この SWU イメージを 「SWU イメージのインストール」 を参照して Armadillo へインストールしてください。 6.2.5.2. Docker ファイルからイメージをビルドするArmadillo-610 コンテナ から
| standby
デフォルトで有効化されています -
6.8.6.6. Rest API : コンテナ操作
6.8.6.7. Rest API : ネットワーク設定
ネットワーク接続一覧
ネットワーク接続詳細取得
{"name":"Wired connection 1","state":"activated","uuid":"18d241f1-946c-3325-974f-65cda3e6eea5","ctype":"802-3-ethernet","device":"eth0","props":{"802-3-ethernet.accept-all-mac-addresses":"-1","802-3-ethernet.auto-negotiate":"no","802-3-ethernet.cloned-mac-address":"","802-3-ethernet.duplex":"","802-3-ethernet.generate-mac-address-mask":"","802-3-ethernet.mac-address":"","802-3-ethernet.mac-address-blacklist":"","802-3-ethernet.mtu":"auto","802-3-ethernet.port":"","802-3-ethernet.s390-nettype":"","802-3-ethernet.s390-options":"","802-3-ethernet.s390-subchannels":"","802-3-ethernet.speed":"0","802-3-ethernet.wake-on-lan":"default","802-3-ethernet.wake-on-lan-password":"","GENERAL.CON-PATH":"/org/freedesktop/NetworkManager/Settings/1","GENERAL.DBUS-PATH":"/org/freedesktop/NetworkManager/ActiveConnection/6","GENERAL.DEFAULT":"yes","GENERAL.DEFAULT6":"no","GENERAL.DEVICES":"eth0","GENERAL.IP-IFACE":"eth0","GENERAL.MASTER-PATH":"","GENERAL.NAME":"Wired connection 1","GENERAL.SPEC-OBJECT":"","GENERAL.STATE":"activated","GENERAL.UUID":"18d241f1-946c-3325-974f-65cda3e6eea5","GENERAL.VPN":"no","GENERAL.ZONE":"","IP4.ADDRESS[1]":"198.51.100.123/16","IP4.DNS[1]":"192.0.2.1","IP4.DNS[2]":"192.0.2.2","IP4.GATEWAY":"198.51.100.1","IP4.ROUTE[1]":"dst = 198.51.100.0/16, nh = 0.0.0.0, mt = 100","IP4.ROUTE[2]":"dst = 0.0.0.0/0, nh = 198.51.100.1, mt = 100","IP6.ADDRESS[1]":"fe80::211:cff:fe00:b13/64","IP6.GATEWAY":"","IP6.ROUTE[1]":"dst = fe80::/64, nh = ::, mt = 1024","connection.auth-retries":"-1","connection.autoconnect":"yes","connection.autoconnect-priority":"-999","connection.autoconnect-retries":"-1","connection.autoconnect-slaves":"-1","connection.dns-over-tls":"-1","connection.gateway-ping-timeout":"0","connection.id":"Wired connection 1","connection.interface-name":"eth0","connection.lldp":"default","connection.llmnr":"-1","connection.master":"","connection.mdns":"-1","connection.metered":"unknown","connection.mptcp-flags":"0x0","connection.multi-connect":"0","connection.permissions":"","connection.read-only":"no","connection.secondaries":"","connection.slave-type":"","connection.stable-id":"","connection.timestamp":"1703208824","connection.type":"802-3-ethernet","connection.uuid":"18d241f1-946c-3325-974f-65cda3e6eea5","connection.wait-activation-delay":"-1","connection.wait-device-timeout":"-1","connection.zone":"","ipv4.addresses":"198.51.100.123/16","ipv4.auto-route-ext-gw":"-1","ipv4.dad-timeout":"-1","ipv4.dhcp-client-id":"","ipv4.dhcp-fqdn":"","ipv4.dhcp-hostname":"","ipv4.dhcp-hostname-flags":"0x0","ipv4.dhcp-iaid":"","ipv4.dhcp-reject-servers":"","ipv4.dhcp-send-hostname":"yes","ipv4.dhcp-timeout":"0","ipv4.dhcp-vendor-class-identifier":"","ipv4.dns":"192.0.2.1,192.0.2.2","ipv4.dns-options":"","ipv4.dns-priority":"0","ipv4.dns-search":"","ipv4.gateway":"198.51.100.1","ipv4.ignore-auto-dns":"no","ipv4.ignore-auto-routes":"no","ipv4.link-local":"0","ipv4.may-fail":"yes","ipv4.method":"manual","ipv4.never-default":"no","ipv4.replace-local-rule":"-1","ipv4.required-timeout":"-1","ipv4.route-metric":"-1","ipv4.route-table":"0","ipv4.routes":"","ipv4.routing-rules":"","ipv6.addr-gen-mode":"eui64","ipv6.addresses":"","ipv6.auto-route-ext-gw":"-1","ipv6.dhcp-duid":"","ipv6.dhcp-hostname":"","ipv6.dhcp-hostname-flags":"0x0","ipv6.dhcp-iaid":"","ipv6.dhcp-send-hostname":"yes","ipv6.dhcp-timeout":"0","ipv6.dns":"","ipv6.dns-options":"","ipv6.dns-priority":"0","ipv6.dns-search":"","ipv6.gateway":"","ipv6.ignore-auto-dns":"no","ipv6.ignore-auto-routes":"no","ipv6.ip6-privacy":"-1","ipv6.may-fail":"yes","ipv6.method":"auto","ipv6.mtu":"auto","ipv6.never-default":"no","ipv6.ra-timeout":"0","ipv6.replace-local-rule":"-1","ipv6.required-timeout":"-1","ipv6.route-metric":"-1","ipv6.route-table":"0","ipv6.routes":"","ipv6.routing-rules":"","ipv6.token":"","proxy.browser-only":"no","proxy.method":"none","proxy.pac-script":"","proxy.pac-url":""}}
ネットワーク接続の変更
6.8.6.8. Rest API : 時刻の設定-
図6.81「ABOSDE で ローカルネットワーク上の Armadillo をスキャンする」 の赤枠で囲まれているボタンをクリックすることで、ローカルネットワーク上で ABOS Web が動作している Armadillo をスキャンすることができます。
そのため、ABOSDE では 図6.82「ABOSDE の ABOS Web パスワード入力画面」 のように ABOS Web のパスワードを求められますので、設定したパスワードを入力してください。 6.9.2. Armadillo のコンテナの情報を取得するローカルネットワーク上の Armadillo をスキャンした後に、
図6.84「ABOSDE で Armadillo のコンテナ情報を取得」 の赤枠で囲まれているボタンをクリックすることで、選択した Armadillo のコンテナの情報を取得できます。
図6.88「ABOSDE で Armadillo に SWU をインストール」 の赤枠で囲まれているボタンをクリックすることで、選択した Armadillo に SWU をインストールすることができます。
SWU インストールのログは VSCode 画面下部の OUTPUT に表示されます。 6.10. ssh 経由で Armadillo Base OS にアクセスするArmadillo-610 にはopensshがインストールされていますが、デフォルトではSSHサーバーが起動していません。 SSHサーバーを自動的に起動するようにするためには、以下のコマンドを実行してください。 [armadillo:~]# rc-update add sshd
図6.91「nmcli のコマンド書式」に nmcli の書式を示します。このことから、 nmcli は「オブジェクト (OBJECT) というものが存在し、
