DS-0.5V(57)HIROSE ELECTRIC
CON6LAN Interface9771-8813-S3L6T1SUN JUN ELECTRONICS
CON7USB Host InterfaceUBA-4R-D14T-4D(LF)(SN)J.S.T. Mfg.
CON10WWAN Expansion InterfaceDF12(3.0)-30DP-0.5V(86)HIROSE ELECTRIC
CON11MicroSIM InterfaceCIM-J78MITSUMI
CON13RTC Backup Interface 1SMTU1220-LFRenata SA
CON14Power Input Interface 1PJ-102AHCUI
CON15Power Input Interface 2S02B-PASK-2(LF)(SN)J.S.T. Mfg.
CON16Power Output InterfaceB02B-PASK(LF)(SN)J.S.T. Mfg.
CON173G/LTE Antenna Interface1U.FL-R-SMT-1HIROSE ELECTRIC
CON183G/LTE Antenna Interface2U.FL-R-SMT-1HIROSE ELECTRIC
CON20WLAN InterfaceMM60-52B1-E1-R650Japan Aviation Electronics Industry
CON22RTC Backup Interface 2DF13C-2P-1.25V (21)HIROSE ELECTRIC
SW1User Switch 1SKHHLRA010ALPS ELECTRIC
SW2User Switch 2SKHHLRA010ALPS ELECTRIC
SW3User Switch 3SKHHLRA010ALPS ELECTRIC
SW4Reset SwitchSKHHLUA010ALPS ELECTRIC
JP1Boot Device Configuration JumperA2-2PA-2.54DSA(71)HIROSE ELECTRIC
TH3Stud for Add-on ModuleKRB-2008Hirosugi-Keiki
TH5
TH8
TH10
TH12
TH14
TH20Stud for WWAN ModuleTH-1.6-3.0-M2Mac-Eight
TH26
SP1Stud for Wireless LAN ModuleNT4R1600Japan Aviation Electronics Industry
SP2
[18] Whether they are mounted or not depends on the product model.
The is no guarantee that the parts installed have the part numbers shown in 表11.1「Armadillo-IoT Interface List (Side A)」. Please check the parts specifications and change history table which can be downloaded from the Atmark Techno Users' site for the parts on your product.
Interface Layout (Side B)
図11.2 Interface Layout (Side B)
表11.2 Armadillo-IoT Interface List (Side B)
CON4SD InterfaceDM1B-DSF-PEJ(82)HIROSE ELECTRIC
CON9Debug Serial InterfaceDF13A-7P-1.25H(51)HIROSE ELECTRIC
LED1WWAN LEDSML-A12P8TROHM
LED2User LED2SML-A12P8TROHM
LED3User LED1SML-A12P8TROHM
LED4User LED3SML-A12P8TROHM
LED5User LED4SML-A12P8TROHM
The is no guarantee that the parts installed have the part numbers shown in 表11.2「Armadillo-IoT Interface List (Side B)」. Please check the parts specifications and change history table which can be downloaded from the Atmark Techno Users' site for the parts on your product.
11.2. CON1 Add-on Interface 1
CON1 is an expansion interface. It connects to signal lines of the i.MX7 Dual which offer multiple functions (multiplexing), and functions such as USB, UART, SPI, I2C, SD, CAN, PWM and GPIO can be interfaced to.
