VSCode の左ペインの [A600] から [Atmark Container New Project] を実行し、
プロジェクト名 : my_project
6.2.5.2. Docker ファイルからイメージをビルドするArmadillo-640 コンテナ から
| standby
UART1 (CON9)
USB OTG1 (下段)
USB OTG2 (上段)
6.8.6.6. Rest API : コンテナ操作
6.8.6.7. Rest API : ネットワーク設定
{"name":"Wired connection 1","state":"activated","uuid":"18d241f1-946c-3325-974f-65cda3e6eea5","ctype":"802-3-ethernet","device":"eth0","props":{"802-3-ethernet.accept-all-mac-addresses":"-1","802-3-ethernet.auto-negotiate":"no","802-3-ethernet.cloned-mac-address":"","802-3-ethernet.duplex":"","802-3-ethernet.generate-mac-address-mask":"","802-3-ethernet.mac-address":"","802-3-ethernet.mac-address-blacklist":"","802-3-ethernet.mtu":"auto","802-3-ethernet.port":"","802-3-ethernet.s390-nettype":"","802-3-ethernet.s390-options":"","802-3-ethernet.s390-subchannels":"","802-3-ethernet.speed":"0","802-3-ethernet.wake-on-lan":"default","802-3-ethernet.wake-on-lan-password":"","GENERAL.CON-PATH":"/org/freedesktop/NetworkManager/Settings/1","GENERAL.DBUS-PATH":"/org/freedesktop/NetworkManager/ActiveConnection/6","GENERAL.DEFAULT":"yes","GENERAL.DEFAULT6":"no","GENERAL.DEVICES":"eth0","GENERAL.IP-IFACE":"eth0","GENERAL.MASTER-PATH":"","GENERAL.NAME":"Wired connection 1","GENERAL.SPEC-OBJECT":"","GENERAL.STATE":"activated","GENERAL.UUID":"18d241f1-946c-3325-974f-65cda3e6eea5","GENERAL.VPN":"no","GENERAL.ZONE":"","IP4.ADDRESS[1]":"198.51.100.123/16","IP4.DNS[1]":"192.0.2.1","IP4.DNS[2]":"192.0.2.2","IP4.GATEWAY":"198.51.100.1","IP4.ROUTE[1]":"dst = 198.51.100.0/16, nh = 0.0.0.0, mt = 100","IP4.ROUTE[2]":"dst = 0.0.0.0/0, nh = 198.51.100.1, mt = 100","IP6.ADDRESS[1]":"fe80::211:cff:fe00:b13/64","IP6.GATEWAY":"","IP6.ROUTE[1]":"dst = fe80::/64, nh = ::, mt = 1024","connection.auth-retries":"-1","connection.autoconnect":"yes","connection.autoconnect-priority":"-999","connection.autoconnect-retries":"-1","connection.autoconnect-slaves":"-1","connection.dns-over-tls":"-1","connection.gateway-ping-timeout":"0","connection.id":"Wired connection 1","connection.interface-name":"eth0","connection.lldp":"default","connection.llmnr":"-1","connection.master":"","connection.mdns":"-1","connection.metered":"unknown","connection.mptcp-flags":"0x0","connection.multi-connect":"0","connection.permissions":"","connection.read-only":"no","connection.secondaries":"","connection.slave-type":"","connection.stable-id":"","connection.timestamp":"1703208824","connection