コネクションの作成と同様に persist_file コマンドで永続化する必要があります。 DHCP に設定する例を、図6.101「DHCP の設定」に示します。 ![[注記]](images/note.png) | |
一つのパーティションで構成されている microSD カードのパーティションを、2つに分割する例を図6.110「fdiskコマンドによるパーティション変更」に示します。
これにより Armadillo 動作中の温度の変化が可視化され、得られる情報が見やすくなります。 図6.121「Armadillo-IoT ゲートウェイ G4で取得した温度のグラフ」は Armadillo-IoT ゲートウェイ G4上で一定期間 atmark-thermal-profiler を実行して取得した thermal_profile.csv を Google スプレッドシートでグラフ化したものです。
ブートディスクイメージのビルドします
baseos-640-[VERSION].img -
また、JP1 をジャンパでショートします。
In: mxc_serial
6.20. Armadilloのソフトウェアをビルドするここでは、Armadillo-610で使用するソフトウェアのビルド方法を説明します。 ここでは、Armadillo-610向けのブートローダーイメージをビルドする方法を説明します。
図6.126「デフォルトコンフィギュレーションの適用」に示すコマンドを実行します。
LD u-boot
CAT u-boot-dtb.bin
COPY u-boot.bin
SYM u-boot.sym
CFGCHK u-boot.cfg
Armadillo-610では、
│ │ System Type ---> │ │
│ │ Bus support ---> │ │
a600ディレクトリ以下のファイルを変更することで、
の各ソフトウェアダウンロードページからダウンロードすることができます。 6.21. eMMC の GPP(General Purpose Partition) を利用するGPP に squashfs イメージを書き込み、Armadillo の起動時に自動的にマウントする方法を紹介します。 6.21.1. squashfs イメージを作成するこの作業は ATDE 上で行います。 squashfs-tools パッケージに含まれている mksquashfs コマンドを使用して squashfs イメージを作成します。 6.21.2. squashfs イメージを書き込む以降の作業は Armadillo 上で行います。 「squashfs イメージを作成する」で作成した squashfs イメージを、USB メモリ利用するなどして Armadillo-610 にコピーし、GPP に書き込みます。 ![[警告]](images/warning.png) | |
uboot で wdt による再起動が合った場合にその日付
「i」、「a」それぞれのコマンドを入力した場合の文字入力の開始位置を図6.134「入力モードに移行するコマンドの説明」に示します。 ![[ティップ]](images/tip.png) | |
| ファイルを+file+に指定して保存 | :wq
保存と終了を行うコマンドは「 : 」(コロン)からはじまるコマンドを使用します。" : "キーを入力すると画面下部にカーソルが移り入力したコマンドが表示されます。コマンドを入力した後Enterキーを押すことで、コマンドが実行されます。 Armadillo-610 で採用している CPU (i.MX6ULL) には、一度しか書き込むことのできない eFuse が搭載されています。 eFuse には、 CPUがブートする時の設定や MAC アドレスなどが書かれます。Armadillo-610 は組み込み機器を作り込むエンジニアを対象にした製品ですので、 eFuse もユーザーに開放し、細かな制御を可能にしています。しかし eFuse はその性質上、一度書き間違うと直すことができません。十分に注意してください。 ![[警告]](images/warning.png) | |
Chapter 5: Fusemap
Chatper 8: System Boot
i.MX6ULL にはブートモードを決める BOOT_MODE0 と BOOT_MODE1 というピンがあります。 Armadillo-610 では、BOOT_MODE0 は 0 、BOOT_MODE1 は 1 となるよう回路が設計されており、ブートモードは必ず Internal Boot モードとなります。 6.24.1.1. Internal Boot モードInternal Bootモードでは、 on-chip boot ROMに書き込まれているコードが実行し、ブート可能なデバイスを検索します。リファレンスマニュアル「8.5 Boot devices (internal boot)」に、i.MX6ULL がブートできるデバイスの一覧が記載されています。Armadillo-610 では、そのうちオンボードeMMC と microSDカードに対応しています。 Internal Bootモードでは、GPIO によって eFuseの設定を上書き (override) できるようになっています。この機能は eFuse の BT_FUSE_SEL が 0 の場合のみ有効となります。eFuse の設定とは異なり何度も再設定できる点では便利ですが、overrideに対応したピンには i.MX6ULL の電源投入時に決まった信号を入力しておかなければいけないため、ハードウェア設計上は不便になります。 Armadillo-610では、GPIO による override を利用することで、仕様が確定していない段階ではブートデバイスを自由に何度も切り替えることを可能にしつつ、BT_FUSE_SEL を 1 にして GPIO による override を無効化することで、仕様が確定した段階では自由なハードウェア設計が可能になるよう配慮しています。また、GPIO による override を無効化することで、フィールドに出した製品が悪意ある人によって意図していないブートをし、被害が出ることを防ぐことができます。(もちろん、ブート後に root アカウントを乗っ取られるような作りでは、意味がありませんが…) Internal Bootモードでは、GPIO によって eFuseの設定を上書き (override) できるようになってると紹介しましたが、Armadillo-610 では、Armadillo-610 拡張ボードの JP1 はまさにこの機能を使っています。 JP1 は BJP1(Armadillo-610 CON2_42ピン) に接続されており、 LCD1_DATA05 と LCD1_DATA11 の制御をしていますが、これらのピンはそれぞれ BOOT_CFG1[5] と BOOT_CFG2[3] を override しています。「8.3.2 GPIO boot overrides」の 表「8-3. GPIO override contact assignments」を確認してください。 ややこしい事に、この BOOT_CFG で始まる eFUSE は、リファレンスマニュアルの中では eFuse のアドレスでも表記されています。 BOOT_CFG1 は eFuse のアドレスで言うと 0x450 の下位 8 bit つまり 0x450[7:0] であり、 BOOT_CFG2 は上位 8 bit つまり 0x450[15:8] にあたります。これは「5.1 Boot Fusemap」の表「5-5. SD/eSD Boot Fusemap」または表「5-6. MMC/eMMC Boot Fusemap」を確認することでわかります。 さらにややこしい事に、eFuse を書き込む場合にはこれら全ての値が使えず、On-Chip OTP Controller の bank と word の値が必要になります。これらの値は リファレンスマニュアルの「On-Chip OTP Controller」を参照してください。後で出てきますが Boot From Fuses で使用する BT_FUSE_SEL という eFuse のように GPIO による override ができないものもあります。 表6.14 GPIO override と eFuse 信号名 | eFuse名 | eFuseアドレス | OCOTP名 | Bank | Word |
| BOOT_CFG1[5]
| 0x450[5]
| BOOT_CFG2[3]
| 0x450[11]
| 0x460[4]
| OCOTP_CFG5 | 0 | 6 |
Armadillo-610 ではSDカード または eMMC からのブートになるので、ブートデバイスを選択する eFuse BOOT_CFG1[7:4] は、010x または 011x になります。 リファレンスマニュアル「8.5.3.1 Expansion device eFUSE configuration」には、さらに詳しく SD/MMCデバイスの設定について記載されています。テーブル「8-15. USDHC boot eFUSE descriptions」によれば、eFuse の 0x450[7:6] が 01 の場合に SD/MMC デバイスからブートすることを決めています。さらに 0x450[5] が 0 なら SDが、 0x450[5] が 1 なら MMC が選択されます。つまり、4から 7 bit までの間で 5 bit 目だけが MMC か SD かを決めています。 BOOT_CFG1[5] が 0 の場合はコントローラーは SDデバイスが繋がっている前提で、 BOOT_CFG1[5] が 1 の場合は MMCデバイスが繋っている前提で動作します。 i.MX6ULL には、SD/MMC のコントローラーである uSDHC が 2つ搭載されています。 Armadillo-610では、eMMC が uSDHC1に、 microSDカードが uSDHC2 に接続されています。ブート時にどちらのコントローラーからブートするかを決めている eFuse が 0x450[12:11] です。 0x450[12:11] が 00 であれば uSDHC1 つまりオンボード eMMC から、01 であれば uSDHC2 つまり microSDカードからブートします。言い換えると Armadillo-610 でオンボード eMMC からブートしたい場合は、0x450[5] を 1 に、 0x450[12:11] を 00 にします。逆に microSDカードから起動したい場合は 0x450[5] を 0 に、0x450[12:11] を 01 にします。 表6.15 ブートデバイスと eFuse ブートデバイス | eFuse 0x450[5] | 0x450[12:11] |
オンボード eMMC | 1
| 00
| microSDカード | 0
| 01
Armadillo-610 では、U-Boot のコマンドによって eFuseの書き換えをサポートしています。 「スライドスイッチの設定について」 を参照してU-Boot を保守モードで起動してください。 eFuse の書き換えは、 fuse コマンドを使います。 ![[注記]](images/note.png) | |
cmd/fuse.c
drivers/misc/mxc_ocotp.c