Mounted Connector
DF17(4.0)-60DS-0.5V(57)/HIROSE ELECTRIC
Matching Connector Example
DF17(4.0)-60DP-0.5V(57)/HIROSE ELECTRIC
Allowable Current
0.3A (per one terminal)
表11.3 CON1 Signals
Pin NumberPin NameI/ODescription
1GNDPowerPower (GND)
2GNDPowerPower (GND)
3GPIO3_IO0In/Out
Expansion I/O, connected to LCD_CLK pin of i.MX7 Dual
Shared connection with pin 41 of CON2
4GPIO3_IO1In/Out
Expansion I/O, connected to LCD_ENABLE pin of i.MX7 Dual
Shared connection with pin 40 of CON2
5GPIO3_IO2In/Out
Expansion I/O, connected to LCD_HSYNC pin of i.MX7 Dual
Shared connection with pin 39 of CON2
6GPIO3_IO3In/Out
Expansion I/O, connected to LCD_VSYNC pin of i.MX7 Dual
Shared connection with pin 38 of CON2
7GPIO4_IO2In/Out
Expansion I/O, connected to UART2_RXD pin of i.MX7 Dual
Shared connection with pin 32 of CON2
8GPIO4_IO3In/Out
Expansion I/O, connected to UART2_TXD pin of i.MX7 Dual
Shared connection with pin 34 of CON2
9GPIO4_IO4In/Out
Expansion I/O, connected to UART3_RXD pin of i.MX7 Dual
Shared connection with pin 36 of CON2
10GPIO4_IO5In/Out
Expansion I/O, connected to UART3_TXD pin of i.MX7 Dual
Shared connection with pin 37 of CON2
11GPIO4_IO6In/Out
Expansion I/O, connected to UART3_RTS pin of i.MX7 Dual
Shared connection with pin 35 of CON2
12GPIO4_IO7In/Out
Expansion I/O, connected to UART3_CTS pin of i.MX7 Dual
Shared connection with pin 50 of CON2
13GPIO4_IO10In/Out
Expansion I/O, connected to I2C2_SCL pin of i.MX7 Dual
Shared connection with pin 24 of CON2
14GPIO4_IO11In/Out
Expansion I/O, connected to I2C2_SDA pin of i.MX7 Dual
Shared connection with pin 25 of CON2
15GPIO5_IO11In/Out
Expansion I/O, connected to SD2_RESET_B pin of i.MX7 Dual
Shared connection with pin 33 of CON2
16GPIO6_IO19In/Out
Expansion I/O, connected to SAI2_TXFS pin of i.MX7 Dual
Shared connection with pin 46 of CON2
17GPIO6_IO20In/Out
Expansion I/O, connected to SAI2_TXC pin of i.MX7 Dual
Shared connection with pin 47 of CON2
18GPIO6_IO22In/Out
Expansion I/O, connected to SAI2_TXD pin of i.MX7 Dual
Shared connection with pin 49 of CON2
19GPIO6_IO21In/Out
Expansion I/O, connected to SAI2_RXD pin of i.MX7 Dual
Shared connection with pin 48 of CON2
20GPIO4_IO8In/Out
Expansion I/O, connected to I2C1_SCL pin of i.MX7 Dual
Shared connection with pin 20 of CON2
21GPIO4_IO9In/Out
Expansion I/O, connected to I2C1_SDA pin of i.MX7 Dual
Shared connection with pin 21 of CON2
22GPIO4_IO12In/Out
Expansion I/O, connected to I2C3_SCL pin of i.MX7 Dual
Shared connection with pin 42 of CON2
23GPIO4_IO13In/Out
Expansion I/O, connected to I2C3_SDA pin of i.MX7 Dual
Shared connection with pin 43 of CON2
24GPIO3_IO25In/OutExpansion I/O, connected to LCD_DATA20 pin of i.MX7 Dual