.type":"802-3-ethernet","connection.uuid":"18d241f1-946c-3325-974f-65cda3e6eea5","connection.wait-activation-delay":"-1","connection.wait-device-timeout":"-1","connection.zone":"","ipv4.addresses":"198.51.100.123/16","ipv4.auto-route-ext-gw":"-1","ipv4.dad-timeout":"-1","ipv4.dhcp-client-id":"","ipv4.dhcp-fqdn":"","ipv4.dhcp-hostname":"","ipv4.dhcp-hostname-flags":"0x0","ipv4.dhcp-iaid":"","ipv4.dhcp-reject-servers":"","ipv4.dhcp-send-hostname":"yes","ipv4.dhcp-timeout":"0","ipv4.dhcp-vendor-class-identifier":"","ipv4.dns":"192.0.2.1,192.0.2.2","ipv4.dns-options":"","ipv4.dns-priority":"0","ipv4.dns-search":"","ipv4.gateway":"198.51.100.1","ipv4.ignore-auto-dns":"no","ipv4.ignore-auto-routes":"no","ipv4.link-local":"0","ipv4.may-fail":"yes","ipv4.method":"manual","ipv4.never-default":"no","ipv4.replace-local-rule":"-1","ipv4.required-timeout":"-1","ipv4.route-metric":"-1","ipv4.route-table":"0","ipv4.routes":"","ipv4.routing-rules":"","ipv6.addr-gen-mode":"eui64","ipv6.addresses":"","ipv6.auto-route-ext-gw":"-1","ipv6.dhcp-duid":"","ipv6.dhcp-hostname":"","ipv6.dhcp-hostname-flags":"0x0","ipv6.dhcp-iaid":"","ipv6.dhcp-send-hostname":"yes","ipv6.dhcp-timeout":"0","ipv6.dns":"","ipv6.dns-options":"","ipv6.dns-priority":"0","ipv6.dns-search":"","ipv6.gateway":"","ipv6.ignore-auto-dns":"no","ipv6.ignore-auto-routes":"no","ipv6.ip6-privacy":"-1","ipv6.may-fail":"yes","ipv6.method":"auto","ipv6.mtu":"auto","ipv6.never-default":"no","ipv6.ra-timeout":"0","ipv6.replace-local-rule":"-1","ipv6.required-timeout":"-1","ipv6.route-metric":"-1","ipv6.route-table":"0","ipv6.routes":"","ipv6.routing-rules":"","ipv6.token":"","proxy.browser-only":"no","proxy.method":"none","proxy.pac-script":"","proxy.pac-url":""}}
必要制限: NetworkView
必要制限: NetworkAdmin
必要制限: NetworkAdmin
必要制限: NetworkAdmin
6.8.6.9. Rest API : WWAN の設定
必要制限: NetworkAdmin
必要制限: NetworkAdmin
6.8.6.10. Rest API : DHCP の設定
必要制限: NetworkView
必要制限: NetworkAdmin
必要制限: NetworkAdmin
6.8.6.11. Rest API : NAT の設定
必要制限: NetworkView
必要制限: NetworkAdmin
必要制限: NetworkAdmin
必要制限: NetworkView
必要制限: NetworkAdmin
必要制限: NetworkAdmin
6.8.6.12. Rest API : 時刻の設定-
必要制限: Custom
図6.91「ABOSDE で ローカルネットワーク上の Armadillo をスキャンする」 の赤枠で囲まれているボタンをクリックすることで、ローカルネットワーク上で ABOS Web が動作している Armadillo をスキャンすることができます。
そのため、ABOSDE では 図6.92「ABOSDE の ABOS Web パスワード入力画面」 のように ABOS Web のパスワードを求められますので、設定したパスワードを入力してください。 6.9.2. Armadillo のコンテナの情報を取得するローカルネットワーク上の Armadillo をスキャンした後に、
