library IEEE;
use ieee.std_logic_1164.all;
entity direct_sync is
generic (
C_AWIDTH : integer := 24;
C_DWIDTH : integer := 16;
C_BASEADDR : std_logic_vector := x"B2000000";
C_HIGHADDR : std_logic_vector := x"B27FFFFF"
port (
SYSCLK : in std_logic; -- Clock
RESET : in std_logic; -- Reset
SA : in std_logic_vector(C_AWIDTH-1 downto 0); -- Address
CS3_N : in std_logic; -- Chip Select3
EB1_N : in std_logic; -- Enable Byte(15:8)
RW_N : in std_logic; -- Read Write
RDY_N : out std_logic; -- Ready
SD : inout std_logic_vector(C_DWIDTH-1 downto 0) -- Data
end direct_sync;
architecture Behavioral of direct_sync is
signal reg0 : std_logic_vector(C_DWIDTH-1 downto 0); -- Register
signal data_o : std_logic_vector(C_DWIDTH-1 downto 0); -- Output Data
signal RDY_d1 : std_logic; -- RDY Delay
signal RDY_N_w : std_logic; -- RDY wire
signal EB0_N : std_logic; -- Enable Byte(7:0)
begin
EB0_N <= SA(0);
-- RDY Signal Gen
process(SYSCLK, RESET)
begin
if RESET = '1' then
RDY_d1 <= '1';
RDY_N_w <= '1';
elsif SYSCLK'event and SYSCLK = '1' then
RDY_d1 <= CS3_N;
RDY_N_w <= RDY_d1;
end if;
end process;
RDY_N <= RDY_N_w;
-- Write Access
begin
if RESET = '1' then
reg0 <= (others => '0');
if CS3_N = '0' and RW_N = '0' and RDY_N_w = '0' then
case SA(3 downto 1) is
when "000" =>
if EB1_N = '0' then
if EB0_N = '0' then
reg0 <= SD;
else
reg0(15 downto 8) <= SD(15 downto 8);
end if;
else
reg0(7 downto 0) <= SD(7 downto 0);
end if;
when others => null;
end case;
end if;
end if;
end process;
-- Read Access
begin
if RESET = '1' then
data_o <= (others => '0');
if CS3_N = '0' and RW_N = '1' and RDY_N_w = '0' then
when "000" => data_o <= reg0;
when others => data_o <= (others => '0');
end case;
end if;
end if;
end process;
SD <= data_o when CS3_N = '0' and RW_N = '1' and RDY_N_w = '0' else (others => 'Z');
end Behavioral;