25GPIO3_IO26In/OutExpansion I/O, connected to LCD_DATA21 pin of i.MX7 Dual
26GNDPowerPower (GND)
27GNDPowerPower (GND)
28VCC_3.3V_IOPowerPower (VCC_3.3V_IO)
29VCC_3.3VPowerPower (VCC_3.3V)
30VCC_5VPowerPower (VCC_5V)
31DETECT_CON1OutConnected to GND with 1kΩ resistor
32GPIO7_IO12In/OutExpansion I/O, connected to ENET1_TX_CLK pin of i.MX7 Dual
33GPIO7_IO13In/OutExpansion I/O, connected to ENET1_RX_CLK pin of i.MX7 Dual
34GPIO7_IO7In/OutExpansion I/O, connected to ENET1_TD1 pin of i.MX7 Dual
35GPIO7_IO2In/OutExpansion I/O, connected to ENET1_RD2 pin of i.MX7 Dual
36GPIO7_IO8In/OutExpansion I/O, connected to ENET1_TD2 pin of i.MX7 Dual
37GPIO7_IO3In/OutExpansion I/O, connected to ENET1_RD3 pin of i.MX7 Dual
38GPIO7_IO0In/OutExpansion I/O, connected to ENET1_RD0 pin of i.MX7 Dual
39GPIO7_IO1In/OutExpansion I/O, connected to ENET1_RD1 pin of i.MX7 Dual
40GPIO4_IO1In/OutExpansion I/O, connected to UART1_TXD pin of i.MX7 Dual
41GPIO4_IO0In/OutExpansion I/O, connected to UART1_RXD pin of i.MX7 Dual
42GPIO7_IO4In/OutExpansion I/O, connected to ENET1_RX_CTL pin of i.MX7 Dual
43GPIO7_IO5In/OutExpansion I/O, connected to ENET1_RXC pin of i.MX7 Dual
44GPIO7_IO6In/OutExpansion I/O, connected to ENET1_TD0 pin of i.MX7 Dual
45GPIO7_IO10In/OutExpansion I/O, connected to ENET1_TX_CTL pin of i.MX7 Dual
46GPIO7_IO11In/OutExpansion I/O, connected to ENET1_TXC pin of i.MX7 Dual
47GPIO5_IO12In/OutExpansion I/O, connected to SD2_CLK pin of i.MX7 Dual
48GPIO5_IO13In/OutExpansion I/O, connected to SD2_CMD pin of i.MX7 Dual
49GPIO5_IO14In/OutExpansion I/O, connected to SD2_DATA0 pin of i.MX7 Dual
50GPIO7_IO9In/OutExpansion I/O, connected to ENET1_TD3 pin of i.MX7 Dual
51GPIO5_IO15In/OutExpansion I/O, connected to SD2_DATA1 pin of i.MX7 Dual
52GPIO5_IO16In/OutExpansion I/O, connected to SD2_DATA2 pin of i.MX7 Dual
53GPIO5_IO17In/OutExpansion I/O, connected to SD2_DATA3 pin of i.MX7 Dual
54GNDPowerPower (GND)
55PMIC_ONOFFInThe power management IC on/off signal. Please input an open drain (or open collector) signal.
56CON1_USB_VBUSPowerPower (CON1_USB_VBUS)
57CON1_USB_VBUSPowerPower (CON1_USB_VBUS)
58GNDPowerPower (GND)
59CON1_USB_HS_DPIn/OutCON1_USB plus side signal, connected to USB_OTG2_DP pin of i.MX7 Dual
60CON1_USB_HS_DMIn/OutCON1_USB minus side signal, connected to USB_OTG2_DN pin of i.MX7 Dual
There are a number of add-on modules available which can be connected.
There are many signals which connect to both CON1 and CON2. Please be careful of possible signal conflicts when designing an expansion board.
11.3. CON2 Add-on Interface 2
CON2 is an expansion interface. It connects to signal lines of the i.MX7 Dual which offer multiple functions (multiplexing), and functions such as USB, UART, SPI, I2C, and GPIO can be interfaced to.
