この SWU イメージを 「SWU イメージのインストール」 を参照して Armadillo へインストールしてください。 6.2.5.2. Docker ファイルからイメージをビルドするArmadillo-640 コンテナ から
| standby
UART1 (CON9)
USB OTG1 (下段)
USB OTG2 (上段)
6.8.6.6. Rest API : コンテナ操作
6.8.6.7. Rest API : ネットワーク設定
ネットワーク接続一覧
ネットワーク接続詳細取得
{"name":"Wired connection 1","state":"activated","uuid":"18d241f1-946c-3325-974f-65cda3e6eea5","ctype":"802-3-ethernet","device":"eth0","props":{"802-3-ethernet.accept-all-mac-addresses":"-1","802-3-ethernet.auto-negotiate":"no","802-3-ethernet.cloned-mac-address":"","802-3-ethernet.duplex":"","802-3-ethernet.generate-mac-address-mask":"","802-3-ethernet.mac-address":"","802-3-ethernet.mac-address-blacklist":"","802-3-ethernet.mtu":"auto","802-3-ethernet.port":"","802-3-ethernet.s390-nettype":"","802-3-ethernet.s390-options":"","802-3-ethernet.s390-subchannels":"","802-3-ethernet.speed":"0","802-3-ethernet.wake-on-lan":"default","802-3-ethernet.wake-on-lan-password":"","GENERAL.CON-PATH":"/org/freedesktop/NetworkManager/Settings/1","GENERAL.DBUS-PATH":"/org/freedesktop/NetworkManager/ActiveConnection/6","GENERAL.DEFAULT":"yes","GENERAL.DEFAULT6":"no","GENERAL.DEVICES":"eth0","GENERAL.IP-IFACE":"eth0","GENERAL.MASTER-PATH":"","GENERAL.NAME":"Wired connection 1","GENERAL.SPEC-OBJECT":"","GENERAL.STATE":"activated","GENERAL.UUID":"18d241f1-946c-3325-974f-65cda3e6eea5","GENERAL.VPN":"no","GENERAL.ZONE":"","IP4.ADDRESS[1]":"198.51.100.123/16","IP4.DNS[1]":"192.0.2.1","IP4.DNS[2]":"192.0.2.2","IP4.GATEWAY":"198.51.100.1","IP4.ROUTE[1]":"dst = 198.51.100.0/16, nh = 0.0.0.0, mt = 100","IP4.ROUTE[2]":"dst = 0.0.0.0/0, nh = 198.51.100.1, mt = 100","IP6.ADDRESS[1]":"fe80::211:cff:fe00:b13/64","IP6.GATEWAY":"","IP6.ROUTE[1]":"dst = fe80::/64, nh = ::, mt = 1024","connection.auth-retries":"-1","connection.autoconnect":"yes","connection.autoconnect-priority":"-999","connection.autoconnect-retries":"-1","connection.autoconnect-slaves":"-1","connection.dns-over-tls":"-1","connection.gateway-ping-timeout":"0","connection.id":"Wired connection 