図6.94「ABOSDE で Armadillo のコンテナ情報を取得」 の赤枠で囲まれているボタンをクリックすることで、選択した Armadillo のコンテナの情報を取得できます。
図6.98「ABOSDE で Armadillo に SWU をインストール」 の赤枠で囲まれているボタンをクリックすることで、選択した Armadillo に SWU をインストールすることができます。
図6.101「nmcli のコマンド書式」に nmcli の書式を示します。このことから、 nmcli は「オブジェクト (OBJECT) というものが存在し、
コネクションの作成と同様に persist_file コマンドで永続化する必要があります。 DHCP に設定する例を、図6.111「DHCP の設定」に示します。 ![[注記]](images/note.png) | |
一つのパーティションで構成されている microSD カードのパーティションを、2つに分割する例を図6.120「fdiskコマンドによるパーティション変更」に示します。
これにより Armadillo 動作中の温度の変化が可視化され、得られる情報が見やすくなります。 図6.131「Armadillo-IoT ゲートウェイ G4で取得した温度のグラフ」は Armadillo-IoT ゲートウェイ G4上で一定期間 atmark-thermal-profiler を実行して取得した thermal_profile.csv を Google スプレッドシートでグラフ化したものです。
6.18.1. u-boot の環境変数の変更を制限するu-boot のソースに含まれる u-boot-[VERSION]/configs/armadillo-640_defconfig に
ブートディスクイメージをビルドします
baseos-640-[VERSION].img -
また、JP1と JP2 を共にジャンパでショートします。
In: mxc_serial
図6.137「デフォルトコンフィギュレーションの適用」に示すコマンドを実行します。
LD u-boot
CAT u-boot-dtb.bin
COPY u-boot.bin
SYM u-boot.sym
CFGCHK u-boot.cfg
Armadillo-640では、
│ │ System Type ---> │ │
│ │ Bus support ---> │ │
a600ディレクトリ以下のファイルを変更することで、
アットマークテクノが提供する SBOM は
ソフトウェアのセキュリティ対策は日々見直されており、
表面化していない脆弱性の発見に利用できます。
組み込み機器に適用する際の妨げになる場合があります。
SBOM にはパッケージのライセンス情報が含まれているため、GPLv3 ライセンスが含まれているかどうかの検出を可能にします。 6.21.3. ビルドしたルートファイルシステムの SBOM を作成する「Alpine Linux ルートファイルシステムをビルドする」 を実行すると、OS_update.swu と同じ場所に SBOM を作成します。
各項目の詳細な説明については SPDX specification v2.2.2 (https://spdx.github.io/spdx-spec/v2.2.2/) をご覧ください。 [ATDE ~/build-rootfs-[VERSION]]$ cat submodules/make-sbom/config.yaml 作成したコンフィグファイルと、baseos-600-[VERSION].tar.zst から OS_update.swu の SBOM を作成します。 [ATDE ~/build-rootfs-[VERSION]]$ ./build_sbom.sh -i OS_update.swu -c <コンフィグファイル> -f baseos-{product-image-name}-[VERSION].tar.zst
の各ソフトウェアダウンロードページからダウンロードすることができます。 6.21.4. SWU イメージと同時に SBOM を作成する「SWUイメージの作成」 の実行時に SBOM を作成する方法について説明します。
このファイルは SBOM 作成ツールによって配置されます。
json 形式で ISO/IEC5962で国際標準となっているSPDX2.2のフォーマットに準拠しています。 6.22. eMMC の GPP(General Purpose Partition) を利用するGPP に squashfs イメージを書き込み、Armadillo の起動時に自動的にマウントする方法を紹介します。 6.22.1. squashfs イメージを作成するこの作業は ATDE 上で行います。 squashfs-tools パッケージに含まれている mksquashfs コマンドを使用して squashfs イメージを作成します。 6.22.2. squashfs イメージを書き込む以降の作業は Armadillo 上で行います。 「squashfs イメージを作成する」で作成した squashfs イメージを、USB メモリ利用するなどして Armadillo-640 にコピーし、GPP に書き込みます。 ![[警告]](images/warning.png) | |
6.22.4. 起動時に squashfs イメージをマウントされるようにする/etc/fstab を変更し、起動時に squashfs イメージがマウントされるようにします。