Mounted Connector
Allowable Current
表11.4 CON2 Signals
3NC-Not Connected
4NC-Not Connected
5NC-Not Connected
6NC-Not Connected
7NC-Not Connected
8NC-Not Connected
9NC-Not Connected
10NC-Not Connected
11NC-Not Connected
12NC-Not Connected
13NC-Not Connected
14NC-Not Connected
15NC-Not Connected
16NC-Not Connected
17NC-Not Connected
18NC-Not Connected
19NC-Not Connected
20GPIO4_IO8In/Out
Shared connection with pin 20 of CON1
21GPIO4_IO9In/Out
Shared connection with pin 21 of CON1
22NC-Not Connected
23NC-Not Connected
24GPIO4_IO10In/Out
Shared connection with pin 13 of CON1
25GPIO4_IO11In/Out
Shared connection with pin 14 of CON1
31DETECT_CON2OutConnected to VCC_3.3 V_IO with 1kΩ resistor
32GPIO4_IO2In/Out
Shared connection with pin 7 of CON1
33GPIO5_IO11In/Out
Shared connection with pin 15 of CON1
34GPIO4_IO2In/Out
Shared connection with pin 8 of CON1
35GPIO4_IO6In/Out
Shared connection with pin 11 of CON1
36GPIO4_IO4In/Out
Shared connection with pin 9 of CON1
37GPIO4_IO5In/Out
Shared connection with pin 10 of CON1
38GPIO3_IO3In/Out
Shared connection with pin 6 of CON1
39GPIO3_IO2In/Out
Shared connection with pin 5 of CON1
40GPIO3_IO1In/Out
Shared connection with pin 4 of CON1
41GPIO3_IO0In/Out
Shared connection with pin 3 of CON1
42GPIO4_IO12In/Out
Shared connection with pin 22 of CON1
43GPIO4_IO13In/Out
Shared connection with pin 23 of CON1
44NC-Not Connected
45NC-Not Connected
46GPIO6_IO19In/Out
Shared connection with pin 16 of CON1
47GPIO6_IO20In/Out
Shared connection with pin 17 of CON1
48GPIO6_IO21In/Out
Shared connection with pin 19 of CON1
49GPIO6_IO22In/Out
Shared connection with pin 18 of CON1
50GPIO4_IO7In/Out
Shared connection with pin 12 of CON1
51NC-Not Connected
52NC-Not Connected
53NC-Not Connected
56CON2_USB_VBUSPowerPower (CON2_USB_VBUS)
57CON2_USB_VBUSPowerPower (CON2_USB_VBUS)
59CON2_USB_HS_DPIn/OutCON2_USB plus side signal, connected to i.MX7 Dual USB HSIC controller via USB HUB controller (port 1)
60CON2_USB_HS_DMIn/OutCON2_USB minus side signal, connected to i.MX7 Dual USB HSIC controller via USB HUB controller (port 1)
11.4. CON4 SD Interface
CON 4 is an SD interface compatible with UHS-I (SDR104, maximum clock frequency: 196.36MHz). The SD signal lines are connected to the SD/MMC controller (uSDHC1) on the i.MX7 Dual.
The power (SD_VDD) supplied to the SD card can be controlled with the SD1_RESET_B pin of the i.MX7 Dual. Power is supplied during high level output and power is turned off with low level output.
Mounted Connector
DM1B-DSF-PEJ(82)/HIROSE ELECTRIC
表11.5 CON4 Signals
1SD_DAT3In/OutSD data bus (bit 3), connected to SD1_DATA3 pin of i.MX7 Dual
2SD_CMDIn/OutSD command / response, connected to SD1_CMD pin of i.MX7 Dual
3GNDPowerPower (GND)
4SD_VDDPowerPower (SD_VDD)
5CLKOutSD clock, connected to SD1_CLK pin of i.MX7 Dual
7SD_DAT0In/OutSD data bus (bit 0), connected to SD1_DATA0 pin of i.MX7 Dual
8SD_DAT1In/OutSD data bus (bit 1), connected to SD1_DATA1 pin of i.MX7 Dual
9SD_DAT2In/OutSD data bus (bit 2), connected to SD1_DATA2 pin of i.MX7 Dual
表11.6 CON4 Card Detection and Write Protect Detection
ItemDescription
Card detection
Connected to SD1_CD_B pin of i.MX7 Dual
(Low: card inserted, High: card removed)
Write protect detection
Connected to SD1_WP pin of i.MX7 Dual
(Low: write enabled, High: write disabled)
Please do not apply excessive external force to the connector as it may cause it to break or be damaged.
11.5. CON6 LAN Interface
CON6 is a LAN interface compatible with 10BASE-T / 100BASE-TX / 1000BASE-T. Ethernet cables of category 5e or higher can be connected. AUTO-MDIX is supported, automatically detecting a straight cable or crossover cable and switching the transmission / reception terminals as necessary.
The signal lines are connected to the Ethernet MAC (ENET2) of the i.MX7 Dual via the Ethernet PHY (VSC8501XML-03/Microsemi).