6.24.4. eFuse の設定によるブートデバイスの選択eFuse の設定によるブートデバイスの選択を可能にするには、 eFuse に書き込んだ値が正しいことを i.MX6ULL に教える必要があります。そのための eFuse が BT_FUSE_SEL (0x460[4] ) です。Armadillo-610 では、このビットが 1 であれば、GPIO による override が無効になり eFuse の設定にしたがってブートデバイスが選択されるようになります。 オンボード eMMC からだけブートさせたい場合は、ブートデバイスの種類で MMC と、コントローラーで uSDHC1 を選択することで可能です。忘れずに BT_FUSE_SEL を 1 にします。 オンボード eMMC のスペックは、以下の通りです。リファレンスマニュアル 8.5.3 Expansion device および 表「5-6. MMC/eMMC Boot Fusemap」を確認してください。「可変」列が「不」となっている値は、変更しないでください。例えば、オンボード eMMC は 1.8 V に対応していません。 bit 9 の SD Voltage Selection で 1 の 1.8 V では動作しません。 表6.16 オンボード eMMC のスペック 名前 | Bit | eFuse | 値 | bit列 | 可変 |
| [15:13]
| Bus Width | 8 bit | 010
| 不 | [12:11]
| Port Select | uSDHC1 | 00
| 不 | [10]
| 可 | [9]
| 不 | [8]
| - | - | 0
| - | BOOT_CFG1
| [7:5]
| eMMC | - | 011
| 不 | [4]
| Fast Boot | Regular | 0
| 可 | [3]
| SD/MMC Speed | High | 0
| 不 | [2]
| 可 | [1]
| 可 | [0]
| 不 |
同じ要領で、SDからだけしかブートしないようにすることも可能です。しかし eFuse によるブートデバイスの固定は、意図しないブートを防ぐことが目的です。 Armadillo-610 で microSDからのブートに固定することは可能ですが、別の microSDカードを挿入されてしまうと、その別の microSDカードからブートしてしまうので目的を達成できません。理解してお使いください。 書き込んだ eFuse の値を変更されてしまっては、Boot From Fuseモードにしている意味がありません。i.MX6ULLでは eFuse を変更できなくするビットも用意されています。 リファレンスマニュアル「5.3 Fusemap Descriptions Table」を確認してください。 本章では、Armadillo-610のオプション品について説明します。 表6.17 Armadillo-610関連のオプション品 FT232RLを搭載したUSB-シリアル変換アダプタです。シリアルの信号レベルは3.3V CMOSです。 -
スライドスイッチの状態に対応した起動モードは以下のとおりです。 表6.18 USBシリアル変換アダプタのスライドスイッチによる起動モードの設定 スライドスイッチ | 起動モード |
故障の原因となる可能性があります。 |
6.25.2. Armadillo-610 拡張ボードArmadillo-610 拡張ボードはArmadillo-610を搭載する拡張ボードを設計開発するためのリファレンスボードです。
Armadillo-610 拡張ボードの主な仕様は次のとおりです。 表6.19 Armadillo-610 拡張ボードの仕様 LAN(Ethernet) | 100BASE-TX/10BASE-T x 1、AUTO-MDIX対応 | シリアル(UART) | 3.3V CMOSレベル x 1、RS485 x 1 | USB | USB 2.0 Host(High Speed) x 2、USB 2.0 OTG(High Speed) x 1 | SD | SDスロット x 1 [] | カレンダ時計 | リアルタイムクロック搭載、バックアップ用コネクタ搭載 [] | オーディオ | モノラルスピーカー出力 x 1 | ビデオ | LCDオプションセット(7インチタッチパネルWVGA液晶)接続可能 [] | 接点入出力 | 入力 x 2、出力 x 2 | Groveインターフェース | Groveコネクタ x 4 []
仕様や外観を予告なく変更する場合があります。 |
Armadillo-610 拡張ボードのブロック図は次のとおりです。 Armadillo-610 拡張ボードの電源回路の構成は次のとおりです。 Armadillo-610 拡張ボードのインターフェース仕様について説明します。 表6.20 Armadillo-610 拡張ボードのインターフェース一覧 [] 部品番号 | インターフェース名 | 型番 | メーカー |
CON1 | SDインターフェース | CIM-K03NS | MITSUMI ELECTRIC | CON2 | LANインターフェース | TM11R-5M2-88-LP | HIROSE ELECTRIC | CON3 | シリアルインターフェース | DF13A-7P-1.25H(51) | HIROSE ELECTRIC | CON4 | Armadillo-610インターフェース | DF40HC(3.0)-100DS-0.4V(51) | HIROSE ELECTRIC | CON5 | USBホストインターフェース | UBA-4RS-D14T-4D(LF)(SN) | J.S.T. Mfg. | CON6 | USB OTGインターフェース | UB-MC5ABR3-SD204-4S-1 | J.S.T. Mfg. | CON7 | Groveインターフェース | 1125R-4P | Shenzhen NS-TECH Co.,Ltd | CON8 | 1125R-4P | Shenzhen NS-TECH Co.,Ltd | CON9 | 1125R-4P | Shenzhen NS-TECH Co.,Ltd | CON10 | 1125R-4P | Shenzhen NS-TECH Co.,Ltd | CON11 | LCDインターフェース | XF2M-5015-1A | OMRON | CON12 | 電源入力インターフェース | PJ-102AH | CUI | CON13A | 電源出力インターフェース | TBL002A-350-14GY-2GY | CUI | CON13B | DIDOインターフェース | CON13C | RS485インターフェース | CON13D | オーディオインターフェース | CON14 | 電源出力インターフェース | A2-2PA-2.54DSA(71) | HIROSE ELECTRIC | CON15 | RTCバックアップインターフェース | CH7410-2032LF | TAKACHI | CON16 | B2B-EH(LF)(SN) | J.S.T. Mfg. | CON17 | 内蔵RTCバックアップインターフェース | B2B-EH(LF)(SN) | J.S.T. Mfg. | CON18 | WLANインターフェース | AXK6F34347YG | Panasonic | CON19 | 拡張インターフェース | XG4C-1031 | OMRON | CON20 | XG4C-4031 | OMRON | CON21 | XG4C-1031 | OMRON | CON22 | XG4C-1031 | OMRON | CON23 | リセットインターフェース | A2-2PA-2.54DSA(71) | HIROSE ELECTRIC | CON24 | 電源入力インターフェース | A2-6PA-2.54DSA(71) | HIROSE ELECTRIC | JP1 | 起動デバイス設定ジャンパ | A2-2PA-2.54DSA(71) | HIROSE ELECTRIC | SW1 | ユーザースイッチ | SKHLACA010 | ALPS ELECTRIC | SW2 | リセットスイッチ | SKHLACA010 | ALPS ELECTRIC | SW3 | ONOFFスイッチ | SKHLACA010 | ALPS ELECTRIC | LED1 | LANスピードLED | SML-310MTT86 | ROHM | LED2 | LAN リンクアクティビティ LED | SML-310YTT86 | ROHM | LED3 | ユーザー LED | SML-310MTT86 | ROHM | TH7 | Armadillo-610用スタッド | TH-1.6-3.0-M3 | Mac-Eight | TH8 | TH-1.6-3.0-M3 | Mac-Eight | TH13 | WLANモジュール用スタッド | TH-1.6-1.5-M2 | Mac-Eight | TH14 | TH-1.6-1.5-M2 | Mac-Eight |
6.25.2.5. CON1 (SDインターフェース)CON1はハイスピード(最大クロック周波数: 49.5MHz)に対応したSDインターフェースです。
同時に使用することはできません。
表6.21 CON1 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.25.2.6. CON2(LANインターフェース)CON2は10BASE-T/100BASE-TXに対応したLANインターフェースです。
AUTO-MDIX機能を搭載しており、ストレートケーブルまたはクロスケーブルを自動認識して送受信端子を切り替えます。 信号線はEthernet PHY(LAN8720AI-CP/Microchip Technology)を経由してi.MX6ULLのEthernetコントローラ(ENET1)に接続されます。 表6.22 CON2 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.25.2.7. CON3(シリアルインターフェース)CON3は非同期(調歩同期)シリアルインターフェースです。
また、両コネクタを水平にして挿入・抜去してください。
表6.23 CON3 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.25.2.8. CON4(Armadillo-610インターフェース)CON4はArmadillo-610と接続するためのインターフェースです。 表6.24 CON4 信号配列 ピン番号 | ピン名 | I/O | 説明 |