1","connection.interface-name":"eth0","connection.lldp":"default","connection.llmnr":"-1","connection.master":"","connection.mdns":"-1","connection.metered":"unknown","connection.mptcp-flags":"0x0","connection.multi-connect":"0","connection.permissions":"","connection.read-only":"no","connection.secondaries":"","connection.slave-type":"","connection.stable-id":"","connection.timestamp":"1703208824","connection.type":"802-3-ethernet","connection.uuid":"18d241f1-946c-3325-974f-65cda3e6eea5","connection.wait-activation-delay":"-1","connection.wait-device-timeout":"-1","connection.zone":"","ipv4.addresses":"198.51.100.123/16","ipv4.auto-route-ext-gw":"-1","ipv4.dad-timeout":"-1","ipv4.dhcp-client-id":"","ipv4.dhcp-fqdn":"","ipv4.dhcp-hostname":"","ipv4.dhcp-hostname-flags":"0x0","ipv4.dhcp-iaid":"","ipv4.dhcp-reject-servers":"","ipv4.dhcp-send-hostname":"yes","ipv4.dhcp-timeout":"0","ipv4.dhcp-vendor-class-identifier":"","ipv4.dns":"192.0.2.1,192.0.2.2","ipv4.dns-options":"","ipv4.dns-priority":"0","ipv4.dns-search":"","ipv4.gateway":"198.51.100.1","ipv4.ignore-auto-dns":"no","ipv4.ignore-auto-routes":"no","ipv4.link-local":"0","ipv4.may-fail":"yes","ipv4.method":"manual","ipv4.never-default":"no","ipv4.replace-local-rule":"-1","ipv4.required-timeout":"-1","ipv4.route-metric":"-1","ipv4.route-table":"0","ipv4.routes":"","ipv4.routing-rules":"","ipv6.addr-gen-mode":"eui64","ipv6.addresses":"","ipv6.auto-route-ext-gw":"-1","ipv6.dhcp-duid":"","ipv6.dhcp-hostname":"","ipv6.dhcp-hostname-flags":"0x0","ipv6.dhcp-iaid":"","ipv6.dhcp-send-hostname":"yes","ipv6.dhcp-timeout":"0","ipv6.dns":"","ipv6.dns-options":"","ipv6.dns-priority":"0","ipv6.dns-search":"","ipv6.gateway":"","ipv6.ignore-auto-dns":"no","ipv6.ignore-auto-routes":"no","ipv6.ip6-privacy":"-1","ipv6.may-fail":"yes","ipv6.method":"auto","ipv6.mtu":"auto","ipv6.never-default":"no","ipv6.ra-timeout":"0","ipv6.replace-local-rule":"-1","ipv6.required-timeout":"-1","ipv6.route-metric":"-1","ipv6.route-table":"0","ipv6.routes":"","ipv6.routing-rules":"","ipv6.token":"","proxy.browser-only":"no","proxy.method":"none","proxy.pac-script":"","proxy.pac-url":""}}
ネットワーク接続の変更
6.8.6.8. Rest API : 時刻の設定-
図6.81「ABOSDE で ローカルネットワーク上の Armadillo をスキャンする」 の赤枠で囲まれているボタンをクリックすることで、ローカルネットワーク上で ABOS Web が動作している Armadillo をスキャンすることができます。
そのため、ABOSDE では 図6.82「ABOSDE の ABOS Web パスワード入力画面」 のように ABOS Web のパスワードを求められますので、設定したパスワードを入力してください。 6.9.2. Armadillo のコンテナの情報を取得するローカルネットワーク上の Armadillo をスキャンした後に、