Mounted Connector
表11.7 CON6 Signals (10BASE-T/100BASE-TX)
1TX+In/OutTransmit data +
2TX-In/OutTransmit data -
3RX+In/OutReceive data +
4--
5--
6RX-In/OutReceive data -
7--
8--
表11.8 CON6 Signals (1000BASE-T)
1TRD0+In/OutTransmit / receive data 0 +
2TRD0-In/OutTransmit / receive data 0 -
3TRD1+In/OutTransmit / receive data 1 +
4TRD2+In/OutTransmit / receive data 2 +
5TRD2-In/OutTransmit / receive data 2 -
6TRD1-In/OutTransmit / receive data 1 -
7TRD3+In/OutTransmit / receive data 3 +
8TRD3-In/OutTransmit / receive data 3 -
表11.9 LAN Connector LEDs
NameStatusDescription
LINK_ACTIVITY_LEDOffLink not established
On (yellow)Link established
Blinking (yellow)Link established and transmitting / receiving data
SPEED_LEDOffConnected at 10Mbps
On (green)Connected at 100Mbps
On (amber)Connected at 1000Mbps
11.6. CON7 USB Host Interface
CON7 is a USB 2.0 host interface. The signal lines are connected to the USB controller (OTG1) on the i.MX7 Dual.
The power (CON7_USB_VBUS) supplied to the USB device can be controlled with the I2C4_SDA (GPIO4_IO15) pin of the i.MX7 Dual. Power is supplied with a high level output and power is turned off with a low level output.
Data Transmission Mode
・High Speed (480Mbps)
・Full Speed (12Mbps)
・Low Speed (1.5Mbps)
Mounted Connector
UBA-4R-D14T-4D/J.S.T. Mfg.
表11.10 CON7 Signals
1CON7_USB_VBUSPowerPower (CON7_USB_VBUS)
2CON7_USB_HS_DMIn/OutUSB minus side signal, connected to USB_OTG1_DN pin of i.MX7 Dual
3CON7_USB_HS_DPIn/OutUSB plus side signal, connected to USB_OTG1_DP pin of i.MX7 Dual
11.7. CON9 Debug Serial Interface
CON9 is a serial interface for debugging. It is connected to the UART controller (UART5) on the i.MX7 Dual.
Pin 6 of CON6 is connected to the GPIO1_09 pin of the i.MX7 Dual. Maintenance mode is entered on a low level input and operating system auto boot mode on a high level input.
Mounted Connector
DF13A-7P-1.25H(51)/HIROSE ELECTRIC
DF13-7S-1.25C/HIROSE ELECTRIC (Housing)
DF13-2630SCFA/HIROSE ELECTRIC (Contact)
Signal Level
3.3V CMOS
Allowable Current
1A (per terminal)
表11.11 CON9 Signals
1DEBUG_UART_RXDInData receive, connected to GPIO1_IO06 pin of i.MX7 Dual
3DEBUG_UART_TXDOutData transmit, connected to GPIO1_IO07 pin of i.MX7 Dual
4VCC_3.3VPowerPower (VCC_3.3V)
5DEBUG_UART_CTSInClear To Send, connected to GPIO1_IO05 pin of i.MX7 Dual
6BOOTLOADER_EN_BIn
Boot mode setting, connected to GPIO1_IO09 pin of i.MX7 Dual
(Low: Maintenance mode, High: Operating system auto boot mode)
7DEBUG_UART_RTSOutRequest To Send, connected to GPIO1_IO04 pin of i.MX 7 Dual
11.8. CON10 WWAN Expansion Interface
CON 10 is a WWAN expansion interface.
The USB signal lines are connected to the USB HSIC controller via the USB HUB controller (port 2), and the UART signal lines are connected to the UART controller (UART7) of the i.MX7 Dual.