(High: 電源供給、Low: 電源切断) | 13 | RTC_INT_B | Out | リアルタイムクロック割り込み信号、リアルタイムクロックの割り込みピンに接続 | 14 | ADC_IN4 | In/Out | 拡張入出力、CON11の34ピン、CON20の37ピン、CON10の1ピンに接続 | 15 | ADC_IN3 | In/Out | 拡張入出力、CON11の35ピン、CON20の38ピン、CON9の1ピンに接続 | 16 | ADC_IN2 | In/Out | 拡張入出力、CON11の36ピン、CON20の39ピン、CON9の2ピンに接続 | 17 | ADC_IN1 | In/Out | 拡張入出力、CON11の37ピン、CON20の40ピン、CON10の2ピンに接続 | 18 | LCD_DATA00 | In/Out | 拡張入出力、CON11の13ピン、CON20の13ピンに接続 | 19 | LCD_DATA01 | In/Out | 拡張入出力、CON11の14ピン、CON20の14ピンに接続 | 20 | LCD_DATA02 | In/Out | 拡張入出力、CON11の15ピン、CON20の15ピンに接続 | 21 | LCD_DATA03 | In/Out | 拡張入出力、CON11の16ピン、CON20の16ピンに接続 | 22 | LCD_DATA04 | In/Out | 拡張入出力、CON11の17ピン、CON20の17ピンに接続 | 23 | LCD_DATA05 | In/Out | 拡張入出力、CON11の18ピン、CON20の18ピンに接続 | 24 | LCD_DATA06 | In/Out | 拡張入出力、CON11の20ピン、CON20の20ピンに接続 | 25 | LCD_DATA07 | In/Out | 拡張入出力、CON11の21ピン、CON20の21ピンに接続 | 26 | LCD_DATA08 | In/Out | 拡張入出力、CON11の22ピン、CON20の22ピンに接続 | 27 | LCD_DATA09 | In/Out | 拡張入出力、CON11の23ピン、CON20の23ピンに接続 | 28 | LCD_DATA10 | In/Out | 拡張入出力、CON11の24ピン、CON20の24ピンに接続 | 29 | LCD_DATA11 | In/Out | 拡張入出力、CON11の25ピン、CON20の25ピンに接続 | 30 | LCD_DATA12 | In/Out | 拡張入出力、CON11の27ピン、CON20の27ピンに接続 | 31 | LCD_DATA13 | In/Out | 拡張入出力、CON11の28ピン、CON20の28ピンに接続 | 32 | LCD_DATA14 | In/Out | 拡張入出力、CON11の29ピン、CON20の29ピンに接続 | 33 | LCD_DATA15 | In/Out | 拡張入出力、CON11の30ピン、CON20の30ピンに接続 | 34 | LCD_DATA16 | In/Out | 拡張入出力、CON11の31ピン、CON20の31ピンに接続 | 35 | LCD_DATA17 | In/Out | 拡張入出力、CON11の32ピン、CON20の32ピンに接続 | 36 | GND | Power | 電源(GND) | 37 | LCD_CLK | In/Out | 拡張入出力、CON11の8ピン、CON20の7ピンに接続 | 38 | LCD_HSYNC | In/Out | 拡張入出力、CON11の9ピン、CON20の8ピンに接続 | 39 | LCD_VSYNC | In/Out | 拡張入出力、CON11の10ピン、CON20の9ピンに接続 | 40 | LCD_ENABLE | In/Out | 拡張入出力、CON11の11ピン、CON20の10ピンに接続 | 41 | PWM5_OUT | In/Out | 拡張入出力、CON11の12ピン、CON20の11ピンに接続 | 42 | BJP1 | Out | 起動デバイス設定用信号、JP1に接続 | 43 | EXT_SW1 | Out | ユーザースイッチ、SW1に接続 | 44 | EXT_RESET_B | Out | システムリセット、CON23の1ピンに接続 | 45 | +3.3V_IO | Power | 電源(+3.3V_IO) | 46 | +3.3V_IO | Power | 電源(+3.3V_IO) | 47 | VIN | Power | 電源(VIN) | 48 | VIN | Power | 電源(VIN) | 49 | VIN | Power | 電源(VIN) | 50 | VIN | Power | 電源(VIN) | 51 | GND | Power | 電源(GND) | 52 | GND | Power | 電源(GND) | 53 | +5V_IO | Power | 電源(+5V_IO) | 54 | +5V_IO | Power | 電源(+5V_IO) | 55 | I2C2_SDA | In/Out | I2Cデータ信号、CON11の49ピン、CON21の10ピン、CON8の2ピン、リアルタイムクロックのSDAピンに接続 | 56 | I2C2_SCL | In | I2Cクロック信号、CON11の48ピン、CON21の9ピン、CON8の1ピン、リアルタイムクロックのSCLピンに接続 | 57 | SAI1_TX_SYNC | In/Out | 拡張入出力、CON11の47ピン、CON21の8ピンに接続 | 58 | SAI1_TX_BCLK | In/Out | 拡張入出力、CON11の46ピン、CON21の7ピンに接続 | 59 | SAI1_RX_DATA | In/Out | 拡張入出力、CON11の45ピン、CON21の6ピンに接続 | 60 | SAI1_TX_DATA | In/Out | 拡張入出力、CON11の44ピン、CON21の5ピンに接続 | 61 | SAI1_RX_SYNC | In/Out | 拡張入出力、CON11の43ピン、CON21の4ピンに接続 | 62 | SAI1_MCLK | In/Out | 拡張入出力、CON11の42ピン、CON21の3ピン、CON7の1ピンに接続 | 63 | GPIO4_IO24 | In/Out | 拡張入出力、CON11の41ピン、CON20の36ピンに接続 | 64 | GPIO4_IO21 | In/Out | 拡張入出力、CON11の40ピン、CON20の35ピンに接続 | 65 | GPIO4_IO18 | In/Out | 拡張入出力、CON11の39ピン、CON20の34ピンに接続 | 66 | RS485_DE | In | RS485送信イネーブル信号、RS485トランシーバのDEピン、CON22の6ピンに接続 | 67 | RS485_RE_N | In | RS485受信イネーブル信号、RS485トランシーバのREピン、CON22の5ピンに接続 | 68 | RS485_RX | Out | RS485受信データ、RS485トランシーバのROピン、CON22の4ピンに接続 | 69 | RS485_TX | In | RS485送信データ、RS485トランシーバのDIピン、CON22の3ピンに接続 | 70 | SD2_DATA3 | In/Out | SDデータバス(bit3)、CON1の1ピンに接続 | 71 | SD2_DATA2 | In/Out | SDデータバス(bit2)、CON1の9ピンに接続 | 72 | SD2_DATA1 | In/Out | SDデータバス(bit1)、CON1の8ピンに接続 | 73 | SD2_DATA0 | In/Out | SDデータバス(bit0)、CON1の7ピンに接続 | 74 | SD2_CLK | In | SDクロック、CON1の5ピンに接続 | 75 | GND | Power | 電源(GND) | 76 | SD2_CMD | In/Out | SDコマンド/レスポンス、CON1の2ピンに接続 | 77 | PWRON | Out | パワーマネジメントICのPWRON信号、SW2に接続 | 78 | ONOFF | Out | i.MX6ULLのON/OFF信号、SW3に接続 | 79 | RTC_BAT | Power | 電源(RTC_BAT)、CON17の1ピンに接続 | 80 | EXT_LED1 | In | LED3に接続(High: 点灯、Low: 消灯) | 81 | AMP_SD_B | In | オーディオアンプのシャットダウンピンに接続
6.25.2.9. CON5(USBホストインターフェース)CON5はUSBホストインターフェースです。
表6.25 CON5 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.25.2.10. CON6(USB OTGインターフェース)CON6はUSB OTGインターフェースです。
表6.26 CON6 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.25.2.11. CON7、CON8、CON9、CON10(Groveインターフェース)CON7、CON8、CON9、CON10はSeeed社が推奨するコネクタ規格「Groveシステム」に対応した
共通の信号線が接続されているため、同時に使用できません。
マルチプレクスの設定を変更する際には、ご注意ください。 |
表6.27 CON7 信号配列 ピン番号 | ピン名 | I/O | 説明 |
表6.28 CON8 信号配列 ピン番号 | ピン名 | I/O | 説明 |
表6.29 CON9 信号配列 ピン番号 | ピン名 | I/O | 説明 |
表6.30 CON10 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.25.2.12. CON11(LCDインターフェース)CON11はデジタルRGB入力を持つ液晶パネルモジュールなどを接続することができる、LCDインターフェースです。
基板上のリアルタイムクロックが使用できなくなります。 |
アドレスが被っているため、アクセスすると信号が衝突します。
表6.31 CON11 信号配列 ピン番号 | ピン名 | I/O | 説明 |