ログファイルを取り出して、不具合等の解析に利用することができます。 Armadillo-640 で /var/log 配下に出力するログに関しては 「/var/log/ 配下のログに関して」 を参照ください。 ログファイルは /var/at-log ディレクトリ内に atlog というファイル名で作成されているので、
このパーティションの障害チェックはシステム起動時に自動的に実行されます。 6.23.5. /var/log/ 配下のログに関して表6.17「/var/log/ 配下のログ」 に Armadillo-640 で /var/log/ 配下に出力するログを示します。 最大ファイルサイズを超えると 表6.17「/var/log/ 配下のログ」 の「ファイル名」の 2 行目に記載されたファイル名にコピーします。 その状態から更に最大ファイルサイズを超えた場合、 表6.17「/var/log/ 配下のログ」 の「ファイル名」の 2 行目に記載されたファイル名に上書きします。 表6.17 /var/log/ 配下のログ ファイル名 | 説明 | 最大ファイルサイズ | 最大ファイル数 |
文字を入力するにはコマンドモードから入力モードへ移行する必要があります。コマンドモードから入力モードに移行するには、表6.18「入力モードに移行するコマンド」に示すコマンドを入力します。入力モードへ移行後は、キーを入力すればそのまま文字が入力されます。 表6.18 入力モードに移行するコマンド コマンド | 動作 |
「i」、「a」それぞれのコマンドを入力した場合の文字入力の開始位置を図6.146「入力モードに移行するコマンドの説明」に示します。 入力モードからコマンドモードに戻りたい場合は、ESCキーを入力することで戻ることができます。現在のモードが分からなくなった場合は、ESCキーを入力し、一旦コマンドモードへ戻ることにより混乱を防げます。 ![[警告]](images/warning.png) | |
方向キーでカーソルの移動ができますが、コマンドモードで表6.19「カーソルの移動コマンド」に示すコマンドを入力することでもカーソルを移動することができます。 表6.19 カーソルの移動コマンド コマンド | 動作 |
ファイルの保存、終了を行うコマンドを表6.21「保存・終了コマンド」に示します。 表6.21 保存・終了コマンド コマンド | 動作 |
Chapter 5: Fusemap
Chatper 8: System Boot
i.MX6ULL にはブートモードを決める BOOT_MODE0 と BOOT_MODE1 というピンがあります。 BOOT_MODE0 は GND になっているので必ず 0 になります。BOOT_MODE1 は JP2 に接続されています。 JP2 がショートされていると BOOT_MODE1 は 1 になり Internal Boot モードになります。開放されていると 0 となり、 Boot From Fuses というモードになります。 Internal Bootモードでは、 on-chip boot ROMに書き込まれているコードが実行し、ブート可能なデバイスを検索します。リファレンスマニュアル「8.5 Boot devices (internal boot)」に、i.MX6ULL がブートできるデバイスの一覧が記載されています。Armadillo-640 では、そのうちオンボードeMMC と microSDカードに対応しています。Internal Bootモードでは、GPIO によって eFuseの設定を上書き (override) できるようになっています。つまり eFuse の設定がどうなっていようと、GPIO のピンでブートデバイスを決めることができます。 Boot From Fusesモードでは、単純に言えば GPIO による override が禁止され eFuse に書き込まれた状態でしかブートしません。この機能を有効にすることで、フィールドに出した製品が悪意ある人によって意図していないブートをし、被害が出ることを防ぐことができます。(もちろん、ブート後に root アカウントを乗っ取られるような作りでは、意味がありませんが…) Internal Bootモードでは、GPIO によって eFuseの設定を上書き (override) できるようになってると紹介しましたが、JP1 はまさにこの機能を使っています。 JP1 は LCD1_DATA05 と LCD1_DATA11 の制御をしていますが、これらのピンはそれぞれ BOOT_CFG1[5] と BOOT_CFG2[3] を override しています。「8.3.2 GPIO boot overrides」の 表「8-3. GPIO override contact assignments」を確認してください。 ややこしい事に、この BOOT_CFG で始まる eFUSE は、リファレンスマニュアルの中では eFuse のアドレスでも表記されています。 BOOT_CFG1 は eFuse のアドレスで言うと 0x450 の下位 8 bit つまり 0x450[7:0] であり、 BOOT_CFG2 は上位 8 bit つまり 0x450[15:8] にあたります。これは「5.1 Boot Fusemap」の表「5-5. SD/eSD Boot Fusemap」または表「5-6. MMC/eMMC Boot Fusemap」を確認することでわかります。 さらにややこしい事に、eFuse を書き込む場合にはこれら全ての値が使えず、On-Chip OTP Controller の bank と word の値が必要になります。これらの値は リファレンスマニュアルの「On-Chip OTP Controller」を参照してください。後で出てきますが Boot From Fuses で使用する BT_FUSE_SEL という eFuse のように GPIO による override ができないものもあります。 表6.22 GPIO override と eFuse 信号名 | eFuse名 | eFuseアドレス | OCOTP名 | Bank | Word |
