第10章 Electrical Specifications10.1. Absolute Maximum Ratings表10.1 Absolute Maximum Ratings Item | Symbol | Min. | Max. | Unit | Notes |
Power Supply Voltage | VIN | -0.3 | 26.4 | V | | Input / Output Voltage | VI,VO | -0.3 | OVDD+0.3 | V |
OVDD=VCC_3.3V_IO,VCC_3.3V
@CON1,CON2,CON9,CON10
| -0.3 | 3.63 | V |
USB_HS_DP,USB_HS_DM
@CON1,CON2,CON10
| Operating Temperature Range[][] | Topr | -10 | 50 | ℃ | With no condensation |
Absolute maximum ratings are values that should not be exceeded under any use or test conditions, even just momentarily. Please factor in a margin against these values during use. |
10.2. Recommended Operating Conditions表10.2 Recommended Operating Conditions Item | Symbol | Min. | Typ. | Max. | Unit | Notes |
Power Supply Voltage | VIN | 8 | 12 | 26.4 | V | | Ambient Operating Temperature[] | Ta | -10 | 25 | 50 | ℃ | With no condensation |
When using the standard AC adapter (OP-AC12V2-00) or the wide temperature range AC adapter (OP-AC12V3-00)[] when re-powering, wait at least 3 seconds before turning on the power. When turning on the power using a power supply unit other than the above AC adapter, please do so with a monotonically increasing supply. Also, when re-powering, make sure to first turn the power off (5V or less for at least 10ms) and then turn it on again. |
10.3. Input / Output Interface Electrical Specifications表10.3 Input / Output Interface Power Supply Electrical Specifications Item | Symbol | Min. | Typ. | Max. | Unit | Notes |
CON1_USB_VBUS
CON2_USB_VBUS
| 4.75 | 5 | 5.25 | V | |
VCC_3.3V_IO
| 3.135 | 3.3 | 3.465 | V | |
表10.4 Input / Output Interface Electrical Specifications (OVDD = VCC_3.3V, VCC_3.3V_IO)[] Item | Symbol | Min. | Max. | Unit | Notes |
High-level output voltage | VOH | 0.8xOVDD | OVDD | V | IOH = -1.8mA, -3.6mA, -7.2mA, -10.8mA | Low-level output voltage | VOL | 0 | 0.2×OVDD | V | IOL = 1.8mA, 3.6mA, 7.2mA, 10.8mA | High-level input voltage | VIH | 0.7×OVDD | OVDD+0.3 | V | | Low-level input voltage | VIL | -0.3 | 0.3×OVDD | V | | Input leakage current (no Pull-up/Pull-down) | IIN | -5 | 5 | μA | | Pull-up resistance (5K_PU) | - | 4.8 | 5.3 | kΩ | | Pull-up resistance (47K_PU) | - | 45.8 | 49.8 | kΩ | | Pull-up resistance (100K_PU) | - | 101 | 105 | kΩ | | Pull-up resistance (100K_PD) | - | 101 | 108 | kΩ | |
表10.5 WWAN Expansion Interface Pin 9 (LED1_CTRL) Electrical Specifications Item | Symbol | Min. | Max. | Unit | Notes |
High-level input voltage | VIH | 1.4 | 5.25 | V | | Low-level input voltage | VIL | -0.3 | 0.3 | V | |
10.4. Power Supply Circuit StructureThe structure of the power supply circuit of Armadillo-IoT is as follows. The input voltage from the power input interface 1 (CON 14) or the power input interface 2 (CON 15) is converted to each required voltage by the power supply IC and supplied to the internal circuits and each interface. Please design the connection of any external equipment and power supplies so as not to exceed the maximum output current value of each interface and switching regulator (DC-DC). | |