1 | +5V | Power | 電源出力(+5V) | 2 | +5V | Power | 電源出力(+5V) | 3 | +5V | Power | 電源出力(+5V) | 4 | +3.3V | Power | 電源出力(+3.3V) | 5 | +3.3V | Power | 電源出力(+3.3V) | 6 | GND | Power | 電源(GND) | 7 | GND | Power | 電源(GND) | 8 | LCD_CLK | In/Out | 拡張入出力、i.MX6ULLのLCD_CLKピンに接続 | 9 | LCD_HSYNC | In/Out | 拡張入出力、i.MX6ULLのLCD_HSYNCピンに接続 | 10 | LCD_VSYNC | In/Out | 拡張入出力、i.MX6ULLのLCD_VSYNCピンに接続 | 11 | LCD_ENABLE | In/Out | 拡張入出力、i.MX6ULLのLCD_ENABLEピンに接続 | 12 | PWM5_OUT | In/Out | 拡張入出力、i.MX6ULLのNAND_DQSピンに接続 | 13 | LCD_DATA00 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA00ピンに接続 | 14 | LCD_DATA01 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA01ピンに接続 | 15 | LCD_DATA02 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA02ピンに接続 | 16 | LCD_DATA03 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA03ピンに接続 | 17 | LCD_DATA04 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA04ピンに接続 | 18 | LCD_DATA05 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA05ピンに接続 | 19 | GND | Power | 電源(GND) | 20 | LCD_DATA06 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA06ピンに接続 | 21 | LCD_DATA07 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA07ピンに接続 | 22 | LCD_DATA08 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA08ピンに接続 | 23 | LCD_DATA09 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA09ピンに接続 | 24 | LCD_DATA10 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA10ピンに接続 | 25 | LCD_DATA11 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA11ピンに接続 | 26 | GND | Power | 電源(GND) | 27 | LCD_DATA12 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA12ピンに接続 | 28 | LCD_DATA13 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA13ピンに接続 | 29 | LCD_DATA14 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA14ピンに接続 | 30 | LCD_DATA15 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA15ピンに接続 | 31 | LCD_DATA16 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA16ピンに接続 | 32 | LCD_DATA17 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA17ピンに接続 | 33 | GND | Power | 電源(GND) | 34 | ADC_IN4 | In/Out | 拡張入出力、i.MX6ULLのGPIO1_IO04ピンに接続、0.01uFのコンデンサが接続されています。 | 35 | ADC_IN3 | In/Out | 拡張入出力、i.MX6ULLのGPIO1_IO03ピンに接続、0.01uFのコンデンサが接続されています。 | 36 | ADC_IN2 | In/Out | 拡張入出力、i.MX6ULLのGPIO1_IO02ピンに接続、0.01uFのコンデンサが接続されています。 | 37 | ADC_IN1 | In/Out | 拡張入出力、i.MX6ULLのGPIO1_IO01ピンに接続、0.01uFのコンデンサが接続されています。 | 38 | GND | Power | 電源(GND) | 39 | GPIO4_IO18 | In/Out | 拡張入出力、i.MX6ULLのCSI_PIXCLKピンに接続 | 40 | GPIO4_IO21 | In/Out | 拡張入出力、i.MX6ULLのCSI_DATA00ピンに接続 | 41 | GPIO4_IO24 | In/Out | 拡張入出力、i.MX6ULLのCSI_DATA03ピンに接続 | 42 | SAI1_MCLK | In/Out | 拡張入出力、i.MX6ULLのCSI_DATA01ピンに接続 | 43 | SAI1_RX_SYNC | In/Out | 拡張入出力、i.MX6ULLのCSI_DATA02ピンに接続 | 44 | SAI1_TX_DATA | In/Out | 拡張入出力、i.MX6ULLのCSI_DATA07ピンに接続 | 45 | SAI1_RX_DATA | In/Out | 拡張入出力、i.MX6ULLのCSI_DATA06ピンに接続 | 46 | SAI1_TX_BCLK | In/Out | 拡張入出力、i.MX6ULLのCSI_DATA05ピンに接続 | 47 | SAI1_TX_SYNC | In/Out | 拡張入出力、i.MX6ULLのCSI_DATA04ピンに接続 | 48 | I2C2_SCL | In/Out | 拡張入出力、i.MX6ULLのCSI_HSYNCピンに接続 | 49 | I2C2_SDA | In/Out | 拡張入出力、i.MX6ULLのCSI_VSYNCピンに接続 | 50 | GND | Power | 電源(GND) |
6.25.2.13. CON12(電源入力インターフェース)CON12は電源供給用のインターフェースです。
DCジャックが実装されており、図6.149「ACアダプタの極性マーク」と同じ極性マークのあるACアダプタが使用できます。 ![[警告]](images/warning.png) | |
突入電流により、故障する可能性があります。 |
表6.32 CON12 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.25.2.14. CON13A(電源出力インターフェース)CON13Aは電源出力用インターフェースです。
電源入力として使用することも可能ですが、
同時にCON12から電源供給しないようご注意ください。 |
表6.33 CON13A 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.25.2.15. CON13B(DIDOインターフェース)CON13Bは絶縁デジタル入出力インターフェースです。 デジタル入力部はフォトカプラによる絶縁入力となっています。
出力部を駆動するためには外部に電源が必要となります。
表6.34 CON13B 信号配列 ピン番号 | ピン名 | I/O | 説明 |
CON13の3ピンのGND_ISOは絶縁されています。 |
6.25.2.16. CON13C(RS485インターフェース)CON13CはRS485(半二重)のシリアルインターフェースです。
信号線はRS485トランシーバを経由して、i.MX6ULLのUARTコントローラ(UART2)に接続されています。 表6.35 CON13C 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.25.2.17. CON13D(オーディオインターフェース)CON13Dはモノラルのオーディオ出力インターフェースです。
表6.36 CON13D 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.25.2.18. CON14(電源出力インターフェース)CON14は電源出力インターフェースです。
Armadillo-610で生成する+5V_IOが接続されています。 表6.37 CON14 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.25.2.19. CON15、CON16(RTCバックアップインターフェース)CON15、CON16はArmadillo-610 拡張ボードに搭載している
時刻データを保持することが可能です。 Armadillo-610 拡張ボードに搭載しているリアルタイムクロックは、i.MX6ULL内蔵のリアルタイムクロックよりも消費電力が少なく、精度が良いものとなっております。 表6.38 CON16 信号配列 ピン番号 | ピン名 | I/O | 説明 |
表6.39 CON15、CON16 対応電池の例とバックアップ時間 対応電池 | バックアップ時間(参考値) |
CR2032 | 6.2年 |
時間精度は周囲温度に大きく影響を受けますので、
ご使用の際は十分に特性の確認をお願いします。 |
リチウムコイン電池以外から電源を供給する場合、
6.25.2.20. CON17(内蔵RTCバックアップインターフェース)CON17はi.MX6ULLの低消費電力ドメインにあるSRTC(Secure Real Time Clock)のデータ等を保持するための
ONOFFピンの制御による電源のON
詳細は、「外部からの電源制御」参照してください。 -
詳細は、「起床要因を有効化する」を参照してください。 -
詳細は、「起床要因を有効化する」を参照してください。 表6.40 CON17 信号配列 ピン番号 | ピン名 | I/O | 説明 |
表6.41 CON17 対応電池の例とバックアップ時間 対応電池 | バックアップ時間(参考値) |
CR2032 | 約4か月 [] |
入力電圧範囲内でご使用ください。 |
6.25.2.21. CON18(WLANインターフェース)CON18はArmadillo-WLANモジュール(AWL13)接続用のインターフェースです。AWL13はArmadillo Base OS で非対応の為、利用することができません。 無線LAN機能を拡張する場合、動作確認済みデバイスである、Ezurio製のSterling LWB5+での拡張がおすすめです。
表6.42 CON18 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.25.2.22. CON19(拡張インターフェース)CON19はSD用の機能を割り当て可能な信号線を接続した、
同時に使用できません。
表6.43 CON19 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.25.2.23. CON20(拡張インターフェース)CON20は主にLCDやタッチパネル用の機能を割り当て可能な信号線を接続した、
表6.44 CON20 信号配列 ピン番号 | ピン名 | I/O | 説明 |