| BOOT_CFG1[5]
| 0x450[5]
| BOOT_CFG2[3]
| 0x450[11]
| 0x460[4]
| OCOTP_CFG5 | 0 | 6 |
Armadillo-640 ではmicroSDカード または eMMC からのブートになるので、ブートデバイスを選択する eFuse BOOT_CFG1[7:4] は、010x または 011x になります。 リファレンスマニュアル「8.5.3.1 Expansion device eFUSE configuration」には、さらに詳しく SD/MMCデバイスの設定について記載されています。テーブル「8-15. USDHC boot eFUSE descriptions」によれば、eFuse の 0x450[7:6] が 01 の場合に SD/MMC デバイスからブートすることを決めています。さらに 0x450[5] が 0 なら SDが、 0x450[5] が 1 なら MMC が選択されます。つまり、4から 7 bit までの間で 5 bit 目だけが MMC か SD かを決めています。 BOOT_CFG1[5] が 0 の場合はコントローラーは SDデバイスが繋がっている前提で、 BOOT_CFG1[5] が 1 の場合は MMCデバイスが繋っている前提で動作します。 i.MX6ULL には、SD/MMC のコントローラーである uSDHC が 2つ搭載されています。 Armadillo-640では、eMMC が uSDHC1に、 microSDカードが uSDHC2 に接続されています。ブート時にどちらのコントローラーからブートするかを決めている eFuse が 0x450[12:11] です。 0x450[12:11] が 00 であれば uSDHC1 つまりオンボード eMMC から、01 であれば uSDHC2 つまり microSDカードからブートします。言い換えると Armadillo-640 でオンボード eMMC からブートしたい場合は、0x450[5] を 1 に、 0x450[12:11] を 00 にします。逆に microSDカードから起動したい場合は 0x450[5] を 0 に、0x450[12:11] を 01 にします。 表6.23 ブートデバイスと eFuse ブートデバイス | eFuse 0x450[5] | 0x450[12:11] |
オンボード eMMC | 1
| 00
| microSDカード | 0
| 01
Armadillo-640 では、U-Boot のコマンドによって eFuseの書き換えをサポートしています。 スライドスイッチの設定について を参照してU-Boot を保守モードで起動してください。 eFuse の書き換えは、 fuse コマンドを使います。 ![[注記]](images/note.png) | |
cmd/fuse.c
drivers/misc/mxc_ocotp.c
6.25.3. Boot From FusesモードBoot From Fuses を有効にするには、 eFuse に書き込んだ値が正しいことを i.MX6ULL に教える必要があります。そのための eFuse が BT_FUSE_SEL (0x460[4] ) です。BOOT_MODE が 00 、つまり JP2 がオープンで、且つこのビットが 1 であれば Boot From Fuses モードになります。 BOOT_MODE が 00 でも このビットが 0 であれば Boot From Fusesモードにはならず、 SD/MMC マニュファクチャリングモードやシリアルダウンロードモードになってしまいます。SD/MMCマニュファクチャリングモードについては 「8.12 SD/MMC manufacture mode」に、シリアルダウンロードモードについては「8.9 Serial Downloader」に記載されています。 ![[警告]](images/warning.png) | |
オンボード eMMC からだけブートさせたい場合は、ブートデバイスの種類で MMC と、コントローラーで uSDHC1 を選択することで可能です。忘れずに BT_FUSE_SEL を 1 にします。 オンボード eMMC のスペックは、以下の通りです。リファレンスマニュアル 8.5.3 Expansion device および 表「5-6. MMC/eMMC Boot Fusemap」を確認してください。「可変」列が「不」となっている値は、変更しないでください。例えば、オンボード eMMC は 1.8 V に対応していません。 bit 9 の SD Voltage Selection で 1 の 1.8 V では動作しません。 表6.24 オンボード eMMC のスペック 名前 | Bit | eFuse | 値 | bit列 | 可変 |
| [15:13]