図6.84「ABOSDE で Armadillo のコンテナ情報を取得」 の赤枠で囲まれているボタンをクリックすることで、選択した Armadillo のコンテナの情報を取得できます。
図6.88「ABOSDE で Armadillo に SWU をインストール」 の赤枠で囲まれているボタンをクリックすることで、選択した Armadillo に SWU をインストールすることができます。
図6.91「nmcli のコマンド書式」に nmcli の書式を示します。このことから、 nmcli は「オブジェクト (OBJECT) というものが存在し、
コネクションの作成と同様に persist_file コマンドで永続化する必要があります。 DHCP に設定する例を、図6.101「DHCP の設定」に示します。 ![[注記]](images/note.png) | |
一つのパーティションで構成されている microSD カードのパーティションを、2つに分割する例を図6.110「fdiskコマンドによるパーティション変更」に示します。
これにより Armadillo 動作中の温度の変化が可視化され、得られる情報が見やすくなります。 図6.121「Armadillo-IoT ゲートウェイ G4で取得した温度のグラフ」は Armadillo-IoT ゲートウェイ G4上で一定期間 atmark-thermal-profiler を実行して取得した thermal_profile.csv を Google スプレッドシートでグラフ化したものです。
ブートディスクイメージのビルドします
baseos-640-[VERSION].img -
また、JP1と JP2 を共にジャンパでショートします。
In: mxc_serial
図6.126「デフォルトコンフィギュレーションの適用」に示すコマンドを実行します。
LD u-boot
CAT u-boot-dtb.bin
COPY u-boot.bin
SYM u-boot.sym
CFGCHK u-boot.cfg
Armadillo-640では、
│ │ System Type ---> │ │
│ │ Bus support ---> │ │
a600ディレクトリ以下のファイルを変更することで、
の各ソフトウェアダウンロードページからダウンロードすることができます。 6.21. eMMC の GPP(General Purpose Partition) を利用するGPP に squashfs イメージを書き込み、Armadillo の起動時に自動的にマウントする方法を紹介します。 6.21.1. squashfs イメージを作成するこの作業は ATDE 上で行います。 squashfs-tools パッケージに含まれている mksquashfs コマンドを使用して squashfs イメージを作成します。 6.21.2. squashfs イメージを書き込む以降の作業は Armadillo 上で行います。 「squashfs イメージを作成する」で作成した squashfs イメージを、USB メモリ利用するなどして Armadillo-640 にコピーし、GPP に書き込みます。 ![[警告]](images/warning.png) | |
uboot で wdt による再起動が合った場合にその日付
「i」、「a」それぞれのコマンドを入力した場合の文字入力の開始位置を図6.134「入力モードに移行するコマンドの説明」に示します。 ![[ティップ]](images/tip.png) | |
| ファイルを+file+に指定して保存 | :wq
Chapter 5: Fusemap
Chatper 8: System Boot
i.MX6ULL にはブートモードを決める BOOT_MODE0 と BOOT_MODE1 というピンがあります。 BOOT_MODE0 は GND になっているので必ず 0 になります。BOOT_MODE1 は JP2 に接続されています。 JP2 がショートされていると BOOT_MODE1 は 1 になり Internal Boot モードになります。開放されていると 0 となり、 Boot From Fuses というモードになります。 Internal Bootモードでは、 on-chip boot ROMに書き込まれているコードが実行し、ブート可能なデバイスを検索します。リファレンスマニュアル「8.5 Boot devices (internal boot)」に、i.MX6ULL がブートできるデバイスの一覧が記載されています。Armadillo-640 では、そのうちオンボードeMMC と microSDカードに対応しています。Internal Bootモードでは、GPIO によって eFuseの設定を上書き (override) できるようになっています。つまり eFuse の設定がどうなっていようと、GPIO のピンでブートデバイスを決めることができます。 Boot From Fusesモードでは、単純に言えば GPIO による override が禁止され eFuse に書き込まれた状態でしかブートしません。この機能を有効にすることで、フィールドに出した製品が悪意ある人によって意図していないブートをし、被害が出ることを防ぐことができます。