1 | +5V | Power | 電源出力(+5V) | 2 | +5V | Power | 電源出力(+5V) | 3 | +3.3V | Power | 電源出力(+3.3V) | 4 | +3.3V | Power | 電源出力(+3.3V) | 5 | GND | Power | 電源(GND) | 6 | GND | Power | 電源(GND) | 7 | LCD_CLK | In/Out | 拡張入出力、i.MX6ULLのLCD_CLKピンに接続 | 8 | LCD_HSYNC | In/Out | 拡張入出力、i.MX6ULLのLCD_HSYNCピンに接続 | 9 | LCD_VSYNC | In/Out | 拡張入出力、i.MX6ULLのLCD_VSYNCピンに接続 | 10 | LCD_ENABLE | In/Out | 拡張入出力、i.MX6ULLのLCD_ENABLEピンに接続 | 11 | PWM5_OUT | In/Out | 拡張入出力、i.MX6ULLのNAND_DQSピンに接続 | 12 | GND | Power | 電源(GND) | 13 | LCD_DATA00 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA00ピンに接続 | 14 | LCD_DATA01 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA01ピンに接続 | 15 | LCD_DATA02 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA02ピンに接続 | 16 | LCD_DATA03 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA03ピンに接続 | 17 | LCD_DATA04 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA04ピンに接続 | 18 | LCD_DATA05 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA05ピンに接続 | 19 | GND | Power | 電源(GND) | 20 | LCD_DATA06 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA06ピンに接続 | 21 | LCD_DATA07 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA07ピンに接続 | 22 | LCD_DATA08 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA08ピンに接続 | 23 | LCD_DATA09 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA09ピンに接続 | 24 | LCD_DATA10 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA10ピンに接続 | 25 | LCD_DATA11 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA11ピンに接続 | 26 | GND | Power | 電源(GND) | 27 | LCD_DATA12 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA12ピンに接続 | 28 | LCD_DATA13 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA13ピンに接続 | 29 | LCD_DATA14 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA14ピンに接続 | 30 | LCD_DATA15 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA15ピンに接続 | 31 | LCD_DATA16 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA16ピンに接続 | 32 | LCD_DATA17 | In/Out | 拡張入出力、i.MX6ULLのLCD_DATA17ピンに接続 | 33 | GND | Power | 電源(GND) | 34 | GPIO4_IO18 | In/Out | 拡張入出力、i.MX6ULLのCSI_PIXCLKピンに接続 | 35 | GPIO4_IO21 | In/Out | 拡張入出力、i.MX6ULLのCSI_DATA00ピンに接続 | 36 | GPIO4_IO24 | In/Out | 拡張入出力、i.MX6ULLのCSI_DATA03ピンに接続 | 37 | ADC_IN4 | In/Out | 拡張入出力、i.MX6ULLのGPIO1_IO04ピンに接続、0.01uFのコンデンサが接続されています。 | 38 | ADC_IN3 | In/Out | 拡張入出力、i.MX6ULLのGPIO1_IO03ピンに接続、0.01uFのコンデンサが接続されています。 | 39 | ADC_IN2 | In/Out | 拡張入出力、i.MX6ULLのGPIO1_IO02ピンに接続、0.01uFのコンデンサが接続されています。 | 40 | ADC_IN1 | In/Out | 拡張入出力、i.MX6ULLのGPIO1_IO01ピンに接続、0.01uFのコンデンサが接続されています。 |
6.25.2.24. CON21(拡張インターフェース)CON21は主にオーディオ用の機能を割り当て可能な信号線を接続した、
表6.45 CON21 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.25.2.25. CON22(拡張インターフェース)CON22はSPI、I2C、UART等に割り当て可能な信号線を接続した、拡張用インターフェースです。 ![[警告]](images/warning.png) | |
同時に使用できません。
表6.46 CON22 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.25.2.26. CON23(リセットインターフェース)CON23はリセット入出力用のインターフェースです。
EXT_RESET_NピンはArmadillo-610上のパワーマネジメントICのRESETBMCUピン、i.MX6ULLのPOR_Bピンに接続されています。 リセット回路の詳細につきましては、図3.44「リセット回路の構成」をご参照ください。 表6.47 CON23 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.25.2.27. CON24(電源入力インターフェース)CON24は電源供給用のインターフェースです。
電源回路の詳細につきましては、図6.138「Armadillo-610 拡張ボードの電源回路の構成」をご参照ください。 ![[ティップ]](images/tip.png) | |
電源を供給することが可能になります。
表6.48 CON24 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.25.2.28. JP1(起動デバイス設定ジャンパ)JP1は起動デバイス設定ジャンパです。
JP1の状態で、起動デバイスを設定することができます。 表6.49 JP1 信号配列 部品番号 | 説明 |
表6.50 ジャンパの設定と起動デバイス JP1 | 起動デバイス |
eFUSEは一度書き込むと元に戻すことができません。
細心の注意を払って書き込みを行うようお願いいたします。
SW1はユーザー側で自由に利用できる押しボタンスイッチです。 表6.51 SW1 信号配列 部品番号 | 説明 |
SW2はリセット用の押しボタンスイッチです。
ボタンを押すとパワーマネジメントICからの電源が切断されます。 動作の詳細については、「外部からの電源制御」をご確認ください。 表6.52 SW2 信号配列 部品番号 | 説明 |
6.25.2.31. SW3(ONOFFスイッチ)SW3はボタンの長押しで電源を制御する押しボタンスイッチです。 動作の詳細については、「外部からの電源制御」をご確認ください。 表6.53 SW3 信号配列 部品番号 | 説明 |
SW3 | i.MX6ULLのONOFFピンに接続 |
6.25.2.32. LED1、LED2(LAN LED)LED1、LED2はCON2(LANインターフェース)のステータスLEDです。CON2(LANインターフェース)の上部に表示されます。
信号線はEthernet PHY(LAN8720AI-CP/Microchip Technology)のLEDピンに接続されます。 表6.54 LAN LEDの動作 LED | 名称(色) | 状態 | 説明 |
LED3ユーザー側で自由に利用できるLEDです。 表6.55 LED3 部品番号 | 名称(色) | 説明 |
6.25.3. LCDオプションセット(7インチタッチパネルWVGA液晶)ノリタケ伊勢電子製のタッチパネルLCDとフレキシブルフラットケーブル(FFC)のセットです。
表6.56 LCDオプションセット(7インチタッチパネルWVGA液晶)について 商品名 | LCDオプションセット(7インチタッチパネルWVGA液晶) | 型番 | OP-LCD70EXT-L00 | 内容 | 7インチ タッチパネルLCD、FFC |
表6.57 LCDの仕様 型番 | GT800X480A-1013P | メーカー | ノリタケ伊勢電子 | タイプ | TFT-LCD | 表示サイズ | 7インチ | 外形サイズ | 164.8 x 99.8 mm | 解像度 | 800 x 480 pixels | 表示色数 | 約1677万色 | 使用温度範囲 | -20〜+70℃ | 輝度 | 850cd/m2 (Typ.) 25℃ | 電源 | DC 5V±5%/500mA (Typ.), DC 3.3V±3%/35mA (Typ.) | 映像入力インターフェース | RGBパラレル(18bit/24bit)[] | タッチパネルインターフェース | I2C(HID準拠) | タッチ方式 | 投影型静電容量方式 | マルチタッチ | 最大10点対応 |
6.25.4. Armadillo-400シリーズLCDオプションセット4.3インチタッチパネルLCD、LCD拡張ボード、フレキシブルフラットケーブル(FFC)のセットです。 LCD拡張ボードにはLCD接続インターフェースの他にオーディオコーデック、リアルタイムクロック(RTC)を搭載しています。
表6.58 Armadillo-400シリーズLCDオプションセットについて 商品名 | Armadillo-400シリーズLCDオプションセット | 型番 | OP-A400-LCD43EXT-L01 | 内容 | 4.3インチ タッチパネルLCD、FFC、LCD固定用両面テープ |
表6.59 LCD拡張ボードの仕様 LCD | 型番 | FG040346DSSWBG04 [] | メーカー | Data Image | LCDバックライト | バックライト用LEDドライバ搭載 | オーディオ | 型番 | WM8978GEFL/V | メーカー | Wolfson | リアルタイムクロック | 型番 | S-35390A | メーカー | ABLIC | RTCバックアップ | 300秒(Typ.)、60秒(Min.)、電池ホルダ搭載、外部バッテリ接続コネクタ搭載可能(対応電池: CR2032等) | RTC平均月差(参考値) | 約30秒@25℃ | 電源電圧 | DC 3.3±0.2V(メイン電源)、DC 2.8〜5.5V(LCDバックライト)、DC 2.0〜3.5V(RTCバックアップ) | 消費電力 | 約0.8W(LCD消費分を含む) | 使用温度範囲 | -20~+70℃(結露なきこと) | 外形サイズ | 106 x 82 mm(突起部を除く) |