Mounted Connector
DF12(3.0)-30DP-0.5V(86)/HIROSE ELECTRIC
DF12(3.0)-30DS-0.5V(86)/HIROSE ELECTRIC
Allowable Current
表11.12 CON10 Signals
5GNDPowerPower (GND)
8--Reserved
9LED1_CTRL[a]InLED1 control, connected to LED1 (Low: off, High: on)
10GPIO4_IO19In/OutGeneral-purpose I/O, connected to ECSPI1_SS0 pin of i.MX7 Dual
11GPIO4_IO16In/OutGeneral-purpose I/O, connected to ECSPI1_SCLK pin of i.MX7 Dual
12WWAN_UART_RTSOutRequest To Send, connected to ECSPI2_SS0 pin of i.MX 7 Dual
13WWAN_UART_CTSInClear To Send, connected to ECSPI2_MISO pin of i.MX7 Dual
14WWAN_UART_TXDOutData transmit, connected to ECSPI2_MOSI pin of i.MX7 Dual
15WWAN_UART_RXDInData receive, connected to ECSPI2_MOSI pin of i.MX7 Dual
16GNDPowerPower (GND)
17WWAN_USB_HS_DMIn/OutWWAN_USB minus side signal, connected to USB HSIC controller of i.MX7 Dual via USB HUB controller (port 2)
18WWAN_USB_HS_DPIn/OutWWAN_USB plus side signal, connected to USB HSIC controller of i.MX7 Dual via USB HUB controller (port 2)
19GNDPowerPower (GND)
20WWAN_PWR_ONOutWWAN module power control, connected to ECSPI1_MOSI pin of i.MX7 Dual
21WWAN_RESETOutWWAN module reset, connected to ECSPI1_MISO pin of i.MX7 Dual
22--Reserved
23VCC_3.3VPowerPower (VCC_3.3V)
24VCC_5VPowerPower (VCC_5V)
25VCC_5VPowerPower (VCC_5V)
26VCC_5VPowerPower (VCC_5V)
27VCC_5VPowerPower (VCC_5V)
28VCC_5VPowerPower (VCC_5V)
29VCC_5VPowerPower (VCC_5V)
[a] LED1_CTRL can also be controlled with +1.8V. For details, refer to 表10.5「WWAN Expansion Interface Pin 9 (LED1_CTRL) Electrical Specifications」.
11.9. CON11 MicroSIM Interface
CON11 is a MicroSIM interface for the 3G/LTE Module.
表11.13 CON11 Signals
2SIM_VCCPowerSIM power, Connecting to 3G/LTE module/SIM interface
3SIM_RSTOutSIM reset, Connecting to 3G/LTE module/SIM interface
4SIM_CLKOutSIM clock, Connecting to 3G/LTE module/SIM interface
5SIM_VPP-Not Connected
6SIM_I/OInSIM data, Connecting to 3G/LTE module/SIM interface
Armadillo-IoT does not support SIM hot-plugging.Please power off the product before inserting or removing the micro SIM card.
At CON11, if you touch SIM card detection switch, the position of the switch can be deflected and the normal operating status can be affected. Please do not touch the switch.
SIM Card Detection Switch
図11.3 SIM Card Detection Switch
11.10. CON13 RTC Backup Interface 1
CON13 is a backup interface for real-time clock functionality. Please use it when you want to retain time data while power is off for an extended period.
Mounted Connector
SMTU1220-LF/Renata SA
Compatible Battery Example
CR1220, BR1220, etc.
表11.14 CON13 Signals
1RTC_BAT1PowerPower supply input for backup of real-time clock
表11.15 Realtime clock accuracy
Product Numberaccuracy
AGX3162Average monthly gap ±60seconds(reference value)
11.11. CON14 Power Input Interface 1
CON14 is a power supply interface. AC adapters with the same polarity mark as shown in 図11.4「AC Adapter Polarity Mark」 may be used.
Mounted Connector
PJ-102AH/CUI
表11.16 CON14 Signals
1VINPowerPower input (VIN)
図11.4 AC Adapter Polarity Mark
When using CON14 do not supply power from CON15 at the same time. It may cause damage.
When using the AC adapter, connect the DC plug of the AC adapter to the Armadillo-IoT first and then plug the AC plug into the outlet.
When using the AC adapter (OP-AC12V5-00) when re-powering, wait at least 3 seconds before turning on the power.