(もちろん、ブート後に root アカウントを乗っ取られるような作りでは、意味がありませんが…) Internal Bootモードでは、GPIO によって eFuseの設定を上書き (override) できるようになってると紹介しましたが、JP1 はまさにこの機能を使っています。 JP1 は LCD1_DATA05 と LCD1_DATA11 の制御をしていますが、これらのピンはそれぞれ BOOT_CFG1[5] と BOOT_CFG2[3] を override しています。「8.3.2 GPIO boot overrides」の 表「8-3. GPIO override contact assignments」を確認してください。 ややこしい事に、この BOOT_CFG で始まる eFUSE は、リファレンスマニュアルの中では eFuse のアドレスでも表記されています。 BOOT_CFG1 は eFuse のアドレスで言うと 0x450 の下位 8 bit つまり 0x450[7:0] であり、 BOOT_CFG2 は上位 8 bit つまり 0x450[15:8] にあたります。これは「5.1 Boot Fusemap」の表「5-5. SD/eSD Boot Fusemap」または表「5-6. MMC/eMMC Boot Fusemap」を確認することでわかります。 さらにややこしい事に、eFuse を書き込む場合にはこれら全ての値が使えず、On-Chip OTP Controller の bank と word の値が必要になります。これらの値は リファレンスマニュアルの「On-Chip OTP Controller」を参照してください。後で出てきますが Boot From Fuses で使用する BT_FUSE_SEL という eFuse のように GPIO による override ができないものもあります。 表6.14 GPIO override と eFuse 信号名 | eFuse名 | eFuseアドレス | OCOTP名 | Bank | Word |
| BOOT_CFG1[5]
| 0x450[5]
| BOOT_CFG2[3]
| 0x450[11]
| 0x460[4]
| OCOTP_CFG5 | 0 | 6 |
Armadillo-640 ではmicroSDカード または eMMC からのブートになるので、ブートデバイスを選択する eFuse BOOT_CFG1[7:4] は、010x または 011x になります。 リファレンスマニュアル「8.5.3.1 Expansion device eFUSE configuration」には、さらに詳しく SD/MMCデバイスの設定について記載されています。テーブル「8-15. USDHC boot eFUSE descriptions」によれば、eFuse の 0x450[7:6] が 01 の場合に SD/MMC デバイスからブートすることを決めています。さらに 0x450[5] が 0 なら SDが、 0x450[5] が 1 なら MMC が選択されます。つまり、4から 7 bit までの間で 5 bit 目だけが MMC か SD かを決めています。 BOOT_CFG1[5] が 0 の場合はコントローラーは SDデバイスが繋がっている前提で、 BOOT_CFG1[5] が 1 の場合は MMCデバイスが繋っている前提で動作します。 i.MX6ULL には、SD/MMC のコントローラーである uSDHC が 2つ搭載されています。 Armadillo-640では、eMMC が uSDHC1に、 microSDカードが uSDHC2 に接続されています。ブート時にどちらのコントローラーからブートするかを決めている eFuse が 0x450[12:11] です。 0x450[12:11] が 00 であれば uSDHC1 つまりオンボード eMMC から、01 であれば uSDHC2 つまり microSDカードからブートします。言い換えると Armadillo-640 でオンボード eMMC からブートしたい場合は、0x450[5] を 1 に、 0x450[12:11] を 00 にします。逆に microSDカードから起動したい場合は 0x450[5] を 0 に、0x450[12:11] を 01 にします。 表6.15 ブートデバイスと eFuse ブートデバイス | eFuse 0x450[5] | 0x450[12:11] |
オンボード eMMC | 1
| 00
| microSDカード | 0
| 01
Armadillo-640 では、U-Boot のコマンドによって eFuseの書き換えをサポートしています。 「スライドスイッチの設定について」 を参照してU-Boot を保守モードで起動してください。 eFuse の書き換えは、 fuse コマンドを使います。 ![[注記]](images/note.png) | |
cmd/fuse.c
drivers/misc/mxc_ocotp.c