| Bus Width | 8 bit | 010
| 不 | [12:11]
| Port Select | uSDHC1 | 00
| 不 | [10]
| 可 | [9]
| 不 | [8]
| - | - | 0
| - | BOOT_CFG1
| [7:5]
| eMMC | - | 011
| 不 | [4]
| Fast Boot | Regular | 0
| 可 | [3]
| SD/MMC Speed | High | 0
| 不 | [2]
| 可 | [1]
| 可 | [0]
| 不 |
同じ要領で、SDからだけしかブートしないようにすることも可能です。しかし eFuse によるブートデバイスの固定は、意図しないブートを防ぐことが目的です。 Armadillo-640 で microSDからのブートに固定することは可能ですが、別の microSDカードを挿入されてしまうと、その別の microSDカードからブートしてしまうので目的を達成できません。理解してお使いください。 書き込んだ eFuse の値を変更されてしまっては、Boot From Fuseモードにしている意味がありません。i.MX6ULLでは eFuse を変更できなくするビットも用意されています。 リファレンスマニュアル「5.3 Fusemap Descriptions Table」を確認してください。 本章では、Armadillo-640のオプション品について説明します。 表6.25 Armadillo-640関連のオプション品 6.26.1. USBシリアル変換アダプタ(Armadillo-640用)FT232RLを搭載したUSB-シリアル変換アダプタです。シリアルの信号レベルは3.3V CMOSです。 -
Armadillo-640のCON9の「1、3、5、7、9」または「2、4、6、8、10」ピンに接続して使用することが可能です。 各ピンに対応するUARTコントローラは以下のとおりです。 表6.26 各ピンに対応するUARTコントローラ CON9ピン番号 | UART名 |
スライドスイッチの状態に対応した起動モードは以下のとおりです。 表6.27 USBシリアル変換アダプタのスライドスイッチによる起動モードの設定 スライドスイッチ | 起動モード |
故障の原因となる可能性があります。 |
6.26.2. Armadillo-600シリーズ オプションケース(樹脂製)Armadillo-640用のプラスチック製小型ケースです。
表6.28 Armadillo-600シリーズ オプションケース(樹脂製)について 商品名 | Armadillo-600シリーズ オプションケース(樹脂製) | 型番 | OP-CASE600-PLA-00 | 内容 | 樹脂ケース、ネジ、ゴム足 |
表6.29 Armadillo-600シリーズ オプションケース(樹脂製)の仕様 材質 | 難燃ABS樹脂 | 難燃性 | UL94 V-0 | 色 | 白 | 使用温度範囲 | -10〜50℃ |
6.26.3. Armadillo-600シリーズ オプションケース(金属製)Armadillo-640用のアルミ製小型ケースです。
金属ケースはオプション品として別売りしています。 |
表6.30 Armadillo-600シリーズ オプションケース(金属製)について 商品名 | Armadillo-600シリーズ オプションケース(金属製) | 型番 | OP-CASE600-MET-00 | 内容 | アルミケース、ネジ、ゴム足、ACアダプタケーブル固定用パーツ |
ねじ締めトルクは31.5cN•m です。 -
皿ネジ(M2.6、L=4mm) x 3
ねじ締めトルクは10.0cN•m です。 -
トラス小ネジ(M3、L=5mm) x 1
ねじ締めトルクは10.0cN•m です。 6.26.4. LCDオプションセット(7インチタッチパネルWVGA液晶)ノリタケ伊勢電子製のタッチパネルLCDとフレキシブルフラットケーブル(FFC)のセットです。
Armadillo-640のCON11(LCD拡張インターフェース)に接続して使用することが可能です。 ソフトウェアからの利用方法については、「LCD を使用する」を参照してください。 表6.31 LCDオプションセット(7インチタッチパネルWVGA液晶)について 商品名 | LCDオプションセット(7インチタッチパネルWVGA液晶) | 型番 | OP-LCD70EXT-L00 | 内容 | 7インチ タッチパネルLCD、FFC |
表6.32 LCDの仕様 型番 | GT800X480A-1013P | メーカー | ノリタケ伊勢電子 | タイプ | TFT-LCD | 表示サイズ | 7インチ | 外形サイズ | 164.8 x 99.8 mm | 解像度 | 800 x 480 pixels | 表示色数 | 約1677万色 | 使用温度範囲 | -20〜+70℃ | 輝度 | 850cd/m2 (Typ.) 25℃ | 電源 | DC 5V±5%/500mA (Typ.), DC 3.3V±3%/35mA (Typ) | 映像入力インターフェース | RGBパラレル(18bit/24bit)[] | タッチパネルインターフェース | I2C(HID準拠) | タッチ方式 | 投影型静電容量方式 | マルチタッチ | 最大10点対応 |
6.26.5. Armadillo-600シリーズ RTCオプションモジュール温度補償高精度リアルタイムクロック(RTC)とUSBコネクタを搭載したオプションモジュールです。