表6.60 LCDの仕様 型番 | FG040346DSSWBG04 | メーカー | Data Image | タイプ | TFT-LCD | 表示サイズ | 4.3インチ | 外形サイズ | 105.5(W) x 67.2(H) x 4.3(D) mm | 解像度 | 480 x 272 pixels | 表示色数 | 約1677万色 | 使用温度範囲 | -20〜+70℃ | 輝度 | 320cd/m2 (Typ.) | 映像入力インターフェース | RGBパラレル(24bit)[] | タッチ方式 | 4線抵抗膜方式 |
ご確認ください。 |
LCD拡張ボードのインターフェース仕様について説明します。 表6.61 LCD拡張ボード インターフェース一覧 [] 部品番号 | インターフェース名 | 型番 | メーカー |
CON1 | Armadillo接続インターフェース | XF2M-5015-1A | OMRON | CON2 | LCD拡張インターフェース(専用) | FH19SC-40S-0.5SH(05) | HIROSE ELECTRIC | CON3 | モノラルマイク入力 | SJ-3524-SMT | CUI Inc | CON4 | ステレオヘッドホン出力 | SJ-3524-SMT | CUI Inc | CON5 | スピーカー出力 | S2B-PH-K-S(LF)(SN) | J.S.T.Mfg. | CON6 | LCD拡張インターフェース(汎用) | RF-H402TD-1130 | J.S.T.Mfg. | CON7 | 拡張インターフェース | RF-H102TD-1130 | J.S.T.Mfg. | CON8 | RTCバックアップインターフェース | HU2032 | TAKACHI | CON9 | DF13-2P-1.25DS(20) | HIROSE ELECTRIC | CON10 | B2B-EH(LF)(SN) | J.S.T.Mfg. | SW1 | ユーザースイッチ | SKHHLMA010 | ALPS | SW2 | SKHHLMA010 | ALPS | SW3 | SKHHLMA010 | ALPS | SW4 | SKHHLMA010 | ALPS | SW5 | SKHHLMA010 | ALPS | SW6 | SKHHLMA010 | ALPS | LED1 | 電源LED | SML-310MT | ROHM | LED2 | ユーザーLED | OSNG3133A | OPTO SUPPLY | LED3 | OSNG3133A | OPTO SUPPLY |
6.25.4.4. CON1(Armadillo接続インターフェース)CON1はArmadilloと接続するためのインターフェースです。50ピン(0.5mmピッチ)のフレキシブルフ
ラットケーブルにより、LCDインターフェース(Armadillo-610 拡張ボード: CON11)と接続可能です。 LCD、タッチパネル、オーディオコーデック、リアルタイムクロックの各信号線が接続されています。 表6.62 CON1 信号配列 ピン番号 | ピン名 | I/O | 説明 |
1 | GND | Power | 電源(GND) | 2 | I2C3_SDA | In/Out | コーデック I2Cデータ、コーデックのSDINピンに接続、1kΩプルアップ(+3.3V) | 3 | I2C3_SCL | In | コーデック I2Cクロック、コーデック ICのSCLKピンに接続、1kΩプルアップ(+3.3V) | 4 | AUD5_TXFS | In | コーデック TXFS、コーデックのLRCピンに接続 | 5 | AUD5_TXC | In | コーデック TXC、コーデックのBCLKピンに接続 | 6 | AUD5_RXD | Out | コーデック RXD、コーデックのADCDATピンに接続 | 7 | AUD5_TXD | In | コーデック TXD、コーデックのDACDAT ピンに接続 | 8 | AUD_RXFS | In/Out | R50の実装によりリアルタイムクロックの割り込みピンに接続 | 9 | AUD5_SYSCLK | In | コーデック SYSCLK、コーデックのMCLKピンに接続 | 10 | GPIO2_30 | In/Out | タクトスイッチ出力、SW3の2ピン、CON6の7ピンに接続 | 11 | GPIO2_29 | In/Out | タクトスイッチ出力、SW2の2ピン、CON6の8ピンに接続 | 12 | GPIO2_20 | In/Out | タクトスイッチ出力、SW1の2ピン、CON6の9ピンに接続 | 13 | GND | Power | 電源(GND) | 14 | TOUCH_YN | In/Out | タッチパネル YN、CON2の40ピン、CON6の10ピンに接続 | 15 | TOUCH_YP | In/Out | タッチパネル YP、CON2の38ピン、CON6の11ピンに接続 | 16 | TOUCH_XN | In/Out | タッチパネル XN、CON2の39ピン、CON6の12ピンに接続 | 17 | TOUCH_XP | In/Out | タッチパネル XP、CON2の37ピン、CON6の13ピンに接続 | 18 | GND | Power | 電源(GND) | 19 | LCD_LD17 | In | LCD 拡張 I/F LD17、CON2の12ピン、CON6の15 ピンに接続 | 20 | LCD_LD16 | In | LCD 拡張 I/F LD16、CON2の11ピン、CON6の16ピンに接続 | 21 | LCD_LD15 | In | LCD 拡張 I/F LD15、CON2の10ピン、CON6の17ピンに接続 | 22 | LCD_LD14 | In | LCD 拡張 I/F LD14、CON2の9ピン、CON6の18ピンに接続 | 23 | LCD_LD13 | In | LCD 拡張 I/F LD13、CON2の8ピン、CON6の19ピンに接続 | 24 | LCD_LD12 | In | LCD 拡張 I/F LD12、CON2の7ピン、CON6の20ピンに接続 | 25 | GND | Power | 電源(GND) | 26 | LCD_LD11 | In | LCD 拡張 I/F LD11、CON2の20ピン、CON6の22ピンに接続 | 27 | LCD_LD10 | In | LCD 拡張 I/F LD10、CON2の19ピン、CON6の23ピンに接続 | 28 | LCD_LD9 | In | LCD 拡張 I/F LD9、CON2の18ピン、CON6の24ピンに接続 | 29 | LCD_LD8 | In | LCD 拡張 I/F LD8、CON2の17ピン、CON6の25ピンに接続 | 30 | LCD_LD7 | In | LCD 拡張 I/F LD7、CON2の16ピン、CON6の26ピンに接続 | 31 | LCD_LD6 | In | LCD 拡張 I/F LD6、CON2の15ピン、CON6の27ピンに接続 | 32 | GND | Power | 電源(GND) | 33 | LCD_LD5 | In | LCD 拡張 I/F LD4、CON2の28ピン、CON6の29ピンに接続 | 34 | LCD_LD4 | In | LCD 拡張 I/F LD4、CON2の27ピン、CON6の30ピンに接続 | 35 | LCD_LD3 | In | LCD 拡張 I/F LD3、CON2の26ピン、CON6の31ピンに接続 | 36 | LCD_LD2 | In | LCD 拡張 I/F LD2、CON2の25ピン、CON6の32ピンに接続 | 37 | LCD_LD1 | In | LCD 拡張 I/F LD1、CON2の24ピン、CON6の33ピンに接続 | 38 | LCD_LD0 | In | LCD 拡張 I/F LD0、CON2の23ピン、CON6の34ピンに接続 | 39 | PWMO1 | In | LCD 拡張 I/F PWMO1、CON6の36ピン、LEDドライバのFBピンに接続 | 40 | LCD_OE_ACD | In | LCD 拡張 I/F OE_ACD、CON2の34ピン、CON6の37 ピンに接続 | 41 | LCD_VSYN | In | LCD 拡張 I/F VSYN、CON2の33ピン、CON6の38ピンに接続 | 42 | LCD_HSYN | In | LCD 拡張 I/F HSYN、CON2の32ピン、CON6の39ピンに接続 | 43 | LCD_LSCLK | In | LCD 拡張 I/F LSCLK、CON2の30ピン、CON6の40ピンに接続 | 44 | GND | Power | 電源(GND) | 45 | GND | Power | 電源(GND) | 46 | +3.3V | Power | 電源(+3.3V) | 47 | +3.3V | Power | 電源(+3.3V) | 48 | VIN | Power | 電源(VIN) | 49 | VIN | Power | 電源(VIN) | 50 | VIN | Powe | 電源(VIN) |
6.25.4.5. CON2(LCD拡張インターフェース)CON2はLCD(FG040346DSSWBG04/Data Image)と接続するためのインターフェースです。 ![[警告]](images/warning.png) | |
表6.63 CON2 信号配列 ピン番号 | ピン名 | I/O | 説明 |