When turning on the power using a power supply unit other than the above AC adapter, please do so with a monotonically increasing supply. Also, when re-powering, make sure to first turn the power off (5V or less for at least 10ms) and then turn it on again.
11.12. CON15 Power Input Interface 2
CON15 is a power supply interface.
Mounted Connector
S02B-PASK-2(LF)(SN)/J.S.T. Mfg.
PAP-02V-S/J.S.T. Mfg. (Housing)
SPHD-001T-P0.5/J.S.T. Mfg. (Contact)
表11.17 CON15 Signals
When using CON15 do not supply power from CON14 at the same time. It may cause damage.
When using this connector to turn on the power supply, please start it with a monotonically increasing supply. Also, when re-powering, make sure to first turn the power off (5V or less for at least 10ms) and then turn it on again.
11.13. CON16 Power Output Interface
CON16 is a power output interface.
Mounted Connector
B02B-PASK(LF)(SN)/J.S.T. Mfg.
表11.18 CON16 Signals
1VOUTPowerPower (VOUT)
11.14. CON17 3G/LTE Antenna Interface1
CON17 is an interface for the 3G/LTE module antenna.
Mounted Connector
U.FL-R-SMT-1/HIROSE ELECTRIC
When connecting the antenna cable to the antenna terminal, please be careful not to apply excessive force it may cause damage.
11.15. CON18 3G/LTE Antenna Interface2
CON18 is an interface for the 3G/LTE module antenna.
Mounted Connector
11.16. CON20 WLAN Interface
CON20 is an interface for the Wireless LAN Module (AEH-AR9462 / VoxMicro).
The PCI Express signal lines are connected to the PCI Express PHY (PCIe_PHY) on the i.MX7 Dual, and the USB signal lines are connected via the USB HUB controller (port 3) to the USB HSIC controller of the i.MX7 Dual.
The power (WLAN_VDD) supplied to the wireless LAN module can be controlled with the ENET1_CRS (GPIO7_IO14) pin on the i.MX7 Dual. Power is supplied with a high level output and power is turned off with a low level output.
Mounted Connector
MM60-52B1-E1-R650/Japan Aviation Electronics Industry
表11.19 CON20 Signals
1--Reserved
2WLAN_VDDPowerPower (WLAN_VDD)
3--Reserved
5BT_DISABLE_LOut
BT enable / disable signal, connected to SAI1_RXFS pin of i.MX7 Dual
(Low: BT disabled, High: BT enabled)
6--Reserved
7CLKREQ_LInReference clock request, connected to SAI1_RXC pin of i.MX7 Dual
8NC-Not Connected
10NC-Not Connected
11REFCLK-OutDifferential reference clock (-), connected to PCIE_REFCLKOUT_N pin of i.MX7 Dual
12NC-Not Connected
13REFCLK+OutDifferential reference clock (+), connected to PCIE_REFCLKOUT_P pin of i.MX7 Dual
14NC-Not Connected
15GNDPowerPower (GND)
16NC-Not Connected
17NC-Not Connected
18GNDPowerPower (GND)
19NC-Not Connected
20W_DISABLE_LOut
Wireless LAN enable / disable signal, connected to SAI1_TXC pin of i.MX7 Dual
(Low: Wireless LAN disabled, High: Wireless LAN enabled)
21GNDPowerPower (GND)
22PERST_LOut
Basic reset signal, connected to SAI1_RXD pin of i.MX7 Dual
(Low: Reset state, High: Reset release)
23PERn0InDifferential receiver (-), connected to PCIE_RX_N pin of i.MX7 Dual
24WLAN_VDDPowerPower (WLAN_VDD)
25PERp0InDifferential receiver (+), connected to PCIE_RX_P pin of i.MX7 Dual
28--Reserved
29GNDPowerPower (GND)
30--Reserved
31PETn0OutDifferential transmitter (-), connected to PCIE_TX_N pin of i.MX7 Dual
32--Reserved
33PETp0OutDifferential transmitter (+), connected to PCIE_TX_P pin of i.MX7 Dual
34GNDPowerPower (GND)
35GNDPowerPower (GND)
36WLAN_USB_HS_DMIn/OutMinus side signal of WLAN_USB, connected to USB HSIC controller on i.MX7 Dual via USB HUB controller (port 3)
37GNDPowerPower (GND)
38WLAN_USB_HS_DPIn/OutPlus side signal of WLAN_USB, connected to USB HSIC controller of i.MX7 Dual via USB HUB controller (port 3)
39WLAN_VDDPowerPower (WLAN_VDD)
40GNDPowerPower (GND)
41WLAN_VDDPowerPower (WLAN_VDD)
42NC-Not Connected
43GNDPowerPower (GND)
44--Reserved
45NC-Not Connected
46--Reserved
47NC-Not Connected
48--Reserved
49NC-Not Connected
50GNDPowerPower (GND)
51NC-Not Connected
52WLAN_VDDPowerPower (WLAN_VDD)
11.17. CON22 RTC Backup Interface 2
CON22 is an external backup interface for real-time clock functionality. Please use it when you want to retain time data while power is off for an extended period.