6.24.3. Boot From FusesモードBoot From Fuses を有効にするには、 eFuse に書き込んだ値が正しいことを i.MX6ULL に教える必要があります。そのための eFuse が BT_FUSE_SEL (0x460[4] ) です。BOOT_MODE が 00 、つまり JP2 がオープンで、且つこのビットが 1 であれば Boot From Fuses モードになります。 BOOT_MODE が 00 でも このビットが 0 であれば Boot From Fusesモードにはならず、 SD/MMC マニュファクチャリングモードやシリアルダウンロードモードになってしまいます。SD/MMCマニュファクチャリングモードについては 「8.12 SD/MMC manufacture mode」に、シリアルダウンロードモードについては「8.9 Serial Downloader」に記載されています。 ![[警告]](images/warning.png) | |
オンボード eMMC からだけブートさせたい場合は、ブートデバイスの種類で MMC と、コントローラーで uSDHC1 を選択することで可能です。忘れずに BT_FUSE_SEL を 1 にします。 オンボード eMMC のスペックは、以下の通りです。リファレンスマニュアル 8.5.3 Expansion device および 表「5-6. MMC/eMMC Boot Fusemap」を確認してください。「可変」列が「不」となっている値は、変更しないでください。例えば、オンボード eMMC は 1.8 V に対応していません。 bit 9 の SD Voltage Selection で 1 の 1.8 V では動作しません。 表6.16 オンボード eMMC のスペック 名前 | Bit | eFuse | 値 | bit列 | 可変 |
| [15:13]
| Bus Width | 8 bit | 010
| 不 | [12:11]
| Port Select | uSDHC1 | 00
| 不 | [10]
| 可 | [9]
| 不 | [8]
| - | - | 0
| - | BOOT_CFG1
| [7:5]
| eMMC | - | 011
| 不 | [4]
| Fast Boot | Regular | 0
| 可 | [3]
| SD/MMC Speed | High | 0
| 不 | [2]
| 可 | [1]
| 可 | [0]
| 不 |
同じ要領で、SDからだけしかブートしないようにすることも可能です。しかし eFuse によるブートデバイスの固定は、意図しないブートを防ぐことが目的です。 Armadillo-640 で microSDからのブートに固定することは可能ですが、別の microSDカードを挿入されてしまうと、その別の microSDカードからブートしてしまうので目的を達成できません。理解してお使いください。 書き込んだ eFuse の値を変更されてしまっては、Boot From Fuseモードにしている意味がありません。i.MX6ULLでは eFuse を変更できなくするビットも用意されています。 リファレンスマニュアル「5.3 Fusemap Descriptions Table」を確認してください。 本章では、Armadillo-640のオプション品について説明します。 表6.17 Armadillo-640関連のオプション品 6.25.1. USBシリアル変換アダプタ(Armadillo-640用)FT232RLを搭載したUSB-シリアル変換アダプタです。シリアルの信号レベルは3.3V CMOSです。 -
Armadillo-640のCON9の「1、3、5、7、9」または「2、4、6、8、10」ピンに接続して使用することが可能です。 各ピンに対応するUARTコントローラは以下のとおりです。 表6.18 各ピンに対応するUARTコントローラ CON9ピン番号 | UART名 |
スライドスイッチの状態に対応した起動モードは以下のとおりです。 表6.19 USBシリアル変換アダプタのスライドスイッチによる起動モードの設定 スライドスイッチ | 起動モード |
故障の原因となる可能性があります。 |
表6.20 Armadillo-600シリーズ オプションケース(樹脂製)について 商品名 | Armadillo-600シリーズ オプションケース(樹脂製) | 型番 | OP-CASE600-PLA-00 | 内容 | 樹脂ケース、ネジ、ゴム足 |
表6.21 Armadillo-600シリーズ オプションケース(樹脂製)の仕様 材質 | 難燃ABS樹脂 | 難燃性 | UL94 V-0 | 色 | 白 | 使用温度範囲 | -10〜50℃ |
金属ケースはオプション品として別売りしています。 |
表6.22 Armadillo-600シリーズ オプションケース(金属製)について 商品名 | Armadillo-600シリーズ オプションケース(金属製) | 型番 | OP-CASE600-MET-00 | 内容 | アルミケース、ネジ、ゴム足、ACアダプタケーブル固定用パーツ |
皿ネジ(M2.6、L=4mm) x 3
トラス小ネジ(M3、L=5mm) x 1