1 | BL_LED_K | Power | LEDドライバ電源(ー端子) | 2 | BL_LED_A | Power | LEDドライバ電源(+端子) | 3 | GND | Power | 電源(GND) | 4 | +3.3V | Power | 電源(+3.3V) | 5 | GND | Power | 電源(GND) | 6 | GND | Power | 電源(GND) | 7 | LCD_LD12 | Out | LCD 拡張 I/F LD12、CON1の24ピン、CON6の20ピンに接続 | 8 | LCD_LD13 | Out | LCD 拡張 I/F LD13、CON1の23ピン、CON6の19ピンに接続 | 9 | LCD_LD14 | Out | LCD 拡張 I/F LD14、CON1の22ピン、CON6の18ピンに接続 | 10 | LCD_LD15 | Out | LCD 拡張 I/F LD15、CON1の21ピン、CON6の17ピンに接続 | 11 | LCD_LD16 | Out | LCD 拡張 I/F LD16、CON1の20ピン、CON6の16ピンに接続 | 12 | LCD_LD17 | Out | LCD 拡張 I/F LD17、CON1の19ピン、CON6の15ピンに接続 | 13 | GND | Power | 電源(GND) | 14 | GND | Power | 電源(GND) | 15 | LCD_LD6 | Out | LCD 拡張 I/F LD6、CON1の31ピン、CON6の27ピンに接続 | 16 | LCD_LD7 | Out | LCD 拡張 I/F LD7、CON1の30ピン、CON6の26ピンに接続 | 17 | LCD_LD8 | Out | LCD 拡張 I/F LD8、CON1の29ピン、CON6の25ピンに接続 | 18 | LCD_LD9 | Out | LCD 拡張 I/F LD9、CON1の28ピン、CON6の24ピンに接続 | 19 | LCD_LD10 | Out | LCD 拡張 I/F LD10、CON1の27ピン、CON6の23ピンに接続 | 20 | LCD_LD11 | Out | LCD 拡張 I/F LD11、CON1の26ピン、CON6の22ピンに接続 | 21 | GND | Power | 電源(GND) | 22 | GND | Power | 電源(GND) | 23 | LCD_LD0 | Out | LCD 拡張 I/F LD0、CON1の38ピン、CON6の34ピンに接続 | 24 | LCD_LD1 | Out | LCD 拡張 I/F LD1、CON1の37ピン、CON6の33ピンに接続 | 25 | LCD_LD2 | Out | LCD 拡張 I/F LD2、CON1の36ピン、CON6の32ピンに接続 | 26 | LCD_LD3 | Out | LCD 拡張 I/F LD3、CON1の35ピン、CON6の31ピンに接続 | 27 | LCD_LD4 | Out | LCD 拡張 I/F LD4、CON1の34ピン、CON6の30ピンに接続 | 28 | LCD_LD5 | Out | LCD 拡張 I/F LD5、CON1の33ピン、CON6の29ピンに接続 | 29 | GND | Power | 電源(GND) | 30 | DISP | In/Out | 10kΩプルアップ(+3.3V) | 31 | LCD_LSCLK | Out | LCD 拡張 I/F LSCLK、CON1の43ピン、CON6の40ピンに接続 | 32 | LCD_HSYN | Out | LCD 拡張 I/F HSYN、CON1の42ピン、CON6の39ピンに接続 | 33 | LCD_VSYN | Out | LCD 拡張 I/F VSYN、CON1の41ピン、CON6の38ピンに接続 | 34 | LCD_OE_ACD | Out | LCD 拡張 I/F OE_ACD、CON1の40ピン、CON6の37ピンに接続 | 35 | NC | ー | ー | 36 | GND | Power | 電源(GND) | 37 | TOUCH_XP | In/Out | タッチパネル XP、 CON1の17ピン、CON6の13ピンに接続 | 38 | TOUCH_YP | In/Out | タッチパネル YP、 CON1の15ピン、CON6の11ピンに接続 | 39 | TOUCH_XN | In/Out | タッチパネル XN、 CON1の16ピン、CON6の12ピンに接続 | 40 | TOUCH_YN | In/Out | タッチパネル YN、 CON1の14ピン、CON6の10ピンに接続 |
6.25.4.6. CON3(モノラルマイク入力)CON3はモノラルマイク入力です。 表6.64 CON3 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.25.4.7. CON4(ステレオヘッドホン出力)CON4はステレオヘッドホン出力です。 表6.65 CON4 信号配列 ピン番号 | ピン名 | I/O | 説明 |
CON5はスピーカー出力です。部品は実装されていません。 表6.66 CON5 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.25.4.9. CON6(LCD拡張インターフェース)CON6はLCDと接続するためのインターフェースです。部品は実装されていません。 ![[警告]](images/warning.png) | |
表6.67 CON6 信号配列 ピン番号 | ピン名 | I/O | 説明 |
1 | VIN | Power | 電源(VIN) | 2 | VIN | Power | 電源(VIN) | 3 | +3.3V | Power | 電源(+3.3V) | 4 | +3.3V | Power | 電源(+3.3V) | 5 | GND | Power | 電源(GND) | 6 | GND | Power | 電源(GND) | 7 | GPIO2_30 | In/Out | タクトスイッチ出力、SW3の2ピン、CON1の10ピンに接続 | 8 | GPIO2_29 | In/Out | タクトスイッチ出力、SW2の2ピン、CON1の11ピンに接続 | 9 | GPIO2_20 | In/Out | タクトスイッチ出力、SW1の2ピン、CON1の12ピンに接続 | 10 | TOUCH_YN | In/Out | タッチパネル YN、 CON1の14ピン、CON1の40ピンに接続 | 11 | TOUCH_YP | In/Out | タッチパネル YP、 CON1の15ピン、CON1の38ピンに接続 | 12 | TOUCH_XN | In/Out | タッチパネル XN、 CON1の16ピン、CON1の39ピンに接続 | 13 | TOUCH_XP | In/Out | タッチパネル XP、 CON1の17ピン、CON1の37ピンに接続 | 14 | GND | Power | 電源(GND) | 15 | LCD_LD17 | Out | LCD 拡張 I/F LD17、CON2の12 ピン、CON1の19ピンに接続 | 16 | LCD_LD16 | Out | LCD 拡張 I/F LD16、CON2の11 ピン、CON1の20ピンに接続 | 17 | LCD_LD15 | Out | LCD 拡張 I/F LD15、CON2の10 ピン、CON1の21ピンに接続 | 18 | LCD_LD14 | Out | LCD 拡張 I/F LD14、CON2の9 ピン、CON1の22ピンに接続 | 19 | LCD_LD13 | Out | LCD 拡張 I/F LD13、CON2の8 ピン、CON1の23ピンに接続 | 20 | LCD_LD12 | Out | LCD 拡張 I/F LD12、CON2の7 ピン、CON1の24ピンに接続 | 21 | GND | Power | 電源(GND) | 22 | LCD_LD11 | Out | LCD 拡張 I/F LD11、CON2の20ピン、CON1の26ピンに接続 | 23 | LCD_LD10 | Out | LCD 拡張 I/F LD10、CON2の19ピン、CON1の27ピンに接続 | 24 | LCD_LD9 | Out | LCD 拡張 I/F LD9、CON2の18ピン、CON1の28ピンに接続 | 25 | LCD_LD8 | Out | LCD 拡張 I/F LD8、CON2の17ピン、CON1の29ピンに接続 | 26 | LCD_LD7 | Out | LCD 拡張 I/F LD7、CON2の16ピン、CON1の30ピンに接続 | 27 | LCD_LD6 | Out | LCD 拡張 I/F LD6、CON2の15ピン、CON1の31ピンに接続 | 28 | GND | Power | 電源(GND) | 29 | LCD_LD5 | Out | LCD 拡張 I/F LD5、CON2の28ピン、CON1の33ピンに接続 | 30 | LCD_LD4 | Out | LCD 拡張 I/F LD4、CON2の27ピン、CON1の34ピンに接続 | 31 | LCD_LD3 | Out | LCD 拡張 I/F LD3、CON2の26ピン、CON1の35ピンに接続 | 32 | LCD_LD2 | Out | LCD 拡張 I/F LD2、CON2の25ピン、CON1の36ピンに接続 | 33 | LCD_LD1 | Out | LCD 拡張 I/F LD1、CON2の24ピン、CON1の37ピンに接続 | 34 | LCD_LD0 | Out | LCD 拡張 I/F LD0、CON2の23ピン、CON1の38ピンに接続 | 35 | GND | Power | 電源(GND) | 36 | PWMO1 | Out | LCD 拡張 I/F PWMO1、CON1の39ピン、LEDドライバのFBピンに接続 | 37 | LCD_OE_ACD | Out | LCD 拡張 I/F OE_ACD、CON1の40ピン、CON1の34ピンに接続 | 38 | LCD_VSYN | Out | LCD 拡張 I/F VSYN、CON1の41ピン、CON1の33ピンに接続 | 39 | LCD_HSYN | Out | LCD 拡張 I/F HSYN、CON1の42ピン、CON1の32ピンに接続 | 40 | LCD_LSCLK | Out | LCD 拡張 I/F LSCLK、CON1の43ピン、CON1の31ピンに接続 |
6.25.4.10. CON7(拡張インターフェース)CON7はユーザー側で自由に利用できるスイッチ、LED拡張用のインターフェースです。部品は実装されていません。 表6.68 CON7 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.25.4.11. CON8、CON9、CON10(RTCバックアップインターフェース)CON8、CON9、CON10はRTCのバックアップ電源供給用のインターフェースです。
CON9、CON10に部品は実装されていません。 表6.69 CON8 信号配列 ピン番号 | ピン名 | I/O | 説明 |
表6.70 CON9、CON10 信号配列 ピン番号 | ピン名 | I/O | 説明 |
6.25.4.12. SW1、SW2、SW3、SW4、SW5、SW6(ユーザースイッチ)SW1、SW2、SW3、SW4、SW5、SW6はユーザー側で自由に利用できるスイッチです。
SW4、SW5、SW6に部品は実装されていません。 表6.71 SW1、SW2、SW3、SW4、SW5、SW6の機能 部品番号 | 説明 |
LED1は電源LEDです。 表6.72 LED1の機能 部品番号 | 名称(色) | 説明 |
6.25.4.14. LED2、LED3ユーザー(LED)LED2、LED3はユーザー側で自由に利用できるLEDです。部品は実装されていません。 表6.73 LED2、LED3の機能 部品番号 | 名称(色) | 説明 |
タッチパネルLCDとLCD拡張ボードは図6.176「タッチパネルLCDとLCD拡張ボードの接続」のように接続します。 -
LCD拡張ボード CON2のロックレバーを上げる
LCD拡張ボード CON2のロックレバーを下げる
タッチパネルLCDをLCD拡張ボードに両面テープで固定する場合、図6.177「両面テープの貼付位置」の位置に貼付するのがおすすめです。 -
両面テープ貼付位置
絶縁テープ
Armaidllo-610 拡張ボードとLCD拡張ボードは図6.178「Armadillo-610とLCD拡張ボードの接続」を参考にし、Armadillo-610 拡張ボードのCON11の1ピンとLCD拡張ボードのCON1の50ピンが対応するように、FFCを接続します。
必ず1ピンと50ピンが対応するように、接続してください。
故障の原因となります。 |
故障する可能性があります。 |
両面テープ
固定部品