時刻データを保持するための電池ホルダも搭載しています。
表6.33 Armadillo-600シリーズ RTCオプションモジュールについて 商品名 | Armadillo-600シリーズ RTCオプションモジュール | 型番 | OP-A600-RTCMOD-00 | 内容 | RTCオプションモジュール、ネジ、スペーサ |
RTCオプションモジュールの仕様は次のとおりです。 表6.34 RTCオプションモジュールの仕様 リアルタイムクロック | 型番 | NR3225SA | メーカー | 日本電波工業 | バックアップ | 電池ホルダ、外部バッテリ接続コネクタ搭載(対応電池: CR2016、CR2032 WK11等) | 平均月差(参考値) | 約21秒@-20℃、約8秒@25℃、約21秒@70℃ | USB | Type Aコネクタ搭載 | 電源電圧 | DC 3.3V±6%(RTC)、DC 2.0〜3.5V(RTCバックアップ)、DC 5V±5%(USB) | 使用温度範囲 | -20~+70℃(結露なきこと) [] | 外形サイズ | 42 x 50 mm |
RTCオプションモジュールのブロック図は次のとおりです。 RTCオプションモジュールのインターフェースについて説明します。 表6.35 RTCオプションモジュール インターフェース一覧 [] 部品番号 | インターフェース名 | 型番 | メーカ |
6.26.5.5. CON1(Armadillo-600シリーズ接続インターフェース)CON1はArmadillo-600シリーズの基板と接続するためのインターフェースです。
Armadillo-640のCON9(拡張インターフェース)の11ピンから24ピンに接続して使用します。 表6.36 CON1 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.26.5.6. CON3(USBホストインターフェース)CON3はUSBホストインターフェースです。 CON1の8ピン(USB2_PORT_EN)からUSBコントローラ(USB OTG2)の接続先を変更して使用します。
CON3は活線挿抜非対応となっております。
表6.37 CON3 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.26.5.7. CON4、CON5、CON6(RTCバックアップインターフェース)CON4、CON5、CON6はRTCのバックアップ電源供給用のインターフェースです。
3つの形状のインターフェースがありますので、お使いのバッテリに合わせてご使用ください。 表6.38 対応バッテリ例 部品番号 | 対応電池 | バックアップ時間(参考値) |
表6.39 CON4、CON5、CON6 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.26.5.8. JP1(ONOFFピン接続ジャンパ)JP1は RTC のアラーム割り込み端子と Armadillo-640 の ONOFF ピン(Armadillo-640 CON9 11ピン)を接続するジャンパです。
JP1は、はんだジャンパになります。
6.26.5.9. Armadillo-640とRTCオプションモジュールの組み立てRTCオプションモジュールはArmadillo-640のCON9の11ピンから24ピンに接続します。図6.158「RTCオプションモジュールの組み立て」のようにコネクタ接続後、金属スペーサで固定してください。 ![[警告]](images/warning.png) | |
金属スペーサ(M2、L=11mm) x 2
プラス端子側に電池を入れる
電池ホルダのツメの下に電池を押し込む
電池を取り外す手順は以下のとおりです。 -
電池を軽く押さえる
マイナスドライバーで電池を持ち上げる
6.26.6. Armadillo-600シリーズ WLANコンボ、BT/THオプションモジュールEzurio製の無線LAN/BTコンボモジュール Sterling LWB5+、
加賀FEI製のBT/THモジュール EYSKBNZWBの実装/未実装で、3種類のオプションモジュールがあります。 表6.40 Armadillo-640 WLANコンボ、BT/THオプションモジュールの搭載デバイス 名称 | 型番 | 搭載デバイス |
BT機能もしくはThread機能を使用したい場合は、
EYSKBNZWBを搭載したオプションモジュールを選択してください。 ソフトウェアからの利用方法については、Sterling LWB5+搭載のオプションモジュールを利用している場合は「WLAN を使用する」を、EYSKBNZWB搭載のオプションモジュールを利用している場合は「BT デバイスを使用する」または、「Thread デバイスを扱う」を参照してください。 WLANコンボ、BT/THオプションモジュールの同梱物は表6.41「WLANコンボ、BT/THオプションモジュールの同梱物」のとおりです。
Sterling LWB5+を使う場合は、外付けアンテナが必須となりますので別途ご用意ください。 表6.41 WLANコンボ、BT/THオプションモジュールの同梱物 内容物 | 個数 | 用途 |
表6.42 推奨外付けアンテナ 商品名 | 無線LAN用 外付けアンテナセット 08 | 型番 | OP-ANT-WLAN-08K | セット内容 | アンテナ(WAND2DBI-SMA-2NB/OxfordTEC)、アンテナケーブル(ケーブル長60mm) |