Armadillo-640のCON11(LCD拡張インターフェース)に接続して使用することが可能です。 ソフトウェアからの利用方法については、「LCD を使用する」を参照してください。 表6.23 LCDオプションセット(7インチタッチパネルWVGA液晶)について 商品名 | LCDオプションセット(7インチタッチパネルWVGA液晶) | 型番 | OP-LCD70EXT-L00 | 内容 | 7インチ タッチパネルLCD、FFC |
表6.24 LCDの仕様 型番 | GT800X480A-1013P | メーカー | ノリタケ伊勢電子 | タイプ | TFT-LCD | 表示サイズ | 7インチ | 外形サイズ | 164.8 x 99.8 mm | 解像度 | 800 x 480 pixels | 表示色数 | 約1677万色 | 使用温度範囲 | -20〜+70℃ | 輝度 | 850cd/m2 (Typ.) 25℃ | 電源 | DC 5V±5%/500mA (Typ.), DC 3.3V±3%/35mA (Typ) | 映像入力インターフェース | RGBパラレル(18bit/24bit)[] | タッチパネルインターフェース | I2C(HID準拠) | タッチ方式 | 投影型静電容量方式 | マルチタッチ | 最大10点対応 |
時刻データを保持するための電池ホルダも搭載しています。
表6.25 Armadillo-600シリーズ RTCオプションモジュールについて 商品名 | Armadillo-600シリーズ RTCオプションモジュール | 型番 | OP-A600-RTCMOD-00 | 内容 | RTCオプションモジュール、ネジ、スペーサ |
RTCオプションモジュールの仕様は次のとおりです。 表6.26 RTCオプションモジュールの仕様 リアルタイムクロック | 型番 | NR3225SA | メーカー | 日本電波工業 | バックアップ | 電池ホルダ、外部バッテリ接続コネクタ搭載(対応電池: CR2016、CR2032 WK11等) | 平均月差(参考値) | 約21秒@-20℃、約8秒@25℃、約21秒@70℃ | USB | Type Aコネクタ搭載 | 電源電圧 | DC 3.3V±6%(RTC)、DC 2.0〜3.5V(RTCバックアップ)、DC 5V±5%(USB) | 使用温度範囲 | -20~+70℃(結露なきこと) [] | 外形サイズ | 42 x 50 mm |
RTCオプションモジュールのブロック図は次のとおりです。 RTCオプションモジュールのインターフェースについて説明します。 表6.27 RTCオプションモジュール インターフェース一覧 [] 部品番号 | インターフェース名 | 型番 | メーカ |
Armadillo-640のCON9(拡張インターフェース)の11ピンから24ピンに接続して使用します。 表6.28 CON1 信号配列 ピン番号 | ピン名 | I/O | 説明 |
CON3は活線挿抜非対応となっております。
表6.29 CON3 信号配列 ピン番号 | ピン名 | I/O | 説明 |
3つの形状のインターフェースがありますので、お使いのバッテリに合わせてご使用ください。 表6.30 対応バッテリ例 部品番号 | 対応電池 | バックアップ時間(参考値) |
表6.31 CON4、CON5、CON6 信号配列 ピン番号 | ピン名 | I/O | 説明 |
JP1は、はんだジャンパになります。
6.25.5.9. Armadillo-640とRTCオプションモジュールの組み立てRTCオプションモジュールはArmadillo-640のCON9の11ピンから24ピンに接続します。図6.146「RTCオプションモジュールの組み立て」のようにコネクタ接続後、金属スペーサで固定してください。 ![[警告]](images/warning.png) | |
金属スペーサ(M2、L=11mm) x 2
プラス端子側に電池を入れる
電池ホルダのツメの下に電池を押し込む
電池を取り外す手順は以下のとおりです。 -
電池を軽く押さえる
マイナスドライバーで電池を持ち上げる
6.25.6. Armadillo-600シリーズ WLANコンボ、BT/THオプションモジュールEzurio製の無線LAN/BTコンボモジュール Sterling LWB5+、
加賀FEI製のBT/THモジュール EYSKBNZWBの実装/未実装で、3種類のオプションモジュールがあります。 表6.32 Armadillo-640 WLANコンボ、BT/THオプションモジュールの搭載デバイス 名称 | 型番 | 搭載デバイス |
BT機能もしくはThread機能を使用したい場合は、
EYSKBNZWBを搭載したオプションモジュールを選択してください。 ソフトウェアからの利用方法については、Sterling LWB5+搭載のオプションモジュールを利用している場合は「WLAN を使用する」を、EYSKBNZWB搭載のオプションモジュールを利用している場合は「BT デバイスを使用する」または、「Thread デバイスを扱う」を参照してください。 WLANコンボ、BT/THオプションモジュールの同梱物は表6.33「WLANコンボ、BT/THオプションモジュールの同梱物」のとおりです。