Mounted Connector
DF13C-2P-1.25V(21)/HIROSE ELECTRIC
DF13-2S-1.25C/HIROSE ELECTRIC (Housing)
DF13-2630SCF/HIROSE ELECTRIC (Contact)
Allowable Current
1A (per terminal)
CR2032 WK11/Hitachi Maxell[19] etc
表11.20 CON22 Signals
1RTC_BAT2PowerReal-time clock external backup power in
表11.21 Realtime clock accuracy
11.18. JP1 Boot Device Setting Jumper
JP1 is the boot device setting jumper.
Mounted Connector
A2-2PA-2.54DSA(71)/HIROSE ELECTRIC
表11.22 JP1 Signals
1VCC_3.3VPowerPower (VCC_3.3V)
2SDBOOT_ENIn
Boot device setting, connected to BOOT_MODE0 pin of i.MX7 Dual
(Low: Boot from board assembled memory)
表11.23 Jumper Function
Part NumberFunctionOperation
JP1Boot device configuration
Open: To start up bootloader of memory module
Short: Runs the bootloader in the SD card inserted in CON4.
11.19. SW1 to SW3 User Switches
SW1, SW2 and SW3 are tactile switches that can be used freely by the user.
表11.24 User Switch Connections
Part NumberDescription
Connected to GPIO1_IO02 pin of i.MX7 Dual, PTB5/IRQ_12 pin of BMIC (On: Low, Off: High)
Connected to LCD_DAT 17 pin of i.MX7 Dual (On: Low, Off: High)
Connected to LCD_DAT18 pin of i.MX7 Dual (On: Low, Off: High)
11.20. SW4 Reset Switch
SW4 is a tact switch for resets.
表11.25 Reset Switch Connections
SW4
External Reset
(On: Reset state, Off: Reset release)
When resetting with SW4, press and hold for more than one second in order to ensure the reset occurs.
11.21. LED1 WWAN LED
LED1 is a surface-mounted green LED indicating the communication status of the 3G/LTE module.
表11.26 WWAN LED Connections
LED1Connected to 3G/LTE module or pin 9 of CON10 (Low: Off、High: On)
表11.27 WWAN LED Status
Product NumberStatusDescription
AGX3162OffPower off status
Blink (200ms ON/1800ms OFF)Network Detecting
Blink (1800ms ON/200ms OFF)Stand-by
Blink (125ms ON/125ms OFF)Connected
11.22. LED2 to LED5 User LEDs
LED2, LED3, LED4 and LED5 are surface mounted green LEDs that can be used freely by the user.
表11.28 User LED Connections
LED2
Connected to LCD_DATA05 pin of i.MX7 Dual (Low: Off、High: On)
Connected to LCD_DATA06 pin of i.MX7 Dual (Low: Off、High: On)
Connected to LCD_DATA07 pin of i.MX7 Dual (Low: Off、High: On)
LED5
Connected to LCD_DATA08 pin of i.MX7 Dual (Low: Off、High: On)
[17] Whether they are mounted or not depends on the product model.
[19] For more information, please contact an Armadillo dealer.