BTOサービスを提供しています。詳細につきましては、
WLANコンボ、BT/THオプションモジュールの仕様は次のとおりです。 表6.43 WLANコンボ、BT/THオプションモジュールの仕様 無線LAN/BTコンボモジュール | 型番 | Sterling LWB5+ | メーカー | Ezurio | 無線規格 | IEEE 802.11a/b/g/n/ac and Bluetooth 5.2 | BT/THモジュール | 型番 | EYSKBNZWB | メーカー | 加賀FEI | 無線規格 | Bluetooth 5.0 or IEEE 802.15.4(Thread) [] | 電源電圧 | DC 5V±5% | 使用温度範囲(基板単体) | -20~+70℃(結露なきこと) [] | 外形サイズ | 41 x 49.7 mm |
デバイスのメーカーサイトにてご確認ください。 |
WLANコンボ、BT/THオプションモジュールのブロック図は次のとおりです。 WLANコンボ、BT/THオプションモジュールのインターフェースについて説明します。 表6.44 WLANコンボ、BT/THオプションモジュール インターフェース一覧 [] 部品番号 | インターフェース名 | 型番 | メーカー |
6.26.6.5. CON1(Armadillo-600シリーズ接続インターフェース)CON1はArmadillo-600シリーズの基板と接続するためのインターフェースです。 表6.45 CON1 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.26.6.6. CON2(拡張インターフェース)CON2は機能拡張用インターフェースです。
Armadillo-640と接続した場合、UART1の信号線が利用可能です。 表6.46 CON2 信号配列 ピン番号 | ピン名 | I/O | 説明 | Armadillo-640 CON9接続ピン名 |
コネクタは実装されておりませんので、必要であればコネクタを実装してください。表6.47「CON2 搭載コネクタ例」に記載したコネクタ等が実装可能です。
蓋が閉まらなくなりますので、オプションケースへの収納を検討している場合はご注意ください。 表6.47 CON2 搭載コネクタ例 型番 | メーカー |
オプションケース対応のアンテナ固定金具を使用した場合、組み立て後でも
Armadillo-600シリーズ オプションケース(樹脂製)に収めることが可能です。 -
タッピングねじ(M2.6、L=20mm) x 3
タッピングねじ(M3、L=12mm) x 1
飾りねじ x 1
ねじ締めトルクは30.0cN•m です。 6.26.6.11. シリアルコンソールの使用方法シリアルコンソールが必要な場合、WLANコンボ、BT/THオプションモジュールを
シリアルコンソールを利用することが可能です。
CON3を使用する場合は、シリアルクロスケーブルが必要になります。 6.26.7. 無線LAN用 外付けアンテナセット 08無線LAN用 外付けアンテナセット 08は、
Ezurio製の無線LAN/BTコンボモジュール Sterling LWB5+対応のアンテナセットです。 表6.48 無線LAN用 外付けアンテナセット 08について 商品名 | 無線LAN用 外付けアンテナセット 08 | 型番 | OP-ANT-WLAN-08K | セット内容 | アンテナ(WAND2DBI-SMA-2NB/OxfordTEC)、アンテナケーブル(ケーブル長100mm) | 対応製品 | OP-A600-AWLMOD-20, OP-A600-BTTHMOD-21 |
詳細につきましては、
6.26.7.2. アンテナケーブルコネクタの嵌合アンテナケーブルコネクタは、Sterling LWB5+上のコネクタに接続します。 アンテナケーブルコネクタは、挿抜治具(90609-0001/IPEX)を使用して嵌合するか、手で直接嵌合します。 挿抜治具による嵌合 アンテナケーブルコネクタのストッパーに当たるまで挿抜治具をスライドさせ、コネクタ全体を抱えるようにします。アンテナケーブルコネクタが基板に対し平行になっていることを確認し、垂直に挿抜治具を押してコネクタを嵌合します。 ![[警告]](images/warning.png) | |
曲がったまま嵌合すると、コネクタ破損の原因となります。 |
手で直接嵌合 アンテナケーブルを持ち、Sterling LWB5+上のアンテナコネクタにアンテナケーブルのコネクタをセットします。セットしたら前後に軽く動かし、動かないことを確認します。 コネクタのセンターを真上から押し、カチッという音がすると嵌合完了です。 6.26.7.3. アンテナケーブルコネクタの抜去アンテナのケーブルコネクタは、ケーブルコネクタ首部へのストレスを避けるため、挿抜治具(90609-0001/IPEX)を使用して抜去してください。 ケーブルコネクタのストッパーに当たるまで挿抜治具をスライドさせ、ケーブルコネクタ全体を抱えるようにします。基板と垂直に挿抜治具を引き上げてコネクタを抜去します。 ![[警告]](images/warning.png) | |
挿抜治具は必ず基板と垂直に引き上げてください。
アンテナを固定することができます。 表6.49 外付けアンテナ固定金具 00について 商品名 | 外付けアンテナ固定金具 00 | 型番 | OP-MNT-ANT-MET-00 | セット内容 | アンテナ固定金具本体[] |
オプションケース対応のアンテナ固定金具とは違う金具です。