Sterling LWB5+を使う場合は、外付けアンテナが必須となりますので別途ご用意ください。 表6.33 WLANコンボ、BT/THオプションモジュールの同梱物 内容物 | 個数 | 用途 |
表6.34 推奨外付けアンテナ 商品名 | 無線LAN用 外付けアンテナセット 08 | 型番 | OP-ANT-WLAN-08K | セット内容 | アンテナ(WAND2DBI-SMA-2NB/OxfordTEC)、アンテナケーブル(ケーブル長60mm) |
BTOサービスを提供しています。詳細につきましては、
WLANコンボ、BT/THオプションモジュールの仕様は次のとおりです。 表6.35 WLANコンボ、BT/THオプションモジュールの仕様 無線LAN/BTコンボモジュール | 型番 | Sterling LWB5+ | メーカー | Ezurio | 無線規格 | IEEE 802.11a/b/g/n/ac and Bluetooth 5.2 | BT/THモジュール | 型番 | EYSKBNZWB | メーカー | 加賀FEI | 無線規格 | Bluetooth 5.0 or IEEE 802.15.4(Thread) [] | 電源電圧 | DC 5V±5% | 使用温度範囲(基板単体) | -20~+70℃(結露なきこと) [] | 外形サイズ | 41 x 49.7 mm |
デバイスのメーカーサイトにてご確認ください。 |
WLANコンボ、BT/THオプションモジュールのブロック図は次のとおりです。 WLANコンボ、BT/THオプションモジュールのインターフェースについて説明します。 表6.36 WLANコンボ、BT/THオプションモジュール インターフェース一覧 [] 部品番号 | インターフェース名 | 型番 | メーカー |
6.25.6.5. CON1(Armadillo-600シリーズ接続インターフェース)CON1はArmadillo-600シリーズの基板と接続するためのインターフェースです。 表6.37 CON1 信号配列 ピン番号 | ピン名 | I/O | 説明 |
Armadillo-640と接続した場合、UART1の信号線が利用可能です。 表6.38 CON2 信号配列 ピン番号 | ピン名 | I/O | 説明 | Armadillo-640 CON9接続ピン名 |
コネクタは実装されておりませんので、必要であればコネクタを実装してください。表6.39「CON2 搭載コネクタ例」に記載したコネクタ等が実装可能です。
蓋が閉まらなくなりますので、オプションケースへの収納を検討している場合はご注意ください。 表6.39 CON2 搭載コネクタ例 型番 | メーカー |
シリアルコンソールを利用することが可能です。
Ezurio製の無線LAN/BTコンボモジュール Sterling LWB5+対応のアンテナセットです。 表6.40 無線LAN用 外付けアンテナセット 08について 商品名 | 無線LAN用 外付けアンテナセット 08 | 型番 | OP-ANT-WLAN-08K | セット内容 | アンテナ(WAND2DBI-SMA-2NB/OxfordTEC)、アンテナケーブル(ケーブル長100mm) | 対応製品 | OP-A600-AWLMOD-20, OP-A600-BTTHMOD-21 |
詳細につきましては、
6.25.7.2. アンテナケーブルコネクタの嵌合アンテナケーブルコネクタは、Sterling LWB5+上のコネクタに接続します。 アンテナケーブルコネクタは、挿抜治具(90609-0001/IPEX)を使用して嵌合するか、手で直接嵌合します。 挿抜治具による嵌合 アンテナケーブルコネクタのストッパーに当たるまで挿抜治具をスライドさせ、コネクタ全体を抱えるようにします。アンテナケーブルコネクタが基板に対し平行になっていることを確認し、垂直に挿抜治具を押してコネクタを嵌合します。 ![[警告]](images/warning.png) | |
曲がったまま嵌合すると、コネクタ破損の原因となります。 |
手で直接嵌合 アンテナケーブルを持ち、Sterling LWB5+上のアンテナコネクタにアンテナケーブルのコネクタをセットします。セットしたら前後に軽く動かし、動かないことを確認します。 コネクタのセンターを真上から押し、カチッという音がすると嵌合完了です。 6.25.7.3. アンテナケーブルコネクタの抜去アンテナのケーブルコネクタは、ケーブルコネクタ首部へのストレスを避けるため、挿抜治具(90609-0001/IPEX)を使用して抜去してください。 ケーブルコネクタのストッパーに当たるまで挿抜治具をスライドさせ、ケーブルコネクタ全体を抱えるようにします。基板と垂直に挿抜治具を引き上げてコネクタを抜去します。 ![[警告]](images/warning.png) | |
挿抜治具は必ず基板と垂直に引き上げてください。
アンテナを固定することができます。 表6.41 外付けアンテナ固定金具 00について 商品名 | 外付けアンテナ固定金具 00 | 型番 | OP-MNT-ANT-MET-00 | セット内容 | アンテナ固定金具本体[] |
オプションケース対応のアンテナ固定金具とは違う金具です。
