When connecting power to Armadillo-IoT G3, the start mode changes depending on the slide switch on the USB serial converter. For details, refer to 「Slide Switch Configuration」. This section shows an example when maintenance mode is selected. When auto boot mode is selected, the startup completes without requiring any input. To boot the Linux system, enter the "boot" command as shown below. When the command is executed, the bootloader starts the Linux system and the Linux boot log is displayed in the serial communication software. | |
The startup status of Armadillo-IoT can be checked with the user LEDs. Therefore, the startup status of Linux can be confirmed even if turning on power without connecting the USB serial converter to Armadillo-IoT. For the location of the user LEDs, see 図5.40「User LEDs Location」. |
The login prompt will be displayed once the boot has completed. The usernames shown in 表4.1「Serial Console Login Username and Password」 can be used to login. 表4.1 Serial Console Login Username and Password Username | Password | Permissions |
root | root | root user | atmark | atmark | general user |
When connecting the device for the first time, please make sure to change the default password by following the procedure below. Login as root Change the default password. Login as atmark Change the default password.
With Armadillo-IoT G3 being a device that can be connected to a network, the security risk will be extremely high if used with the default password. It is strongly recommended to change the password to one with high security strength, and then manage the password appropriately thereafter. |
4.3. Managing Debian UsersCreating a User Here we create a user named guest as an example. Changing the Password Here we change the password of the guest user as an example. Permitting Use of sudo Here we give permission to use sudo to the guest user as an example. For details on how to use vi, please refer to 「Using the vi Editor」. Deleting a User Here we delete the guest user as an example. | |
To delete the home directory at the same time, use the "r" option. |
To perform a safe shutdown, execute the command shown below, wait until the "System halted." message is displayed and then disconnect the power supply. | |
Disconnecting the power supply while data is being written to storage may result in the file system or the data being damaged. Be sure to unmount storage first before disconnecting the power supply. |
